Gönderen Konu: [Çözüldü] Wine ile kurulmuş oyunda renk bozulması sorunu  (Okunma sayısı 4096 defa)
Çevrimdışı joshquunn
  • İleti: 75
  • İşlemci: AMD A8 6410
Oyun esnasında (wine ile) renklerin negatif (kamera filtresi gibi) hale gelmesi, tamamen yok olması, objeleri siyah bir gölge gibi görünmesi ya da renk değiştirmesi gibi sorunlar yaşamaktayım bilgisi olan dostların yardımı rica ederim
kolay gelsin
inxi -Fxxz
System:
  Host: HP-15 Kernel: 4.15.0-51-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.10 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: Hewlett-Packard product: HP 15 Notebook PC
  v: 0990100000000000001600087 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 22CE v: 93.0E serial: <filter> UEFI: Insyde
  v: F.12 date: 04/12/2014
Battery:
  ID-1: BAT1 charge: 24.2 Wh condition: 24.2/24.2 Wh (100%) volts: 16.9/14.8
  model: 11-85 OA04041 serial: <filter> status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M215 2nd Gen
  serial: <filter> charge: 100% status: Discharging
CPU:
  Topology: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics
  bits: 64 type: MCP arch: Puma rev: 1 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 15968
  Speed: 1319 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 1401 2: 1382
  3: 1385 4: 1590
Graphics:
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
  driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9851
  Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] driver: radeon v: kernel
  bus ID: 01:00.0 chip ID: 1002:666f
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD MULLINS (DRM 2.50.0 4.15.0-51-generic LLVM 8.0.0)
  v: 4.5 Mesa 19.0.1 - padoka PPA direct render: Yes
Audio:
  Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:9840
  Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus ID: 00:14.2 chip ID: 1022:780d
  Sound Server: ALSA v: k4.15.0-51-generic
Network:
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: Hewlett-Packard driver: ath9k v: kernel port: 4100 bus ID: 03:00.0
  chip ID: 168c:0036
  IF: wlo1 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: 2.3LK-NAPI port: 2000
  bus ID: 04:00.0 chip ID: 10ec:8136
  Device-3: Atheros type: USB driver: btusb bus ID: 1-1.4:7
  chip ID: 0cf3:3121
Drives:
  Local Storage: total: 577.55 GiB used: 246.36 GiB (42.7%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
  ID-2: /dev/sdb type: USB vendor: Seagate model: ST500DM002-1BD142
  size: 465.76 GiB serial: <filter>
Partition:
  ID-1: / size: 109.04 GiB used: 86.75 GiB (79.6%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 55.2 C mobo: 20.0 C gpu: radeon temp: 55 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 201 Uptime: 4h 15m Memory: 6.76 GiB used: 2.16 GiB (31.9%)
  v: 4.4.19 running in: gnome-terminal inxi: 3.0.27
« Son Düzenleme: 11 Haziran 2019, 01:28:46 Gönderen: joshquunn »
Ynt: Wine ile kurulmuş oyunda renk bozulması sorunu
« Yanıtla #1 : 07 Haziran 2019, 16:25:10 »
Hangi oyun, hangi wine sürümü ve nasıl kurduğunuz gibi ayrıntılı bilgileri paylaşınız.
Bir de şu konuyu inceleyiniz, eğer aygıtlar destekliyorsa uygulamayı deneyebilirsiniz. Nasıl sorgulanacağı konuda bahsediliyor.
[info][Nasıl] AMD/ATI Southern Islands ve Sea Islands Amdgpu Sürücüsünü Kullanma[/info]
« Yanıtla #2 : 07 Haziran 2019, 16:37:25 »
Bir de oyun adını ve kullandığı grafiki api'ını öğrenirsek ( D3D9 , 10 veya 11) daha faydalı olacaktır.
Zira eğer oyun D3D11 veya 10 kullanıyorsa DXVK , 9 kullanıyorss D9VK ile test etmeniz yerinde olur.
Gerçi kartınızda Butterfly'ın dediği şekilde AMDGPU kernel driverını aktif etmeniz gerekir zira üstteki çözümler RadeonSI Vulkan desteğinden yoksun olduğu için bir anlam ifade etmez.
  • İleti: 75
« Yanıtla #3 : 07 Haziran 2019, 16:55:57 »
üstadım oyun eski bir oyun Battlefield Bad Company 2 aşığı yukarı 10 senelik kadar dvdden yüklenmekte wine 4.0.1 stable kurulu. Kurulum esnasında hiçbir sıkıntı olmamıştı arayüzde de sıkıntı yok oyunu oynama esnasında gerçekleşen hadiseler bunlar.
Bu verdiğiniz linktekileri hainan southern island serisi işlemlerini gerçekleştirdim ama oyunda test etmedim.
Ayrıca mesa sürücüsünü yüklerken mesa vulkan driver util diye yüklemiştim, ama dxvk ve d3vk meseleleri hakkında  hiçbirşey bilmiyorum başka paylaşmam gereken bir şey varsa da belirtirseniz onları da iletirim.
inxi -SMGxx
System:
Machine:
  v: 0990100000000000001600087 serial: <root required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 22CE v: 93.0E serial: <root required>
  UEFI: Insyde v: F.12 date: 04/12/2014
Graphics:
OpenGL renderer string: AMD MULLINS (DRM 2.50.0, 4.15.0-51-generic, LLVM 8.0.0)
    GL_NVX_gpu_memory_info, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_EXT_read_format_bgra, GL_EXT_render_snorm, GL_EXT_robustness,
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Mullins [Radeon R4/R5 Graphics] (rev 05)
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun LE [Radeon HD 8550M / R5 M230] (rev ff)
eDP connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
   1366x768      60.03*+  40.01
   1280x720      59.97
   1152x768      59.95
   1024x768      59.95
   800x600       59.96
   848x480       59.94
   720x480       59.94
   640x480       59.94
ii  libdrm-amdgpu1:amd64                       2.4.97-1~b~padoka0                          amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                        2.4.97-1~b~padoka0                          i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  nvidia-prime-applet                        1.0.7                                       all          An applet for NVIDIA Prime
ii  xserver-xorg-video-amdgpu                  18.0.1-1                                    amd64        X.Org X server -- AMDGPU display driver
dkms status
herhangi bir sonuç vermedi
« Son Düzenleme: 07 Haziran 2019, 17:04:09 Gönderen: joshquunn »
« Yanıtla #4 : 07 Haziran 2019, 17:06:12 »
Tamamdır.
Öncelikle forumumuzun oyun bölümünde bulunan " Steam Kullanım Rehberi " adlı konudaki anlatıma göre Vulkan kütüphanesi kurulumunu gerçekleştiriniz.
Ardından yine oyun bölümünde bulunan " Lutris Kullanım Rehberi" 'nde anlatıldığı şekilde Lutris kurulumu yapınız.
Sonrasında aşağıdaki linkte bulunan " DVD with DXVK version " yükleyicisini kullanınız.
https://lutris.net/games/battlefield-bad-company-2/
Eğer isterseniz daha güncel bir Wine ve DXVk versiyonu ile de kullanabilirsiniz yükleme gerçekleştikten sonra. Lutris konusunda onun da anlatımı mevcut.
  • İleti: 75
« Yanıtla #5 : 07 Haziran 2019, 17:13:04 »
Sağolasınız üstadım yazdıklarınızı uygulayıp sonucu bildireceğim kolay gelsin
« Yanıtla #6 : 07 Haziran 2019, 17:56:57 »
Vulkan kütüphanesi kurulumunu eklemeyi unutmuşum.
Şimdi Steam kullanım rehberinde mevcut.
  • İleti: 75
« Yanıtla #7 : 07 Haziran 2019, 18:24:46 »
üstadım herşeyi uyguladım ama yine de olmadı bahsetmeye çalıştığım şey bu resim deki gibi renklerin oluşu yada simsiyah gölge gibi oluşu
not: bu oyun bf 3 oyunundan alıntı başka oyunda da oluyormu diye baktım aynısı nfs rival'de de oluyor orada da sadece kullanılan araba sorunlu görüntüdeydi.
« Son Düzenleme: 07 Haziran 2019, 18:28:52 Gönderen: joshquunn »
« Yanıtla #8 : 07 Haziran 2019, 18:55:28 »
Kurduğunuz installerda sağ tıkla configure deyip runner options kısmınının ekran görüntüsünü atar mısınız?
  • İleti: 75
« Yanıtla #9 : 07 Haziran 2019, 19:07:10 »
ha yazmayı unuttum bunu lutrisle yükleyemedim hesap açtım ama 404 sayfa hatası verdi uygulamadan da giremedim aktivasyon maili herşey tamam herhalde lutris ile ilgili geçici bir sıkıntı var zira daha önce kullanmıştım bu uygulamayı. direkt olarak kurdum bunu. cs-go da hiçbir problem de olmamış oğlum öyle diyor yüksek grafik özellikleri ile oynamış sıkıntı yok diyor
tamamdır lutriste dxvk kapalıydı configuire wine da runner options ekranında enable dxvk yapınca sorun çözüldü gibi yine de ilerde bir sorun olur mu bilmiyorum
« Son Düzenleme: 07 Haziran 2019, 19:25:48 Gönderen: joshquunn »
« Yanıtla #10 : 07 Haziran 2019, 19:35:07 »
Ilerde sorun olursa tekrar yazarsınız.
DXVK 1.2.1 ile kullanmanızı ve ve oyunun içinde DX11 rendererın seçili olmasını tavsiye ederim.
Bu arada Lutris'te hesap açmaya gerek yok.
« Son Düzenleme: 07 Haziran 2019, 20:56:10 Gönderen: Leopard »
  • İleti: 75
« Yanıtla #11 : 10 Haziran 2019, 23:29:16 »
Evet Üstadım, yaşadığım sorun kesinlikle vulkan kütüphanesinin eksik oluşu ve DXVK ile kurmamış olmamdan kaynaklanıyormuş onu anladım. 3 oyunda daha denedim sizin verdiğiniz talimatlarla lutris aracılığı ile kurulum yaptım sonuç harika. Hatta bugün Sekiro'yu da kurdum gayet iyi.
Yalnız bir sorum olacak lutriste DXVK 0.94 versiyonu kurulu olarak gösteriyor bana 1.2.1 versiyon ve directx11 ile kullanmamı önermiştiniz lutris i ppa deposundan yüklemiştim acaba otomatik olarak güncellenir mi yoksa ek bir işlem yapmalı mıyım?
« Yanıtla #12 : 11 Haziran 2019, 00:55:12 »
[member=5431]joshquunn[/member] Lutris Kullanım Rehberi'nin 5'inci adımında bunu açıklamıştım esasen.
Buradan kolaylıkla değiştirebilrsiniz.
Battlefield Bad Company 2'ye Lutris'te sağ tık - Configure - Runner Options
Steam'de olan oyunlarınız varsa bunlar için çoğunlukla Lutris kullanmaya gerek yok. Proton/ SteamPlay aracılığı ile native Steam Linux istemcisinden de bunları oynabilirsiniz. Yani Sekiro'yu pek ala native Linux client'ından da kurabilirsiniz. Onun kısaca konusu da burada.
https://forum.linuxmint.net.tr/index.php?topic=9695.0
DXVK ile sorununuz çözüldüyse zaten DX11 kullanıyorsunuz demektir. DXVK bir DX10 ve DX11 implementasyonudur. DX9 ileride D9VK olgunlaştığında eklenecek.
Eğer sorun tekrar etmiyorsa ve tam anlamıyla çözüldüyse , konuyu çözüldü olarak etiketleyebilirsiniz.
« Son Düzenleme: 11 Haziran 2019, 00:58:31 Gönderen: Leopard »
  • İleti: 75
« Yanıtla #13 : 11 Haziran 2019, 01:28:36 »
Yardımlarınız için teşekkür ederim herşey tamamdır.
kolay gelsin
