Gönderen Konu: [Çözüldü] fedora nvidia optimus düşük fps  (Okunma sayısı 3327 defa)
Çevrimdışı derek
  • İleti: 77
« : 01 Mayıs 2019, 17:21:23 »
arkadaşlar glxgears -info komutunu verdiğimde aldığım oranlar çok düşük. bunun bir çözümü var mı?
244 frames in 5.0 seconds = 48.650 FPS
154 frames in 5.0 seconds = 30.783 FPS
171 frames in 5.0 seconds = 34.193 FPS
166 frames in 5.0 seconds = 33.178 FPS
217 frames in 5.0 seconds = 43.388 FPS
189 frames in 5.1 seconds = 37.026 FPS
q149 frames in 5.0 seconds = 29.791 FPS
laptop özellikleri; nvidia sürücüsünü kurdum.
$ inxi -Fxxz
System:    Host: fedora30 Kernel: 5.0.9-301.fc30.x86_64 x86_64 bits: 64 compiler: gcc v: 9.0.1 Desktop: Gnome 3.32.1
           wm: gnome-shell dm: GDM Distro: Fedora release 30 (Thirty)
Machine:   Type: Laptop System: ASUSTeK product: X556UQK v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <filter> UEFI: American Megatrends v: X556UQK.313 date: 03/13/2018
Battery:   ID-1: BAT0 charge: 28.0 Wh condition: 33.3/38.0 Wh (88%) volts: 7.6/7.6 model: ASUSTeK ASUS Battery
           serial: <filter> status: Charging
CPU:       Topology: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21696
           Speed: 601 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 694 2: 686 3: 695 4: 699
Graphics:  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
           Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia v: 418.56 bus ID: 01:00.0 chip ID: 10de:134d
           Display: x11 server: Fedora Project X.org 1.20.4 driver: nvidia compositor: gnome-shell resolution: 1366x768~60Hz
           OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 418.56 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:9d71
           Sound Server: ALSA v: k5.0.9-301.fc30.x86_64
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
           bus ID: 02:00.0 chip ID: 10ec:8168
           Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lite-On driver: ath9k v: kernel
           port: d000 bus ID: 03:00.0 chip ID: 168c:0036
           IF-ID-1: virbr0 state: down mac: <filter>
           IF-ID-2: virbr0-nic state: down mac: <filter>
Drives:    Local Storage: total: 931.51 GiB used: 63.93 GiB (6.9%)
           ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 59.79 GiB used: 6.82 GiB (11.4%) fs: ext4 dev: /dev/sda7
           ID-2: /boot size: 975.9 MiB used: 126.1 MiB (12.9%) fs: ext4 dev: /dev/sda5
           ID-3: /home size: 29.19 GiB used: 269.0 MiB (0.9%) fs: ext4 dev: /dev/sda8
           ID-4: swap-1 size: 5.87 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
Sensors:   System Temperatures: cpu: 46.5 C mobo: N/A gpu: nvidia temp: 49 C
           Fan Speeds (RPM): N/A
Info:      Processes: 268 Uptime: 15m Memory: 11.61 GiB used: 2.10 GiB (18.1%) Init: systemd v: 241 runlevel: 5
           target: graphical.target Compilers: gcc: 9.0.1 Shell: bash v: 5.0.2 running in: gnome-terminal inxi: 3.0.32
« Son Düzenleme: 01 Mayıs 2019, 22:38:50 Gönderen: derek »
Ynt: fedora nvidia optimus düşük fps
« Yanıtla #1 : 01 Mayıs 2019, 18:45:10 »
Aşağıdaki kumutu çalıştırınca durum ne oluyor?
__GL_SYNC_TO_VBLANK=0 glxgears
Çevrimdışı derek
  • İleti: 77
« Yanıtla #2 : 01 Mayıs 2019, 19:34:42 »
şimdi şu çıktıyı veriyor
[sonsuz@fedora30 ~]$ __GL_SYNC_TO_VBLANK=0 glxgears
44500 frames in 5.0 seconds = 8899.881 FPS
45425 frames in 5.0 seconds = 9084.933 FPS
45420 frames in 5.0 seconds = 9083.127 FPS
47912 frames in 5.0 seconds = 9582.343 FPS
« Yanıtla #3 : 01 Mayıs 2019, 22:25:23 »
Nvidia sürücüsü ile dikey eşitleme varsayılan olarak etkin olduğu için FPS sınırlanıyor. Bu, bir yandan yırtılma sorunlarının olmasını engelliyor. Pasifleştirmek için şunu deneyebilirsiniz. https://forum.linuxmint.net.tr/index.php?topic=9948.msg61172#msg61172
Çevrimdışı derek
  • İleti: 77
« Yanıtla #4 : 01 Mayıs 2019, 22:38:13 »
[member=8]Butterfly[/member]
çok teşekkür ederim.  sorun çözüldü. şuan herhangi bir yırtılma yok. fps değeri arttı, normale döndü.
Ynt: [Çözüldü] fedora nvidia optimus düşük fps
« Yanıtla #5 : 01 Mayıs 2019, 23:13:08 »
Rica ederiz.
