Gönderen Konu: Ekran kartı güncellemesinden sonra donmaların olması  (Okunma sayısı 2155 defa)
Ekran kartı güncellemesinden sonra, belirsiz bir süre içerisinde ekranda donma oluyor ve hiç hareketlilik olmuyor.
Bilgisayarı yeniden başlatınca düzeliyor. Güncelleme öncesi bu durumu görmemiştim.
Ekran kartı çıktıların aşağıdaki gibidir.
Değerli bilgilerinizi rica ederim.
inxi -SMGxx
System:
  Host: WS-LIN-40 Kernel: 4.15.0-72-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.4.5 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: HP product: HP Pavilion Laptop 15-cs1xxx
  v: Type1ProductConfigId serial: <root required> Chassis: type: 10
  Mobo: HP model: 84C1 v: 15.21 serial: <root required>
  UEFI [Legacy]: Insyde v: F.07 date: 12/11/2018
Graphics:
  Device-1: Intel vendor: Hewlett-Packard driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3ea0
  Device-2: NVIDIA GP108M [GeForce MX150] vendor: Hewlett-Packard
  driver: nvidia v: 435.21 bus ID: 02:00.0 chip ID: 10de:1d10
  Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia
  unloaded: fbdev,nouveau,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: GeForce MX150/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21
  direct render: Yes
OpenGL renderer string: GeForce MX150/PCIe/SSE2
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
    GL_NV_command_list, GL_NV_compute_program5, GL_NV_conditional_render,
    GL_NV_path_rendering_shared_edge, GL_NV_pixel_data_range,
    GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
    GL_EXT_multisample_compatibility, GL_EXT_multisampled_render_to_texture,
    GL_EXT_multisampled_render_to_texture2,
    GL_EXT_raster_multisample, GL_EXT_render_snorm, GL_EXT_robustness,
    GL_NV_clip_space_w_scaling, GL_NV_conditional_render,
    GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
    GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
    GL_OVR_multiview_multisampled_render_to_texture
00:02.0 VGA compatible controller: Intel Corporation Device 3ea0
02:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX150] (rev a1)
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1920x1080     60.01*+  60.01    59.97    59.96    59.93    40.00
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
ii  libdrm-amdgpu1:amd64                       2.4.97-1ubuntu1~18.04.1                             amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                        2.4.97-1ubuntu1~18.04.1                             i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libnvidia-cfg1-435:amd64                   435.21-0ubuntu0.18.04.2                             amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-435                       435.21-0ubuntu0.18.04.2                             all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-435:amd64                435.21-0ubuntu0.18.04.2                             amd64        NVIDIA libcompute package
ii  libnvidia-compute-435:i386                 435.21-0ubuntu0.18.04.2                             i386         NVIDIA libcompute package
ii  libnvidia-decode-435:amd64                 435.21-0ubuntu0.18.04.2                             amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-435:i386                  435.21-0ubuntu0.18.04.2                             i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-435:amd64                 435.21-0ubuntu0.18.04.2                             amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-435:i386                  435.21-0ubuntu0.18.04.2                             i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-435:amd64                   435.21-0ubuntu0.18.04.2                             amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-435:i386                    435.21-0ubuntu0.18.04.2                             i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-435:amd64                     435.21-0ubuntu0.18.04.2                             amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-435:i386                      435.21-0ubuntu0.18.04.2                             i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-435:amd64                   435.21-0ubuntu0.18.04.2                             amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-435:i386                    435.21-0ubuntu0.18.04.2                             i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-compute-utils-435                   435.21-0ubuntu0.18.04.2                             amd64        NVIDIA compute utilities
ii  nvidia-dkms-435                            435.21-0ubuntu0.18.04.2                             amd64        NVIDIA DKMS package
ii  nvidia-driver-435                          435.21-0ubuntu0.18.04.2                             amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-435                   435.21-0ubuntu0.18.04.2                             amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-435                   435.21-0ubuntu0.18.04.2                             amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8.2                                             all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.0.8                                               all          An applet for NVIDIA Prime
ii  nvidia-settings                            390.77-0ubuntu0.18.04.1                             amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-435                           435.21-0ubuntu0.18.04.2                             amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-amdgpu                  18.0.1-1                                            amd64        X.Org X server -- AMDGPU display driver
ii  xserver-xorg-video-nvidia-435              435.21-0ubuntu0.18.04.2                             amd64        NVIDIA binary Xorg driver
dkms status
nvidia, 435.21, 4.15.0-72-generic, x86_64: installed
Çevrimdışı yigitates
  • İleti: 31
Ynt: Ekran kartı güncellemesinden sonra donmaların olması
« Yanıtla #1 : 21 Aralık 2019, 11:36:32 »
Sisteminiz şu an harici ekran kartı üzerinden çalışıyor. Nvidia ayarlarından dahili Intel karta geçtiğinizde de bu sorun oluyor mu?
Düzenleme: Geri dönüş yapılmadığı için konu kilitlendi.
« Son Düzenleme: 02 Ocak 2020, 22:48:34 Gönderen: Butterfly »
