Gönderen Konu: [Çözüldü] Tsc Yazıcı Kurulum Hatası  (Okunma sayısı 4876 defa)
Çevrimdışı Mustaf a GÜL
  • İleti: 16
  • Dağıtım: Ubuntu
« : 21 Mayıs 2019, 15:58:26 »
Öncelikle Merhabalar.
Bilgisayarımda Cinnamon x64 İşletim sistemi kurulu durumda.
Tsc ttp 244 Plus Barkod yazıcıyı bilgisayarıma kurmak istediğimde aşağıdaki uyarıyı alıyorum ne gibi bir yol izlemem gerekiyor.
Çıktılar aşağıdaki gibidir...
user@WS-LIN-36:~$ inxi -Fxz
System:
  Host: WS-LIN-36 Kernel: 4.15.0-50-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Desktop Mobo: INTEL model: N/A serial: <filter>
  BIOS: American Megatrends v: 080015 date: 12/04/2014
CPU:
  Topology: Dual Core model: Intel Core i3 M 380 bits: 64 type: MT MCP
  arch: Nehalem rev: 5 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20211
  Speed: 1706 MHz min/max: N/A Core speeds (MHz): 1: 1706 2: 1599 3: 1710
  4: 1727
Graphics:
  Device-1: Intel Core Processor Integrated Graphics driver: i915 v: kernel
  bus ID: 00:02.0
  tty: N/A
  OpenGL: renderer: Mesa DRI Intel Ironlake Mobile v: 2.1 Mesa 18.2.8
  direct render: Yes
Audio:
  Device-1: Intel 5 Series/3400 Series High Definition Audio
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k4.15.0-50-generic
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  v: 2.3LK-NAPI port: e800 bus ID: 02:00.0
  IF: ens133 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 111.79 GiB used: 19.66 GiB (17.6%)
  ID-1: /dev/sda model: SATA SSD size: 111.79 GiB
Partition:
  ID-1: / size: 109.53 GiB used: 19.66 GiB (17.9%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 31.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 188 Uptime: 6h 55m Memory: 3.66 GiB used: 771.7 MiB (20.6%)
  Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.19
  inxi: 3.0.27
Düzenleme: Kod etiketi
« Son Düzenleme: 22 Mayıs 2019, 14:21:41 Gönderen: Mustaf a GÜL »
Çevrimiçi Danny
Ynt: Tsc Yazıcı Kurulum Hatası
« Yanıtla #1 : 21 Mayıs 2019, 20:36:50 »
ürünün kendi sitesinde sürücüsü mevcutmuş zaten oradan indirip kurmayı denediniz mi ?
https://www.tscprinters.com/EN/support/support_download/TTP-244%20Plus
Linux Driver V0.2.06
For Linux 64 bit under Ubuntu 11.04~16.04 olanı indirebilirsiniz.
  • İleti: 16
  • Dağıtım: Ubuntu
« Yanıtla #2 : 22 Mayıs 2019, 07:29:21 »
Evet yazıcının kendi sitesinden en güncel driver indirildi.
Yazıcı bilgisayara Usb portu aracılığı ile bağlandı yazıcı ekle kısmına yazıcı düştü ekle dedim fakat otomatik olarak ekleyemedi.Yazıcı sitesinden indirmiş olduğum driver aracılığı ile pfd dosyasını gösterdim ve kurulumu sağladım fakat bu sefer bu hata ile karşılaştım.
Çevrimiçi Danny
« Yanıtla #3 : 22 Mayıs 2019, 11:16:28 »
PDF dosyasını gösterdim derken neyi kast etmek istediniz. PDF bir kurulum dosyası değildir, en kötü ihtimal kurulumu nasıl yapacağınızı gösteren bir sayfadır. Kurulumu nasıl gerçekleştirdiğinizi öğrenebilir miyim ?
  • İleti: 16
  • Dağıtım: Ubuntu
« Yanıtla #4 : 22 Mayıs 2019, 11:38:50 »
Özür dileyerekten düzeltmeyi yapıyorum bir harf hatası oluşmuş sanırım pfd demişim ama ppd olacaktı.
Kuruluma gelince:
Yazıcılar/Ekle/Açılan Pencerede Benim yazıcım görünüyor üstüne tıklayarak ileri/ppd dosyası sağla  diyerek indirmiş olduğum driver gösteriyorum sonrasında bu olay çıkıyor.
Yazıcıyı tekrar silerek kurulumu sıfırdan yaptım ve başarılı bir şekilde kurulum sağladım.
İlginiz için teşekkürler.
Konu çözülmüştür.
« Son Düzenleme: 22 Mayıs 2019, 12:07:39 Gönderen: Mustaf a GÜL »
Çevrimiçi Danny
« Yanıtla #5 : 22 Mayıs 2019, 14:13:35 »
sorun çözüldüğüne göre başlığı etiketlemenizi rica ederim.
