Gönderen Konu: [Çözüldü] Zekr Ses Çalma Sorunu  (Okunma sayısı 3785 defa)
Çevrimdışı deniztopal
  • İleti: 29
  • Dağıtım: linux mint 19.3
  • İşlemci: intel i7
« : 05 Ocak 2020, 13:06:48 »
Ses oynatmada hata alıyorum sizce neden olabilir?
online/offline her ikisinde de
java.lang.NoClassDefFoundError: org/tritonus/share/sampled/convert/TMatrixFormatConversionProvider
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1016)
at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:174)
at java.base/jdk.internal.loader.BuiltinClassLoader.defineClass(BuiltinClassLoader.java:800)
at java.base/jdk.internal.loader.BuiltinClassLoader.findClassOnClassPathOrNull(BuiltinClassLoader.java:698)
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClassOrNull(BuiltinClassLoader.java:621)
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:579)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Class.java:398)
at java.base/java.util.ServiceLoader$LazyClassPathLookupIterator.nextProviderClass(ServiceLoader.java:1209)
at java.base/java.util.ServiceLoader$LazyClassPathLookupIterator.hasNextService(ServiceLoader.java:1220)
at java.base/java.util.ServiceLoader$LazyClassPathLookupIterator.hasNext(ServiceLoader.java:1264)
at java.base/java.util.ServiceLoader$2.hasNext(ServiceLoader.java:1299)
at java.base/java.util.ServiceLoader$3.hasNext(ServiceLoader.java:1384)
at java.desktop/com.sun.media.sound.JSSecurityManager$2.run(JSSecurityManager.java:147)
at java.desktop/com.sun.media.sound.JSSecurityManager$2.run(JSSecurityManager.java:144)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.desktop/com.sun.media.sound.JSSecurityManager.getProviders(JSSecurityManager.java:151)
at java.desktop/com.sun.media.sound.JDK13Services.getProviders(JDK13Services.java:102)
at java.desktop/javax.sound.sampled.AudioSystem.getProviders(AudioSystem.java:1517)
at java.desktop/javax.sound.sampled.AudioSystem.getFormatConversionProviders(AudioSystem.java:1266)
at java.desktop/javax.sound.sampled.AudioSystem.getAudioInputStream(AudioSystem.java:884)
at javazoom.jlgui.basicplayer.BasicPlayer.createLine(Unknown Source)
at javazoom.jlgui.basicplayer.BasicPlayer.initAudioInputStream(Unknown Source)
at javazoom.jlgui.basicplayer.BasicPlayer.open(Unknown Source)
at net.sf.zekr.engine.audio.DefaultPlayerController.open(DefaultPlayerController.java:131)
at net.sf.zekr.engine.audio.DefaultPlayerController.open(DefaultPlayerController.java:145)
at net.sf.zekr.ui.AudioPlayerUiController.playerOpenAyaAudio(AudioPlayerUiController.java:249)
at net.sf.zekr.ui.AudioPlayerUiController.playerOpenAyaAudio(AudioPlayerUiController.java:244)
at net.sf.zekr.ui.AudioPlayerUiController.playerTogglePlayPause(AudioPlayerUiController.java:219)
at net.sf.zekr.engine.audio.ui.AudioPlayerForm$13.widgetSelected(AudioPlayerForm.java:719)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at net.sf.zekr.ui.BaseForm.loopEver(BaseForm.java:36)
at net.sf.zekr.ZekrMain.startZekr(ZekrMain.java:63)
at net.sf.zekr.ZekrMain.main(ZekrMain.java:94)
Caused by: java.lang.ClassNotFoundException: org.tritonus.share.sampled.convert.TMatrixFormatConversionProvider
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
... 41 more
« Son Düzenleme: 11 Ocak 2020, 18:14:24 Gönderen: deniztopal »
Ynt: Zekr Ses Çalma Sorunu
« Yanıtla #1 : 05 Ocak 2020, 22:39:01 »
Komutların çıktılarını paylaşın.
sudo update-alternatives --list java
java -version
inxi -S
  • İleti: 29
  • İşlemci: intel i7
« Yanıtla #2 : 11 Ocak 2020, 12:02:59 »
deniz[member=424]deniz[/member]:~$ sudo update-alternatives --list java
[sudo] password for deniz:
/usr/lib/jvm/java-11-openjdk-amd64/bin/java
deniz[member=424]deniz[/member]:~$ java -version
openjdk version "11.0.5" 2019-10-15
OpenJDK Runtime Environment (build 11.0.5+10-post-Ubuntu-0ubuntu1.118.04)
OpenJDK 64-Bit Server VM (build 11.0.5+10-post-Ubuntu-0ubuntu1.118.04, mixed mode, sharing)
deniz[member=424]deniz[/member]:~$ inxi -S
System:
  Host: deniz Kernel: 5.0.0-37-generic x86_64 bits: 64
  Desktop: Cinnamon 4.4.6 Distro: Linux Mint 19.3 Tricia
« Yanıtla #3 : 11 Ocak 2020, 13:28:12 »
Burada bahsedilen işlemleri yapmamışsınız sanırım. Uygulama Java 11 ile sağlıklı çalışmıyor, bu sebeple Java 8 kurulumuna yönlendirmiştim. Sizin sistemde sadece Java 11 kurulu görünüyor.
  • İleti: 29
  • İşlemci: intel i7
« Yanıtla #4 : 11 Ocak 2020, 14:20:03 »
şu şekilde yaptım hiç açılmadı bu sefer
« Yanıtla #5 : 11 Ocak 2020, 15:01:04 »
Lütfen çıktı ve benzerlerini resim olarak paylaşmayınız.
Çalışmadı ama hiç mi hata vermedi? zekr.sh dosyasını uçbirimden çalıştırmayı deneyip, çıktıları paylşaın.
  • İleti: 29
  • İşlemci: intel i7
« Yanıtla #6 : 11 Ocak 2020, 16:07:56 »
hiç tepki yok
« Yanıtla #7 : 11 Ocak 2020, 16:24:11 »
Hangi sürümü kurdunuz, portable olanı mı yoksa konuda belirtilen 64 bit sürümü mü? Bir şeyleri hatalı yapıyor olabilirsiniz, kendi denemem ve konudaki dönüşe göre bu şekilde uygulama sorunsuz çalışıyor.
  • İleti: 29
  • İşlemci: intel i7
« Yanıtla #8 : 11 Ocak 2020, 16:52:37 »
64 bit olanı  kurmuştum
« Yanıtla #9 : 11 Ocak 2020, 17:18:56 »
Buradaki paketle kurulum dene bakalım, indirip sağ tık Gdebi ile kurulabilir. Kurulum sonrası menüden aratıp çalıştırılabilir.
  • İleti: 29
  • İşlemci: intel i7
« Yanıtla #10 : 11 Ocak 2020, 17:35:41 »
bu sürümde ses çalışıyor portable dediğiniz miydi bu?
« Yanıtla #11 : 11 Ocak 2020, 17:57:52 »
Hayır bu portable sürüm değil, konudaki anlatıma göre 64 bit sürümdeki dosyalardan paket oluşturdum sadece, tek farkı paket olarak her şeyin hazır olması. Zekr için bir PPA deposu hazırladım. Bu paket de PPA deposuna ait, 32 bit sürümü de ekleyince diğer konudan paylaşırım.
Sorun çözüldüğüne göre; başlığı etiketlerseniz, konuyu kilitleyebiliriz.
