Gönderen Konu: [Çözüldü] Mate Masaüstü - Ekran Görüntüsü Alma Kısayolunun Çalışmaması  (Okunma sayısı 4981 defa)
Çevrimdışı fikretugur
  • İleti: 46
System:
  Host: HP-Pavilion-g6-Notebook-PC Kernel: 5.0.0-37-generic x86_64
  bits: 64 compiler: gcc v: 7.4.0 Desktop: MATE 1.22.2 wm: marco dm: LightDM
Machine:
  Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
  v: 0692120000204610000610100 serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: Hewlett-Packard model: 1670 v: 09.36 serial: <filter>
  BIOS: Hewlett-Packard v: F.30 date: 06/21/2011
CPU:
  Topology: Dual Core model: Intel Core i5-2430M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19156
  Speed: 850 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 823 2: 854
  3: 821 4: 824
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:0116
  Device-2: AMD Seymour [Radeon HD 6400M/7400M Series]
  vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 01:00.0
  chip ID: 1002:6760
  Display: x11 server: X.Org 1.19.6 driver: ati,modesetting,radeon
  unloaded: fbdev,vesa compositor: marco resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.2.1
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20
  Sound Server: ALSA v: k5.0.0-37-generic
Network:
  Device-1: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network
  Adapter
  vendor: Hewlett-Packard driver: wl v: kernel port: 4000 bus ID: 04:00.0
  chip ID: 14e4:4727
  IF: wlp4s0 state: up mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
  chip ID: 10ec:8136
  IF: eno1 state: down mac: <filter>
Drives:
  Local Storage: total: 298.09 GiB used: 40.93 GiB (13.7%)
  ID-1: /dev/sda vendor: Seagate model: ST320LT020-9YG142 size: 298.09 GiB
Partition:
  ID-1: / size: 292.41 GiB used: 40.93 GiB (14.0%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 61.0 C mobo: N/A gpu: radeon temp: 52 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 209 Uptime: 3h 31m Memory: 3.80 GiB used: 1.98 GiB (52.1%)
  v: 4.4.20 running in: mate-terminal inxi: 3.0.32
   Ekran görüntüsü almak için "prt sc" tuşuna basıyorum ama herhangi bir şey olmuyor. Kısayol ayarlarına da baktım bu tuşa atanmış. Tuş mu çalışmıyor acaba diye de düşündüm. Fakat kısayollardan gördüğüm ve öğrendiğim "Pencerenin ekran görüntüsünü al" işlevini "alt+prt sc" gerçekleştirebiliyor. Yani tuş çalışıyor. Ekran görüntüsünü al'ı "alt+prt sc" ile değiştirdim. İşe yarıyor. Sadece "prt sc" komutu çalışmıyor ekran görüntüsü almak için fakat varsayılan ayar olarak da böyle gelmişti bilgisayara. Ne yapabilirim?
« Son Düzenleme: 24 Ocak 2020, 20:31:41 Gönderen: fikretugur »
Aşağıdaki komutu çalıştırmayı deneyiniz.
gsettings reset org.mate.Marco.global-keybindings run-command-screenshot
  • İleti: 46
 Aynı hala, "prt sc"ye basınca herhangi bir komut çalışmıyor
Aşğaıdaki komutu deneyin.
gsettings reset org.mate.Marco.keybinding-commands command-screenshot
  • İleti: 46
 aynı
Klavye Kısayolları => Ekle düğmesi ile açılan pencerede komut kısmına aşağıdaki komutu yazın, istediğiniz bir isim verin ve uygulayın.
mate-screenshot
Sonra bu özel kısayola tıklayarak, istediğiniz klavye kısayolunu atamayı deneyebilirsiniz.
  • İleti: 46
İşe yaradı. Teşekkürler
