Gönderen Konu: [Çözüldü] Genymotion ve Virtualbox Sorunu  (Okunma sayısı 3713 defa)
Çevrimdışı Comedy
  • İleti: 33
  • Dağıtım: mint
  • Masaüstü Ortamı: bilmiyom
  • Grafik Kartı: bilmiyom
« : 25 Nisan 2019, 19:34:33 »
Genymotion similatör kurmaya çalışıyorum, kurdum da. Ancak Virtaulbox'da bir sıkıntım var galiba.
Forumdaki diğer konulara baktım herhangi bir değişiklik olmadı.
sincap@Sincap:~$ inxi -Fxxz
System:
  Host: Sincap Kernel: 4.15.0-48-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: MATE 1.20.1 wm: marco dm: LightDM
Machine:
  Type: Laptop System: LENOVO product: 20351 v: Lenovo G50-70
  serial: <filter> Chassis: type: 10 v: Lenovo G50-70 serial: <filter>
  Mobo: LENOVO model: Lancer 5A2 v: 31900059WIN serial: <filter>
  UEFI: LENOVO v: 9ACN29WW date: 10/20/2014
Battery:
  ID-1: BAT0 charge: 6.3 Wh condition: 20.5/28.5 Wh (72%) volts: 14.0/14.4
  model: Lenovo IdeaPad serial: <filter> status: Discharging
CPU:
  Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
  arch: Haswell rev: 1 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19156
  Speed: 895 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 798 2: 798
  3: 798 4: 798
Graphics:
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
  Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] driver: radeon v: kernel
  bus ID: 03:00.0 chip ID: 1002:666f
  Display: x11 server: X.Org 1.19.6 driver: ati,modesetting,radeon
  unloaded: fbdev,vesa compositor: marco resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.2.8
Audio:
  Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
  Sound Server: ALSA v: k4.15.0-48-generic
Network:
  vendor: Lenovo driver: r8169 v: 2.3LK-NAPI port: 4000 bus ID: 01:00.0
  chip ID: 10ec:8168
  IF: enp1s0 state: down mac: <filter>
  Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel port: 4000
  bus ID: 02:00.0 chip ID: 8086:08b4
Drives:
  Local Storage: total: 465.76 GiB used: 126.60 GiB (27.2%)
  ID-1: /dev/sda vendor: Seagate model: ST500LM000-SSHD-8GB size: 465.76 GiB
  speed: 6.0 Gb/s serial: <filter> temp: 44 C
Partition:
  ID-1: / size: 456.96 GiB used: 126.60 GiB (27.7%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 257 Uptime: 1h 09m Memory: 3.75 GiB used: 2.37 GiB (63.3%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc: 7.3.0 alt: 7 Shell: bash
  v: 4.4.19 running in: mate-terminal inxi: 3.0.27
sincap@Sincap:~$
Düzenleme: yazım kuralları => İmla ve Yazım Kuralları
« Son Düzenleme: 26 Nisan 2019, 21:56:10 Gönderen: Comedy »
Ynt: Genymotion ve Virtualbox Sorunu
« Yanıtla #1 : 25 Nisan 2019, 22:59:28 »
Genymotion uygulamasını başlattığınız komutun başına, env LC_ALL=C değişkeni ekleyip başlatmayı deneyiniz. Eğer sorun çözülmezse komutun çıktısını paylaşırsınız.
env LC_ALL=C /genymotion/uygulamasını/başlattığınız/komut
Çevrimdışı Comedy
  • İleti: 33
  • Dağıtım: mint
« Yanıtla #2 : 26 Nisan 2019, 09:38:02 »
merhaba
sincap@Sincap:/opt/genymotion$ env LC_ALL=C ./genymotion start
Logging activities to file: /home/sincap/.Genymobile/genymotion.log
komutu start vermiş olmama ragmen yine aynı şekilde hata verdi yani bir değişiklik olmadı
2. aşamada programı açabildim ancak bu seferde sistem tam başlayacağı anda program kapanıyor. gelip gitmesi bir oluyor.
genymotion ekranı
« Son Düzenleme: 26 Nisan 2019, 09:46:43 Gönderen: Comedy »
« Yanıtla #3 : 26 Nisan 2019, 14:44:16 »
Sorun yaşandığında aşağıdaki komutun çıktısını paylaşırsınız.
cat ~/.Genymobile/genymotion.log
Bir de aşağıdaki komutun çıktısına bakalım.
dpkg -l | grep virtualbox
Çevrimdışı Comedy
  • İleti: 33
  • Dağıtım: mint
« Yanıtla #4 : 26 Nisan 2019, 16:43:04 »
sincap@Sincap:~$ dpkg -l | grep virtualbox
ii  unity-scope-virtualbox                     0.1+13.10.20130723-0ubuntu1                 all          VirtualBox scope for Unity
ii  virtualbox                                 5.2.18-dfsg-2~ubuntu18.04.5                 amd64        x86 virtualization solution - base binaries
ii  virtualbox-dkms                            5.2.18-dfsg-2~ubuntu18.04.5                 all          x86 virtualization solution - kernel module sources for dkms
ii  virtualbox-qt                              5.2.18-dfsg-2~ubuntu18.04.5                 amd64        x86 virtualization solution - Qt based user interface
sincap@Sincap:~$
malesef yukardaki kodda işe yaramadı
« Yanıtla #5 : 26 Nisan 2019, 19:16:54 »
Komutun bir işe yarayacağını söylemedim zaten, ilk komutun çıktısı Genymotion uygulamasının hata günlüğünü görüntülemenizi ve bu sayede paylaşmanıza imkan verecek.
Çevrimdışı Comedy
  • İleti: 33
  • Dağıtım: mint
« Yanıtla #6 : 26 Nisan 2019, 20:46:07 »
bu kod cıktısını nasıl paylaşabilirim sizinle , 300000 den fazla karaktere sahip forumda, fazla karaktere sahip olduğu için paylaşamıyorum
« Son Düzenleme: 26 Nisan 2019, 20:52:19 Gönderen: Comedy »
« Yanıtla #7 : 26 Nisan 2019, 21:33:52 »
Genymotion kapalı olduğu halde önce aşağıdaki komutu çalıştırın, bu komutla mevcut günlük dosyasını silinsin.
rm -f ~/.Genymobile/genymotion.log
Ardından Genymotion uygulamasını çalıştırın, hata alınca aşağıdaki komutu çalıştırırsınız.
cat ~/.Genymobile/genymotion.log | nc termbin.com 9999
Bu komutun ürettiği bağlantıyı foruma aktarırsınız.
Genymotion uygulamasını LC_ALL=C değişkeni ile başlatmayı unutmayın.
Çevrimdışı Comedy
  • İleti: 33
  • Dağıtım: mint
« Yanıtla #8 : 26 Nisan 2019, 21:42:48 »
tekrar merhaba hocam.. logları sildikten sonra tekra rçalıştırmayı denedim... şimdi ekran açılıp kapanması gitti ancak bu seferde açılan ekran siyah ve herhangi birşey açılmadı.
sincap@Sincap:~$ cat ~/.Genymobile/genymotion.log | nc termbin.com 9999
https://termbin.com/g9ae
sincap@Sincap:~$
sorun Butterfly arkadaşımız sayesinde sorun çözüldü.  çok tşkler. emeğiniz büyük
« Son Düzenleme: 26 Nisan 2019, 21:55:42 Gönderen: Comedy »
Ynt: [Çözüldü] Genymotion ve Virtualbox Sorunu
« Yanıtla #9 : 26 Nisan 2019, 22:37:04 »
Sorunu LC_ALL=C değişkeni çözmüş olabilir. Bu değişken ASCII ile kodlanmış uygulamalarda, uygulamayı kodlama dilinde çalıştırarak yerel dilden kaynaklı sorunları çözebiliyor.
Bunu denemek için önce uygulamayı klasik şekilde başlatmayı deneyin. Eğer bu şekilde sorun devam ediyorsa, aşağıdaki şekilde LC_ALL=C değişkeni ile başlatırsınız.
Bu komutla sorun çözüldüğünü teyit ediyorsanız, aşağıdaki komutlarla bir alias (kısaltma) oluşturabilirsiniz. Aşağıdaki komutu birden fazla kere çalıştırmayın.
echo "alias genymotion='env LC_ALL=C genymotion'" | tee -a ~/.bashrc
source ~/.bashrc
Bu şekilde alias ekledikten sonra sadece genymotion komutunu kullanabilirsiniz.
