Gönderen Konu: [Çözüldü] Linux Mint 19.3 - NVIDIA Corporation GF117M - Intel + Nvidia Sürücüsü  (Okunma sayısı 3073 defa)
Çevrimdışı Serdar Sert
  • İleti: 70
  • Dağıtım: Mint 19
  • Masaüstü Ortamı: Cinnamon 4.4
Merhaba arkadaşlar.
Mint 19.3 cinnamon kurdum. Ekran kartı ile ilgili sorunları forumdaki yazılarda okudum.
Buradaki yönergelerle ekran kartı kurulumunu yapayım mı?  https://forum.linuxmint.net.tr/index.php?topic=9347.0
serdar@madigudi:~$ inxi -SMGxx
System:
  Host: madigudi Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.4.5 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: SAMSUNG
  product: 300E5EV/300E4EV/270E5EV/270E4EV/2470EV v: 0.1
  serial: <root required> Chassis: type: 9 v: 0.1 serial: <root required>
  Mobo: SAMSUNG model: NP270E5E-X01TR v: FAB1 serial: <root required>
  UEFI [Legacy]: Phoenix v: P07RBK date: 02/14/2014
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0166
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: Samsung Co driver: nouveau v: kernel bus ID: 01:00.0
  chip ID: 10de:1140
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.0.8
serdar@madigudi:~$ glxinfo | grep render
serdar@madigudi:~$ lspci | egrep 'VGA|3D|Display'
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)
serdar@madigudi:~$ xrandr
   1366x768      60.05*+
   1360x768      59.80    59.96
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
serdar@madigudi:~$ cat /etc/X11/xorg.conf
serdar@madigudi:~$ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx|amdgpu'
ii  libdrm-amdgpu1:amd64                       2.4.97-1ubuntu1~18.04.1                         amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  nvidia-prime-applet                        1.0.8                                           all          An applet for NVIDIA Prime
ii  xserver-xorg-video-amdgpu-hwe-18.04        19.0.1-1~18.04.1                                amd64        X.Org X server -- AMDGPU display driver
serdar@madigudi:~$ dkms status
serdar@madigudi:~$
Saygılarımla...
Düzenleme: Konu başlığı
« Son Düzenleme: 27 Aralık 2019, 21:45:56 Gönderen: Serdar Sert »
Ynt: İntel + Nvidia Kurulumu Hk.
« Yanıtla #1 : 27 Aralık 2019, 21:12:53 »
Aşağıdaki komutun çıktısına bakalım öncelikle.
ubuntu-drivers list
Sizin sistemdeki aygıt da buradaki konudaki ile benzer. Çıktıyı bu sbeple istedim.
  • İleti: 70
  • Dağıtım: Mint 19
« Yanıtla #2 : 27 Aralık 2019, 21:26:20 »
Hocam sürücü yöneticisinden lk başta yükselttim ve siyah ekran sorununa takıldım. O yüzden emin olmak istedim.
serdar@madigudi:~$ ubuntu-drivers list
nvidia-340
« Son Düzenleme: 27 Aralık 2019, 21:27:42 Gönderen: Serdar Sert »
Aşağıdaki komutla kurulum yapmayı deneyebilirsiniz. Bağlantıdaki konudaki aygıtla benzer olduğu için sorun çıkacağın sanmıyorum.
sudo apt install nvidia-driver-390 nvidia-settings nvidia-prime
  • İleti: 70
  • Dağıtım: Mint 19
Hocam teşekkürler. Sorunsuz bir şekilde kuruldu ve sorunsuz bir şekilde çalışıyor.
Rica ederiz.
Nvidia GPU etkinken oluşabilen, yırtılma sorununun çözüm adresini biliyorsundur zaten.
  • İleti: 70
  • Dağıtım: Mint 19
Hocam şu ana kadar yırtılma sorunu oluşmadı. Oluşma ihtimaline karşı forumdaki o gönderiye bakmıştım zaten   :)
chip ID: 10de:1140
Nvidia-390 sürücü paketinin "Modaliases" kısmını inceledim. Bu kısımdaki üretici ve marka ID değerlerine göre, Sürücü Yöneticisi uygun sürücüyü belirliyor. Sizin sistemdeki aygıtın ID değerleri bu sürücü de (nidia-390) mevcut değil. Ama Nvidia-340 sürücüsü paketinin "Modaliases" kısmına ekli durumda.
Diğer konudaki aygıt da aynı çipset ID değerine sahip olduğu için, aynı sorun yaşanmış oldu.
Nvidia-390 sürücüsünün, Sürücü Yönetcisinde listelenmemesi bu sebepten kaynaklanıyor olabilir. Belki paket bakımcılarına ulaşan bir bilgiden dolayı böyle yapılmış olabilir. Şu an için nedeni ile ilgili araştırma yapma imkanım bulunmuyor.
Sorun durum sadece Linux Mint'de değil, Ubuntu tabanlı tüm dağıtımlarda aynı maalesef. Belki paketin sonraki sürümlerinde bunu düzeltirler.
Sürücü sorunu çözüldüğüne göre konuyu kilitleyebiliriz.
« Son Düzenleme: 27 Aralık 2019, 22:32:03 Gönderen: Butterfly »
