Gönderen Konu: [Çözüldü] Linux Mint 19.2 de KDE kurmak  (Okunma sayısı 4581 defa)
Çevrimdışı joshquunn
  • İleti: 75
  • İşlemci: AMD A8 6410
« : 19 Ağustos 2019, 18:42:46 »
Başlıkta olduğu gibi Linux Mint 19.2 sürümünde temiz ve sorunsuz KDE tecrübesi yaşamak istiyorum. En azından denemek isterim.
Bu linkte https://forum.linuxmint.net.tr/index.php?topic=9837.0 bazı uygulamalar gerçekleşmiş ama LM 19.1 için yapılmış.
uygulasam benim için de geçerli olur mu?
inxi -Fxxz
System:
  Host: hp-15 Kernel: 5.0.0-25-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.2.3 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: Hewlett-Packard product: HP 15 Notebook PC
  v: 0990100000000000001600087 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 22CE v: 93.0E serial: <filter> UEFI: Insyde
  v: F.12 date: 04/12/2014
Battery:
  ID-1: BAT1 charge: 18.1 Wh condition: 18.1/18.1 Wh (100%) volts: 17.0/14.8
  model: 11-85 OA04041 serial: <filter> status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M215 2nd Gen
  serial: <filter> charge: 100% status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K330
CPU:
  Topology: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics
  bits: 64 type: MCP arch: Puma rev: 1 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 15969
  Speed: 1110 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 998 2: 998
  3: 998 4: 998
Graphics:
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
  driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9851
  Device-2: AMD Sun LE [Radeon HD 8550M / R5 M230] vendor: Hewlett-Packard
  driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:666f
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD MULLINS (DRM 2.50.0 5.0.0-25-generic LLVM 8.0.0)
  v: 4.5 Mesa 19.1.2 - padoka PPA direct render: Yes
Audio:
  Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:9840
  Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus ID: 00:14.2 chip ID: 1022:780d
  Sound Server: ALSA v: k5.0.0-25-generic
Network:
  Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: Hewlett-Packard driver: ath9k v: kernel port: 3000 bus ID: 03:00.0
  chip ID: 168c:0036
  IF: wlo1 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000 bus ID: 04:00.0
  chip ID: 10ec:8136
  Device-3: Atheros type: USB driver: btusb bus ID: 1-1.4:4
  chip ID: 0cf3:3121
Drives:
  Local Storage: total: 111.79 GiB used: 52.16 GiB (46.7%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
Partition:
  ID-1: / size: 109.04 GiB used: 52.16 GiB (47.8%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 50.8 C mobo: N/A gpu: radeon temp: 51 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 203 Uptime: 8h 12m Memory: 6.76 GiB used: 1.70 GiB (25.2%)
« Son Düzenleme: 19 Ağustos 2019, 23:09:42 Gönderen: joshquunn »
Ynt: Linux Mint 19.2 de KDE kurmak
« Yanıtla #1 : 19 Ağustos 2019, 18:59:11 »
Aşağıdaki komutlarla Kubuntu PPA deposundan güncel sürümü kurabilirsiniz.
sudo add-apt-repository ppa:kubuntu-ppa/ppa
sudo apt update
apt install kde-full systemsettings
Aşağıdaki komutla dil paketlerini de kurabilirsiniz.
apt install language-pack-kde-tr kde-l10n-tr
  • İleti: 75
« Yanıtla #2 : 19 Ağustos 2019, 19:05:38 »
teşekkür ederim
sorun var mı yok mu diye biraz kontrol edip geri dönüş yaparım  ya da çözüldü diye etiketlerim
kde plazmayı kurdum
1- başlık çubukları hiçbir uygulamada görünmüyor
2- alt panelde açılan pencerelerin hiçbiri görünmüyor
3- açılan uygulamalar kesinlikle ne tam ekran ne de küçültülebiliyor
şimdilik sıkıntılar bunlar sistem ayarlarına da ulaşılamıyor nasıl düzelteceğim hakkında fikrim yok yardımınızı beklerim
« Son Düzenleme: 19 Ağustos 2019, 22:38:18 Gönderen: joshquunn »
« Yanıtla #3 : 19 Ağustos 2019, 22:38:03 »
Bunlar pencere yöneticisine işaret ediyor, aşağıdaki komutla kwin paketini kurarsanız sorunla çözülür.
sudo apt install kwin
  • İleti: 75
« Yanıtla #4 : 19 Ağustos 2019, 23:09:28 »
Pencere yöneticisini yükledikten sonra sorun kalmadı teşekkür ederim
Ynt: [Çözüldü] Linux Mint 19.2 de KDE kurmak
« Yanıtla #5 : 19 Ağustos 2019, 23:20:03 »
Rica ederiz.
Bu durumda; Linux Mint 19.x serisine aşağıdaki komutlarla PPA deposundan son sürüm KDE masaüstünün yüklenebileceğini teyit etmiş olduk.
sudo apt update
apt install kde-full systemsettings kwin language-pack-kde-tr kde-l10n-tr
[okay]Başlık sonuca ulaştığı için konu kilitlenmiştir.[/okay]
