Gönderen Konu: Linux Mint 19.2 - RTL8723BE Kablosuz Ağ Sinyal Gücü Sorunu  (Okunma sayısı 3089 defa)
Çevrimdışı musat
  • İleti: 11
  • Dağıtım: Linux Mint 19.2
Merhaba bilgisayarımda wifi sinyalide sorun vardı.  Modemden azıcık uzaklaşınca çekmiyordu. Birkaç yöntem denedim ve çözüldü fakat bu seferde kapatıp açınca wifi yi hiç görmüyor.
sorunu çözen kod
sudo modprobe -r rtl8723be && sleep 15 && sudo modprobe rtl8723be ant_sel=2
bu çekme sorunun çözdü fakat apatıp açınca gidiyor wifi.
inxi -SMNnxxz
System:    Host: musa-HP-Notebook Kernel: 4.15.0-62-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.2.4
           wm: muffin dm: LightDM Distro: Linux Mint 19.2 Tina base: Ubuntu 18.04 bionic
Machine:   Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId serial: <filter> Chassis: type: 10
           serial: <filter>
           Mobo: HP model: 81FA v: 67.34 serial: <filter> UEFI: Insyde v: F.17 date: 09/01/2016
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: 2.3LK-NAPI port: 4000
           bus ID: 01:00.0 chip ID: 10ec:8136
           IF: enp1s0 state: down mac: <filter>
           Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8723be v: kernel
           port: 3000 bus ID: 02:00.0 chip ID: 10ec:b723
           IF: wlo1 state: up mac: <filter>
lspci -nnk | grep -iA2 net
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller [10ec:8136] (rev 07)
Subsystem: Hewlett-Packard Company RTL810xE PCI Express Fast Ethernet controller [103c:81fa]
Kernel driver in use: r8169
Kernel modules: r8169
02:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8723BE PCIe Wireless Network Adapter [10ec:b723]
Subsystem: Hewlett-Packard Company RTL8723BE PCIe Wireless Network Adapter [103c:81c1]
Kernel driver in use: rtl8723be
Kernel modules: rtl8723be
lsusb
Bus 001 Device 003: ID 0bda:b008 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 002 Device 002: ID 05c8:038f Cheng Uei Precision Industry Co., Ltd (Foxlink)
rfkill list
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
sudo lshw -C network
  *-network
       product: RTL810xE PCI Express Fast Ethernet controller
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: enp1s0
       version: 07
       serial: c8:d3:ff:93:cd:45
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:32 ioport:4000(size=256) memory:d3400000-d3400fff memory:d3000000-d3003fff
  *-network
       product: RTL8723BE PCIe Wireless Network Adapter
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlo1
       version: 00
       serial: 94:e9:79:c4:96:2b
       width: 64 bits
       clock: 33MHz
       configuration: broadcast=yes driver=rtl8723be driverversion=4.15.0-62-generic firmware=N/A ip=192.168.1.9 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:41 ioport:3000(size=256) memory:d2000000-d2003fff
iwconfig | grep Power
enp1s0    no wireless extensions.
          Bit Rate=72.2 Mb/s   Tx-Power=20 dBm
          Power Management:on
lsmod
ccm                    20480  6
rtl8723be              98304  0
btcoexist             126976  1 rtl8723be
rtl8723_common         24576  1 rtl8723be
rtl_pci                32768  1 rtl8723be
rtlwifi                77824  4 rtl_pci,rtl8723be,btcoexist,rtl8723_common
mac80211              786432  3 rtl_pci,rtl8723be,rtlwifi
cfg80211              622592  2 rtlwifi,mac80211
rfcomm                 77824  16
cmac                   16384  1
edac_mce_amd           28672  0
kvm                   598016  0
pcbc                   16384  0
aesni_intel           188416  6
wmi_bmof               16384  0
fam15h_power           16384  0
bluetooth             544768  43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
videobuf2_core         40960  2 videobuf2_v4l2,uvcvideo
videodev              184320  3 videobuf2_core,videobuf2_v4l2,uvcvideo
ecdh_generic           24576  2 bluetooth
media                  40960  2 videodev,uvcvideo
snd_hda_codec_realtek   106496  1
snd_hda_intel          40960  4
snd_hda_codec         126976  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core           81920  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_pcm                98304  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_seq                65536  2 snd_seq_midi,snd_seq_midi_event
snd_seq_device         16384  3 snd_seq,snd_seq_midi,snd_rawmidi
snd                    81920  19 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
hp_wireless            16384  0
8250_dw                16384  0
sch_fq_codel           20480  6
parport                49152  3 parport_pc,lp,ppdev
ip_tables              28672  0
btrfs                1138688  0
amdkfd                180224  2
amdgpu               2715648  23
hid                   110592  2 usbhid,hid_generic
chash                  16384  1 amdgpu
i2c_algo_bit           16384  1 amdgpu
ttm                   106496  1 amdgpu
psmouse               151552  0
drm_kms_helper        172032  1 amdgpu
ahci                   40960  2
i2c_piix4              24576  0
sdhci_pci              32768  0
sdhci                  49152  1 sdhci_pci
drm                   401408  8 drm_kms_helper,amdgpu,ttm
r8169                  86016  0
wmi                    24576  2 hp_wmi,wmi_bmof
i2c_scmi               16384  0
video                  45056  0
dkms status
Düzenleme: Konu başlığı
« Son Düzenleme: 12 Eylül 2019, 16:15:40 Gönderen: Butterfly »
Ynt: Bilgisayarı Kapatınca Wifi Gidiyor
« Yanıtla #1 : 12 Eylül 2019, 16:12:57 »
[member=7108]musat[/member] , forumda RTL8723BE çipseti ile ilgili anten çözümünü içeren konular mevcut. Forum içi arama yapıp bunları incelediniz mi? Forum içi arama ile şu konuya ulaşabilirdiniz. Lütfen forum içi arama yapmayı gözardı etmeyelim.
[info][Nasıl] RTLWifi-New Github Deposundan Realtek Kablosuz Ağ Sürücüsü Kurulumu[/info]
Çevrimdışı musat
  • İleti: 11
Ynt: Linux Mint 19.2 - RTL8723BE Kablosuz Ağ Sinyal Gücü Sorunu
« Yanıtla #2 : 12 Eylül 2019, 17:51:40 »
github dan dosyaları indirdikten sonra bu yöntemi denedim fakat kalıcı hale gelmiyor. Hata veriyor son kodu girince.
$ make
$ sudo make install
$ sudo modprobe -rv rtl8723be
$ sudo modprobe -v rtl8723be ant_sel=2
sudo ip link set wlp2s0 up
sudo iw dev wlp2s0 scan
Sonrasında ayarları kalıcı yapmak için bu komutu girin.
sudo echo "options rtl8723be ant_sel=2" > /etc/modprobe.d/50-rtl8723be.conf
Eğer bu şekilde olmazsa her iki verdiğim komut kısmındaki ant_sel=2 kısmını ant_sel=1 ile değiştirip deneyin.
hata kodu
bash: /etc/modprobe.d/50-rtl8723be.conf: Permission denied
« Son Düzenleme: 12 Eylül 2019, 18:01:09 Gönderen: musat »
« Yanıtla #3 : 12 Eylül 2019, 18:03:01 »
Ben size böyle bir öneri sunmadım. Bağlantısını verdiğim konuyu neden uygulamadınız?!
Çevrimdışı musat
  • İleti: 11
« Yanıtla #4 : 12 Eylül 2019, 18:10:10 »
Önerinizi uyguladım sorun çözülmedi. Sonra kurduğum paketi kaldırıp.
https://medium.com/@felladrin/how-o-manually-install-realtek-rtl8723be-wireless-drive-on-linux-3bd0fd6a59bb
bu sayfadaki kurulumları yaptım. ant sel 2 yaptım ve kalıcı yapmak için
echo "options rtl8723be ant_sel=2" | sudo tee /etc/modprobe.d/rtl8723be-ant.conf
bu kodu kullandım. Sorunum çözüldü teşekkürler.
« Yanıtla #5 : 12 Eylül 2019, 18:14:44 »
İlgili pakette sorunu çözecek yapılandırma ve sürücünün en güncel hali mevcut. Bağlantıda paketi kurduktan sonra, secureboot özelliğini kapatmanız gerektiği yazıyor, aksi durumda sürücü modülü etkinleşmez. Paket zaten belirttiğiniz github adresindeki sürücülerden oluşuyor. Yani paketi kurunca işe yaramaması, ama Github sayfasından kurulum ile sonuca ulaşmanız gibi bir olasılık mümkün değil.
Sorun çözüldüğü için konu kilitlenmiştir.
