Gönderen Konu: [Çözüldü] Ram miktarının düşük görünmesi sorunu  (Okunma sayısı 3250 defa)
Çevrimdışı joshquunn
  • İleti: 75
  • İşlemci: AMD A8 6410
Kullandığım Laptopa 8 gb ram ram taktım, sistemde 6.7 gb gibi görünmekte daha önceden 4 gb ram vardı o zamanda 3.3 gb görünüyordu pek takmamıştım fakat 1.3 gb lık bir kayıp söz konusu ne yapmalıyım acaba.
kolay gelsin
inxi -Fxxz
System:
  Host: hp Kernel: 4.15.0-48-generic x86_64 bits: 64 compiler: gcc v: 7.3.0
  Desktop: Cinnamon 4.0.10 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: Hewlett-Packard product: HP 15 Notebook PC
  v: 0990100000000000001600087 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 22CE v: 93.0E serial: <filter> UEFI: Insyde
  v: F.12 date: 04/12/2014
Battery:
  ID-1: BAT1 charge: 20.2 Wh condition: 20.3/20.3 Wh (100%) volts: 17.2/14.8
  model: 11-85 OA04041 serial: <filter> status: Charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M215 2nd Gen
  serial: <filter> charge: 100% status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K330
CPU:
  Topology: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics
  bits: 64 type: MCP arch: Puma rev: 1 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 15969
  Speed: 1141 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 1135 2: 1186
  3: 1118 4: 1198
Graphics:
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
  driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9851
  Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] driver: radeon v: kernel
  bus ID: 01:00.0 chip ID: 1002:666f
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD MULLINS (DRM 2.50.0 4.15.0-48-generic LLVM 8.0.0)
  v: 4.5 Mesa 19.0.1 - padoka PPA direct render: Yes
Audio:
  Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:9840
  Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus ID: 00:14.2 chip ID: 1022:780d
  Sound Server: ALSA v: k4.15.0-48-generic
Network:
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: Hewlett-Packard driver: ath9k v: kernel port: 4100 bus ID: 03:00.0
  chip ID: 168c:0036
  IF: wlo1 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: 2.3LK-NAPI port: 2000
  bus ID: 04:00.0 chip ID: 10ec:8136
  Device-3: Atheros type: USB driver: btusb bus ID: 1-1.4:4
  chip ID: 0cf3:3121
Drives:
  Local Storage: total: 111.79 GiB used: 41.94 GiB (37.5%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
Partition:
  ID-1: / size: 109.04 GiB used: 41.93 GiB (38.5%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 49.4 C mobo: 20.0 C gpu: radeon temp: 51 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 186 Uptime: 1h 03m Memory: 6.76 GiB used: 1.59 GiB (23.6%)
  v: 4.4.19 running in: gnome-terminal inxi: 3.0.27
« Son Düzenleme: 08 Mayıs 2019, 01:04:39 Gönderen: joshquunn »
Ynt: Ram miktarının düşük görünmesi sorunu
« Yanıtla #1 : 07 Mayıs 2019, 23:47:53 »
Aşağıdaki komutların çıktılarına da bakalım.
sudo inxi -m
sudo lshw -C memory
  • İleti: 75
« Yanıtla #2 : 08 Mayıs 2019, 00:32:59 »
bu arada 2 slot varmış gibi görünüyor ama tek slot var
sudo inxi -m
Memory:
  RAM: total: 6.76 GiB used: 2.50 GiB (37.0%)
  Array-1: capacity: 8 GiB slots: 2 EC: None
  Device-1: Bottom size: 8 GiB speed: 800 MT/s
  Device-2: Top size: No Module Installed
sudo lshw -C memory
*-firmware
       açıklama: BIOS
       üretici: Insyde
       physical id: 0
       sürüm: F.12
       date: 04/12/2014
       boyut: 128KiB
       kapasite: 8128KiB
       kapasiteler: pc_ upgrade shadowing cdboot bootselect socketedrom edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acp_ usb uefi
  *-memory
       açıklama: Sistem Belleği
       physical id: 10
       slot: System board or motherboard
       boyut: 8GiB
     *-bank:0
          açıklama: SODIMM DDR3 Eşzamanlı Unbuffered (Unregistered) 800 MHz (1,2 ns)
          üretici: Kingston
          physical id: 0
          serial: 10CC9D86
          slot: Bottom
          boyut: 8GiB
          genişlik: 64 bits
          saat: 800MHz (1.2ns)
     *-bank:1
          açıklama: SODIMMProject-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME <EMAIL@ADDRESS>PO-Revision-Date: 2013-10-03 13:53+0000Last-Translator: Emre AYTAÇ <Unknown>Language-Team: Turkish <tr@li.org>MIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2018-07-12 13:19+0000X-Generator: Launchpad (build 18719) [boş]
          ürün: Empty
          üretici: Empty
          physical id: 1
          serial: Empty
          slot: Top
  *-cache:0
       açıklama: L1 önbellek
       physical id: 19
       slot: L1 Cache
       boyut: 256KiB
       kapasite: 256KiB
       saat: 1GHz (1.0ns)
       kapasiteler: pipeline-burst internal write-back unified
       yapılandırma: level=1
  *-cache:1
       açıklama: L2 önbellek
       physical id: 1a
       slot: L2 Cache
       boyut: 2MiB
       kapasite: 2MiB
       saat: 1GHz (1.0ns)
       yapılandırma: level=2
« Son Düzenleme: 08 Mayıs 2019, 00:34:33 Gönderen: joshquunn »
« Yanıtla #3 : 08 Mayıs 2019, 00:54:23 »
Ürün alırken GiB ve GB farkına dikkat etmek gerekiyor. GiB, gibibayt manasına geliyor, GB cigabayt . 1 GiB, yaklaşık olarak 1.073741824 GB ediyor. Yani 6.76 GiB, yaklaşık olarak 7.25 GB'ye karşılık geliyor. Geriye kalan miktar ise dahili GPU'ya tahsis edilmiş olabilir. Buradaki dönüştürücü faydalı olabilir.
  • İleti: 75
« Yanıtla #4 : 08 Mayıs 2019, 01:04:18 »
kelime oyununa denk gelmişiz demek sağlık olsun 500 mb oynuyormuş arada zaten neyse merakım giderilmiş oldu bir yerde.
  çok teşekkür ederim ilginize sorun çözülmüş oldu kolay gelsin
Ynt: [Çözüldü] Ram miktarının düşük görünmesi sorunu
« Yanıtla #5 : 08 Mayıs 2019, 01:16:04 »
     *-bank:0
          üretici: Kingston
          physical id: 0
          serial: 10CC9D86
          slot: Bottom
          boyut: 8GiB
Daha dikkatli bakınca, takılı olan RAM miktarının 8 GiB olduğunu gördüm. Bu durumda şöyle bir şey olabilir. Sistem takılı olan RAM'ın belirli bir orannı dahili GPU için ayırmış olabilir. Aşağıdaki komutun çıktısına bir bakalım.
glxinfo | grep memory
  • İleti: 75
« Yanıtla #6 : 08 Mayıs 2019, 01:29:20 »
Video memory: 1024MB
    Unified memory: no
    VBO free memory - total: 956 MB, largest block: 956 MB
    VBO free aux. memory - total: 2032 MB, largest block: 2032 MB
    Texture free memory - total: 956 MB, largest block: 956 MB
    Texture free aux. memory - total: 2032 MB, largest block: 2032 MB
    Renderbuffer free memory - total: 956 MB, largest block: 956 MB
    Renderbuffer free aux. memory - total: 2032 MB, largest block: 2032 MB
Memory info (GL_NVX_gpu_memory_info):
    Dedicated video memory: 1024 MB
    Total available memory: 3067 MB
    Currently available dedicated video memory: 956 MB
    GL_AMD_pinned_memory, GL_AMD_query_buffer_object,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB, GL_EXT_memory_object,
    GL_EXT_memory_object_fd, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
    GL_NVX_gpu_memory_info, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_AMD_performance_monitor, GL_AMD_pinned_memory,
    GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_arrays,
    GL_MESA_window_pos, GL_NVX_gpu_memory_info, GL_NV_blend_square,
    GL_EXT_map_buffer_range, GL_EXT_memory_object, GL_EXT_memory_object_fd,
