Gönderen Konu: E: /var/lib/dpkg/lock-frontend kilidi alınamadı  (Okunma sayısı 2615 defa)
Çevrimdışı Comedy
  • İleti: 33
  • Dağıtım: mint
  • Masaüstü Ortamı: bilmiyom
  • Grafik Kartı: bilmiyom
« : 30 Temmuz 2019, 12:47:31 »
merhaba
bir hata alıyorum ve benden istenilen kod çıktıları aşşağıdadır
sincap@Sincap:~$ inxi -Sr
System:
  Host: Sincap Kernel: 4.15.0-55-generic x86_64 bits: 64
  Desktop: MATE 1.20.1 Distro: Linux Mint 19.1 Tessa
Repos:
  No active apt repos in: /etc/apt/sources.list
  No active apt repos in: /etc/apt/sources.list.d/google-chrome.list
  Active apt repos in: /etc/apt/sources.list.d/morphis-anbox-support-bionic.list
  1: deb http://ppa.launchpad.net/morphis/anbox-support/ubuntu bionic main
  2: deb-src http://ppa.launchpad.net/morphis/anbox-support/ubuntu bionic main
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
  1: deb http://packages.linuxmint.com tessa main upstream import backport
  2: deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
  3: deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
  4: deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
  5: deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
  6: deb http://archive.canonical.com/ubuntu/ bionic partner
  Active apt repos in: /etc/apt/sources.list.d/opera-stable.list
  1: deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
  No active apt repos in: /etc/apt/sources.list.d/playonlinux.list
  No active apt repos in: /etc/apt/sources.list.d/skype-stable.list
  Active apt repos in: /etc/apt/sources.list.d/slack.list
  1: deb https://packagecloud.io/slacktechnologies/slack/debian/ jessie main
  No active apt repos in: /etc/apt/sources.list.d/teamviewer.list
  Active apt repos in: /etc/apt/sources.list.d/virtual-box.list
  1: deb [arch=amd64] http://download.virtualbox.org/virtualbox/debian bionic contrib
sincap@Sincap:~$ sudo apt-get update
Aynı:  1 http://archive.canonical.com/ubuntu bionic InRelease
Aynı:  2 http://security.ubuntu.com/ubuntu bionic-security InRelease
Aynı:  3 http://download.virtualbox.org/virtualbox/debian bionic InRelease
Aynı:  4 http://archive.ubuntu.com/ubuntu bionic InRelease
Aynı:  5 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Aynı:  6 http://ppa.launchpad.net/morphis/anbox-support/ubuntu bionic InRelease
Yoksay:7 http://packages.linuxmint.com tessa InRelease
Aynı:  8 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Aynı:  9 https://deb.opera.com/opera-stable stable InRelease
Aynı:  10 http://packages.linuxmint.com tessa Release
Aynı:  12 https://packagecloud.io/slacktechnologies/slack/debian jessie InRelease
hata burada
sincap@Sincap:~$ sudo apt-get install -f
E: /var/lib/dpkg/lock-frontend kilidi alınamadı - open (11: Özkaynak geçici olarak kullanılamaz durumda)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
sincap@Sincap:~$
Ynt: E: /var/lib/dpkg/lock-frontend kilidi alınamadı
« Yanıtla #1 : 30 Temmuz 2019, 13:18:41 »
Paket yöneticisi başka bir uygulama tarafından kullanılıyor olabilir. Durum buysa, diğer işlemin bitmesini beklemelisiniz.
Eğer paket yöneticisi kullanan bir işlemi yarıda bıraktıysanız, bu hatayı gidermek için sistemi yeniden başlatmak yeterli olacaktır.
Çevrimdışı Comedy
  • İleti: 33
  • Dağıtım: mint
« Yanıtla #2 : 30 Temmuz 2019, 13:41:50 »
bilgisayarı kapatıp tekrara açtım yinede olmadı.. hemen hemen 1 saat oldu sistem hata vereli , şuana kadar yükleme tamamlanmış olması gerekiyordu.. ancak tekrar kontrol ettim az önce yine aynı hatayı alıyorum.
örnek olarak Xampp yüklemek istiyorum
sincap@Sincap:~$ sudo apt-get install lamp-server^
Not, 'lamp-server' görevi için 'libgssapi3-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'libhttp-message-perl' seçiliyor
Not, 'lamp-server' görevi için 'libnghttp2-14' seçiliyor
Not, 'lamp-server' görevi için 'php7.2-common' seçiliyor
Not, 'lamp-server' görevi için 'libencode-locale-perl' seçiliyor
Not, 'lamp-server' görevi için 'php7.2-cli' seçiliyor
Not, 'lamp-server' görevi için 'libwind0-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'libsasl2-modules-db' seçiliyor
Not, 'lamp-server' görevi için 'mysql-client-5.7' seçiliyor
Not, 'lamp-server' görevi için 'libldap-2.4-2' seçiliyor
Not, 'lamp-server' görevi için 'libapache2-mod-php' seçiliyor
Not, 'lamp-server' görevi için 'libevent-core-2.1-6' seçiliyor
Not, 'lamp-server' görevi için 'mysql-server-5.7' seçiliyor
Not, 'lamp-server' görevi için 'php-common' seçiliyor
Not, 'lamp-server' görevi için 'libaprutil1' seçiliyor
Not, 'lamp-server' görevi için 'php7.2-mysql' seçiliyor
Not, 'lamp-server' görevi için 'libheimntlm0-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'mysql-server' seçiliyor
Not, 'lamp-server' görevi için 'libcgi-fast-perl' seçiliyor
Not, 'lamp-server' görevi için 'libwrap0' seçiliyor
Not, 'lamp-server' görevi için 'libhttp-date-perl' seçiliyor
Not, 'lamp-server' görevi için 'perl-modules-5.26' seçiliyor
Not, 'lamp-server' görevi için 'liblwp-mediatypes-perl' seçiliyor
Not, 'lamp-server' görevi için 'libfcgi-perl' seçiliyor
Not, 'lamp-server' görevi için 'libheimbase1-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'libcgi-pm-perl' seçiliyor
Not, 'lamp-server' görevi için 'libaprutil1-dbd-sqlite3' seçiliyor
Not, 'lamp-server' görevi için 'libaio1' seçiliyor
Not, 'lamp-server' görevi için 'php7.2-json' seçiliyor
Not, 'lamp-server' görevi için 'php7.2-opcache' seçiliyor
Not, 'lamp-server' görevi için 'libsasl2-2' seçiliyor
Not, 'lamp-server' görevi için 'libio-html-perl' seçiliyor
Not, 'lamp-server' görevi için 'ssl-cert' seçiliyor
Not, 'lamp-server' görevi için 'apache2-data' seçiliyor
Not, 'lamp-server' görevi için 'libperl5.26' seçiliyor
Not, 'lamp-server' görevi için 'libapr1' seçiliyor
Not, 'lamp-server' görevi için 'libaprutil1-ldap' seçiliyor
Not, 'lamp-server' görevi için 'libhtml-tagset-perl' seçiliyor
Not, 'lamp-server' görevi için 'mysql-client-core-5.7' seçiliyor
Not, 'lamp-server' görevi için 'libsasl2-modules' seçiliyor
Not, 'lamp-server' görevi için 'libldap-common' seçiliyor
Not, 'lamp-server' görevi için 'php7.2-readline' seçiliyor
Not, 'lamp-server' görevi için 'libhcrypto4-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'liblua5.2-0' seçiliyor
Not, 'lamp-server' görevi için 'mysql-common' seçiliyor
Not, 'lamp-server' görevi için 'libsodium23' seçiliyor
Not, 'lamp-server' görevi için 'libhtml-template-perl' seçiliyor
Not, 'lamp-server' görevi için 'libtimedate-perl' seçiliyor
Not, 'lamp-server' görevi için 'libroken18-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'apache2-bin' seçiliyor
Not, 'lamp-server' görevi için 'perl' seçiliyor
Not, 'lamp-server' görevi için 'libasn1-8-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'libkrb5-26-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'libgdbm-compat4' seçiliyor
Not, 'lamp-server' görevi için 'apache2' seçiliyor
Not, 'lamp-server' görevi için 'php-mysql' seçiliyor
Not, 'lamp-server' görevi için 'apache2-utils' seçiliyor
Not, 'lamp-server' görevi için 'libhx509-5-heimdal' seçiliyor
Not, 'lamp-server' görevi için 'libhtml-parser-perl' seçiliyor
Not, 'lamp-server' görevi için 'libapache2-mod-php7.2' seçiliyor
Not, 'lamp-server' görevi için 'liburi-perl' seçiliyor
Not, 'lamp-server' görevi için 'mysql-server-core-5.7' seçiliyor
libapache2-mod-php zaten en yeni sürümde (1:7.2+60ubuntu1).
libapr1 zaten en yeni sürümde (1.6.3-2).
libaprutil1 zaten en yeni sürümde (1.6.1-2).
libaprutil1-dbd-sqlite3 zaten en yeni sürümde (1.6.1-2).
libaprutil1-ldap zaten en yeni sürümde (1.6.1-2).
libasn1-8-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libcgi-fast-perl zaten en yeni sürümde (1:2.13-1).
libcgi-pm-perl zaten en yeni sürümde (4.38-1).
libencode-locale-perl zaten en yeni sürümde (1.05-1).
libevent-core-2.1-6 zaten en yeni sürümde (2.1.8-stable-4build1).
libfcgi-perl zaten en yeni sürümde (0.78-2build1).
libgdbm-compat4 zaten en yeni sürümde (1.14.1-6).
libgssapi3-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libhcrypto4-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libheimbase1-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libheimntlm0-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libhtml-parser-perl zaten en yeni sürümde (3.72-3build1).
libhtml-tagset-perl zaten en yeni sürümde (3.20-3).
libhtml-template-perl zaten en yeni sürümde (2.97-1).
libhttp-date-perl zaten en yeni sürümde (6.02-1).
libhttp-message-perl zaten en yeni sürümde (6.14-1).
libhx509-5-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libio-html-perl zaten en yeni sürümde (1.001-1).
libkrb5-26-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
liblua5.2-0 zaten en yeni sürümde (5.2.4-1.1build1).
liblwp-mediatypes-perl zaten en yeni sürümde (6.02-1).
libnghttp2-14 zaten en yeni sürümde (1.30.0-1ubuntu1).
libroken18-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libsasl2-2 zaten en yeni sürümde (2.1.27~101-g0780600+dfsg-3ubuntu2).
libsasl2-modules zaten en yeni sürümde (2.1.27~101-g0780600+dfsg-3ubuntu2).
libsasl2-modules-db zaten en yeni sürümde (2.1.27~101-g0780600+dfsg-3ubuntu2).
libsodium23 zaten en yeni sürümde (1.0.16-2).
libtimedate-perl zaten en yeni sürümde (2.3000-2).
liburi-perl zaten en yeni sürümde (1.73-1).
libwind0-heimdal zaten en yeni sürümde (7.5.0+dfsg-1).
libwrap0 zaten en yeni sürümde (7.6.q-27).
mysql-common zaten en yeni sürümde (5.8+1.0.4).
php-common zaten en yeni sürümde (1:60ubuntu1).
php-mysql zaten en yeni sürümde (1:7.2+60ubuntu1).
ssl-cert zaten en yeni sürümde (1.0.39).
apache2 zaten en yeni sürümde (2.4.29-1ubuntu4.8).
apache2-bin zaten en yeni sürümde (2.4.29-1ubuntu4.8).
apache2-data zaten en yeni sürümde (2.4.29-1ubuntu4.8).
apache2-utils zaten en yeni sürümde (2.4.29-1ubuntu4.8).
libaio1 zaten en yeni sürümde (0.3.110-5ubuntu0.1).
libapache2-mod-php7.2 zaten en yeni sürümde (7.2.19-0ubuntu0.18.04.1).
libldap-2.4-2 zaten en yeni sürümde (2.4.45+dfsg-1ubuntu1.2).
libldap-common zaten en yeni sürümde (2.4.45+dfsg-1ubuntu1.2).
libperl5.26 zaten en yeni sürümde (5.26.1-6ubuntu0.3).
mysql-client-5.7 zaten en yeni sürümde (5.7.27-0ubuntu0.18.04.1).
mysql-client-core-5.7 zaten en yeni sürümde (5.7.27-0ubuntu0.18.04.1).
mysql-server-5.7 zaten en yeni sürümde (5.7.27-0ubuntu0.18.04.1).
mysql-server-core-5.7 zaten en yeni sürümde (5.7.27-0ubuntu0.18.04.1).
perl zaten en yeni sürümde (5.26.1-6ubuntu0.3).
perl-modules-5.26 zaten en yeni sürümde (5.26.1-6ubuntu0.3).
php7.2-cli zaten en yeni sürümde (7.2.19-0ubuntu0.18.04.1).
php7.2-common zaten en yeni sürümde (7.2.19-0ubuntu0.18.04.1).
php7.2-json zaten en yeni sürümde (7.2.19-0ubuntu0.18.04.1).
php7.2-mysql zaten en yeni sürümde (7.2.19-0ubuntu0.18.04.1).
php7.2-opcache zaten en yeni sürümde (7.2.19-0ubuntu0.18.04.1).
php7.2-readline zaten en yeni sürümde (7.2.19-0ubuntu0.18.04.1).
  mysql-server
0 paket yükseltilecek, 1 yeni paket kurulacak, 0 paket kaldırılacak ve 0 paket yükseltilmeyecek.
0 B/9.948 B arşiv dosyası indirilecek.
Bu işlem tamamlandıktan sonra 110 kB ek disk alanı kullanılacak.
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Daha önce seçili olmayan mysql-server paketi seçiliyor.
(Veritabanı okunuyor ... 506264 dosya veya dizin kurulu durumda.)
Paket açılacak: .../mysql-server_5.7.27-0ubuntu0.18.04.1_all.deb ...
Paket açılıyor: mysql-server (5.7.27-0ubuntu0.18.04.1) ...
Ayarlanıyor: mysql-server-5.7 (5.7.27-0ubuntu0.18.04.1) ...
dpkg: mysql-server-5.7 paketi işlenirken sorun yaşandı (--configure):
 installed mysql-server-5.7 package post-installation script subprocess returned error exit status 1
dpkg: bağımlılık sorunları yüzünden mysql-server paketi yapılandırılamıyor:
 mysql-server şuna bağımlı: mysql-server-5.7, ama:
  mysql-server-5.7 paketi henüz yapılandırılmadı.
dpkg: mysql-server paketi işlenirken sorun yaşandı (--configure):
 bağımlılık sorunları - yapılandırılmadan bırakılıyor
Apport raporu yazılmadı çünkü hata iletisi bu durumun bir önceki hatadan kaynaklanan bir hata olduğunu belirtiyor.
 mysql-server-5.7
 mysql-server
sincap@Sincap:~$
son çıktıda bu şekilde hata alıyorum
« Son Düzenleme: 30 Temmuz 2019, 13:44:32 Gönderen: Comedy »
« Yanıtla #3 : 30 Temmuz 2019, 14:00:57 »
Bilgisayarınızı yeniden başlatınca "lock-frontend kilidi alınamadı" ile ilgili sorun çözülmüş görünüyor. Şu an Xammp kurulumu ile ilgili bir sorun yaşıyorsunuz. Bu başka bir başlığın konusu, forumda aynı başlık altında farklı soru ve sorunlar hakkında konuşmadığımızı biliyorsunuz.
Xammp kurulum sorunu ile ilgili olarak, aşağıdaki hususlara uygun biçimde yeni bir konu açınız. Lütfen ayrıntılı bilgi paylaşınız, aşağıdaki konuda neleri paylaşmanız gerektiği yazıyor, sürekli bu bağlantıyı paylaşmak zorunda kalıyoruz!
