Gönderen Konu: Linux Mint'in Yanına Archman Kurulum Sorunu  (Okunma sayısı 2862 defa)
Çevrimdışı HALDUNHİTAY
  • İleti: 89
  • Dağıtım: LİNUX MİNT
  • Grafik Kartı: Intel Haswell Mobile
  • İşlemci: Intel Core i5-4210U CPU
« : 09 Ocak 2020, 15:29:55 »
Merhaba, bilgisayarımdaki Linux Mint'in yanına gerek usb, gerekse dvd vasıtasıyla Archman kurmak isterken , ekte görüldüğü gibi,ekran takılıp kalıyor ve işlem tamamlanamıyor. Yardımınızı rica eder, iyi günler dilerim.
haldun[member=3507]Haldun[/member]-PU551LD:~$ inxi -Fxxz
System:
  Host: haldun-PU551LD Kernel: 5.0.0-37-generic x86_64 bits: 64
  compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.8 wm: muffin dm: LightDM
Machine:
  Type: Laptop System: ASUSTeK product: PU551LD v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: PU551LD v: 1.0 serial: <filter>
  BIOS: American Megatrends v: PU551LD.211 date: 04/24/2019
Battery:
  ID-1: BAT0 charge: 29.5 Wh condition: 29.7/37.4 Wh (79%) volts: 14.4/14.4
  model: ASUSTeK PU45026 serial: <filter> status: Not charging
CPU:
  Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
  arch: Haswell rev: 1 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19156
  Speed: 798 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 798 2: 798
  3: 800 4: 798
Graphics:
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: ASUSTeK driver: nouveau v: kernel bus ID: 05:00.0
  chip ID: 10de:1140
  Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 19.0.8
Audio:
  Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel v: kernel
  bus ID: 00:03.0 chip ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
  Sound Server: ALSA v: k5.0.0-37-generic
Network:
  vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus ID: 03:00.0
  chip ID: 10ec:8168
  IF: enp3s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 04:00.0
  chip ID: 168c:0036
  IF: wlp4s0 state: up mac: <filter>
Drives:
  Local Storage: total: 465.76 GiB used: 100.76 GiB (21.6%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
  size: 465.76 GiB speed: 6.0 Gb/s serial: <filter>
Partition:
  ID-1: / size: 185.44 GiB used: 45.22 GiB (24.4%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 7.62 GiB used: 268 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors:
  System Temperatures: cpu: 38.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2200
Info:
  Processes: 207 Uptime: 1h 31m Memory: 3.72 GiB used: 1.43 GiB (38.4%)
  Init: systemd v: 237 runlevel: 5 target: graphical.target Compilers:
  gcc: 7.4.0 alt: 7 Shell: bash v: 4.4.20 running in: gnome-terminal
  inxi: 3.0.32
[/img]
« Son Düzenleme: 09 Ocak 2020, 19:12:00 Gönderen: HALDUNHİTAY »
Tek bildiğim, hiçbir şey bilmediğimdir.
Ynt: Linux Mint'in Yanına Archman Kurulum Sorunu
« Yanıtla #1 : 09 Ocak 2020, 17:49:48 »
[member=502]HALDUNHİTAY[/member] , resimi farklı bir alana yükler misiniz? Şu an ki eklenti ile sorun yaşanıyor, bunu farklı bir eklenti ile çözmemiz biraz zaman alabilir.
  • İleti: 89
« Yanıtla #2 : 09 Ocak 2020, 19:12:59 »
[/img]
« Yanıtla #3 : 09 Ocak 2020, 19:21:49 »
Ya indirdiğiniz ISO dosyası ile ilgili ya da ISO dosyasını yazdırdığınız uygulama nedeniyle sorun yaşıyor olabilirsiniz. İndridiğiniz ISO dosyasının sağlamasını yapıp, doğruluğundan emin olunuz. Eğer sağlama sonucu doğru ise, ISO dosyasını farklı bir yazdırma aracı ile yazdırmayı deneyiniz.
  • İleti: 89
« Yanıtla #4 : 10 Ocak 2020, 17:18:49 »
Değerli üstadım, epeyce uğraşmama rağmen bir türlü Archman'ı kuramadım. Onun yerine Debian.10 sürümünü sorunsuz bir şekilde Linux Mint'in yanına kurdum. Tabii ki Linux Mint birinci tercihimdir her zaman. İlginize teşekkür ederim.
