Gönderen Konu: Dell pc fan sesi ve ısıtma problemi  (Okunma sayısı 2619 defa)
Çevrimdışı harkail_rad
  • İleti: 115
  • Dağıtım: linux mint
« : 10 Mayıs 2019, 15:44:10 »
Bilgisayarımda ısınma ve fan sesi olmaya başladı..  Bilgisayar özellikleri aşağıdaki gibidir.
System:
  Host: WS-LIN-25 Kernel: 4.15.0-48-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Laptop System: Dell product: Inspiron 5379 v: N/A serial: <filter>
  Mobo: Dell model: 09NT72 v: A00 serial: <filter> UEFI: Dell v: 1.7.0
  date: 02/09/2018
Battery:
  ID-1: BAT0 charge: 40.3 Wh condition: 40.3/42.0 Wh (96%)
  model: SMP DELL Y3F7Y6B status: Full
CPU:
  Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 8192 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31872
  Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics:
  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0
  Display: x11 server: X.Org 1.19.6 driver: intel resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
  v: 4.5 Mesa 18.2.8 direct render: Yes
Audio:
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3
  Sound Server: ALSA v: k4.15.0-48-generic
Network:
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Dell driver: ath10k_pci v: kernel port: f040 bus ID: 01:00.0
  IF: wlp1s0 state: up mac: <filter>
  Device-2: Atheros type: USB driver: btusb bus ID: 1-7:4
Drives:
  Local Storage: total: 471.36 GiB used: 447.71 GiB (95.0%)
  ID-1: /dev/sda vendor: Toshiba model: KSG60ZMV256G M.2 2280 256GB
  ID-2: /dev/sdb type: USB vendor: Samsung model: SSD 850 EVO M.2 250GB
Partition:
  ID-1: / size: 233.24 GiB used: 215.55 GiB (92.4%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 56.0 C mobo: 54.0 C sodimm: 40.0 C
  Fan Speeds (RPM): cpu: 0
Info:
  Processes: 274 Uptime: 10m Memory: 7.54 GiB used: 2.29 GiB (30.4%)
  Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.19
  inxi: 3.0.27
Ynt: Dell pc fan sesi ve ısıtma problemi
« Yanıtla #1 : 11 Mayıs 2019, 00:32:45 »
Forumda Dell PC'ler ve fan sorunları ile ilgili konular mevcut. Öncelikle bunları denediniz mi?
Çevrimdışı meda
  • İleti: 408
  • Grafik Kartı: GT 940MX
  • İşlemci: İ7 7500U
« Yanıtla #2 : 11 Mayıs 2019, 08:39:55 »
BIOS güncellemesini yapın. https://www.dell.com/support/home/tr/tr/trdhs1/drivers/driversdetails?driverid=dwkr1   Daha sonra sistem güncellemelerini de yapınca ekran kartı sürücülerinin yüklenip doğru çalıştığından emin olmanızda fayda var.
« Son Düzenleme: 11 Mayıs 2019, 08:42:26 Gönderen: meda »
                   Orhan VELİ"
