Gönderen Konu: [Çözüldü] Linux Mint 19.3 - GeForce 710M - Nvidia Sürücüsü Kurulamıyor  (Okunma sayısı 9444 defa)
Çevrimdışı dbedel
  • İleti: 40
  • Masaüstü Ortamı: Xfce
Ynt: Linux Mint 19.3 - GeForce 710M - Nvidia Sürücüsü Kurulamıyor
« Yanıtla #30 : 27 Aralık 2019, 19:12:07 »
Cok pardon telefonla kontrol ettigim icin gorememisim. Kurmamistim kurup bir daha deniyecegim
nvidia-prime yükleyince açıldı. Fakat pek bir şey değişmedi ekrandaki kırılmalar hala devam etmekte.
deniz[member=424]deniz[/member]-PC:~$ nvidia-smi
Fri Dec 27 19:19:00 2019
| NVIDIA-SMI 390.129                Driver Version: 390.129                   |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce 710M        Off  | 00000000:01:00.0 N/A |                  N/A |
| N/A   46C    P8    N/A /  N/A |     51MiB /  1985MiB |     N/A      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0                    Not Supported                                       |
deniz[member=424]deniz[/member]-PC:~$ glxinfo | grep render
OpenGL renderer string: GeForce 710M/PCIe/SSE2
    GL_KHR_robustness, GL_KTX_buffer_region, GL_NVX_conditional_render,
    GL_EXT_multisampled_render_to_texture,
    GL_EXT_multisampled_render_to_texture2, GL_EXT_occlusion_query_boolean,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB,
    GL_NV_blend_equation_advanced, GL_NV_conditional_render,
deniz[member=424]deniz[/member]-PC:~$ dpkg -l | grep -E "nvidia|bumblebee|nvidia-prime|fglrx"
ii  libnvidia-cfg1-390:amd64                   390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.129-0ubuntu0~gpu18.04.1                     all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.129-0ubuntu0~gpu18.04.1                     amd64        NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-compute-utils-390                   390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.129-0ubuntu0~gpu18.04.1                     amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8.2                                         all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.0.7                                           all          An applet for NVIDIA Prime
ii  nvidia-settings                            418.56-0ubuntu0~gpu18.04.1                      amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-390                           390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-nvidia-390              390.129-0ubuntu0~gpu18.04.1                     amd64        NVIDIA binary Xorg driver
Nvidia settingten PRIME Profiles sekmesinden, Select the GPU you would lıke to use ---> NVIDIA(performance mode ) seçili
« Son Düzenleme: 27 Aralık 2019, 19:22:17 Gönderen: dbedel »
« Yanıtla #31 : 27 Aralık 2019, 19:29:37 »
Nvidia Prime yırtılma sorunu ile ilgili, forumdaki Nvidia bölümü altında sabitlenmiş konumuz mevcut. Sürücü kurulum sorunu çözüldüyse bu başlığı etiketleyebilirsiniz.
Çevrimdışı dbedel
  • İleti: 40
« Yanıtla #32 : 27 Aralık 2019, 19:32:42 »
Sabahtan beri uğraşıyorsunuz çok ama çok teşekkür ederim
Rica ederiz. Sorunun kaynağı belli olduğuna göre, Linux Mint 19.2 kurduysanız, Linux Mint 19.3'e yükseltebilirsiniz.
[info][Nasıl] Linux Mint 19.x Serisinde Sürüm Yükseltme[/info]
İsterseniz aşağıdaki komutla Xorg sürümünü de yükseltmek mümkün. Bunu tercihen düşünebilirsiniz, mecburi değildir.
sudo apt-get install --install-recommends xserver-xorg-hwe-18.04
