Gönderen Konu: [Çözüldü] a4tech pk636ma kamera peynir programında çalışmıyor  (Okunma sayısı 4382 defa)
Çevrimdışı inursal
  • İleti: 21
  • Dağıtım: Rosa
  • Masaüstü Ortamı: Rosa
  • Grafik Kartı: Nvida
  • İşlemci: i3
a4tech pk636ma web kamera peynir programında çalışmıyor. Google whatsapp tan kamera görüntümü alabiliyorum ama peynir programında aygıt bulunmadı hatası veriyor.
ibrahim@AOC:~$ inxi -Fxxz
System:
  Host: AOC Kernel: 5.3.0-40-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
  Desktop: MATE 1.22.2 wm: marco dm: LightDM Distro: Linux Mint 19.3 Tricia
  base: Ubuntu 18.04 bionic
Machine:
  Type: Desktop Mobo: ASUSTeK model: H61M-K v: Rev X.0x serial: <filter>
  BIOS: American Megatrends v: 0801 date: 07/21/2014
CPU:
  Topology: Dual Core model: Intel Core i3-3210 bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25541
  Speed: 1596 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 1597 2: 1596
  3: 1597 4: 1594
Graphics:
  Device-1: NVIDIA G96 [GeForce 9500 GT] driver: nvidia v: 340.108
  bus ID: 01:00.0 chip ID: 10de:0640
  Display: x11 server: X.Org 1.20.5 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa compositor: marco
  resolution: 1440x900~60Hz
  OpenGL: renderer: GeForce 9500 GT/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
  direct render: Yes
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20
  Device-2: Biforst type: USB driver: hid-generic,snd-usb-audio,usbhid
  bus ID: 2-1.2:4 chip ID: 19a8:2036
  Sound Server: ALSA v: k5.3.0-40-generic
Network:
  vendor: ASUSTeK P8 series driver: r8169 v: kernel port: d000
  bus ID: 04:00.0 chip ID: 10ec:8168
  Device-2: Atheros AR9271 802.11n type: USB driver: ath9k_htc
  bus ID: 2-1.1:3 chip ID: 0cf3:9271
  IF: wlxc4e98417eb45 state: up mac: <filter>
Drives:
  Local Storage: total: 1.60 TiB used: 1006.26 GiB (61.5%)
  ID-1: /dev/sda vendor: Samsung model: HD502HJ size: 465.76 GiB
  speed: 3.0 Gb/s serial: <filter> temp: 35 C
  ID-2: /dev/sdb vendor: Samsung model: HD253GJ size: 232.89 GiB
  speed: 3.0 Gb/s serial: <filter> temp: 36 C
  ID-3: /dev/sdc type: USB vendor: Samsung model: HD103SI size: 931.51 GiB
  serial: <filter>
  ID-4: /dev/sdd type: USB vendor: Verbatim model: STORE N GO size: 7.28 GiB
  serial: <filter>
Partition:
  ID-1: / size: 228.23 GiB used: 46.16 GiB (20.2%) fs: ext4 dev: /dev/sdb1
  ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-0
Sensors:
  System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 45 C
  Fan Speeds (RPM): cpu: 0
Info:
  Processes: 225 Uptime: 11m Memory: 5.76 GiB used: 1.26 GiB (21.9%)
  v: 4.4.20 running in: mate-terminal inxi: 3.0.32
« Son Düzenleme: 01 Mart 2020, 10:59:50 Gönderen: inursal »
Ynt: a4tech pk636ma kamera peynir programında çalışmıyor
« Yanıtla #1 : 29 Şubat 2020, 22:27:31 »
Uygulamayı aşağıdaki komutla çalıştırıp, çıktıları paylaşınız. Bakalım bir ipucu elde edebilecek miyiz?
cheese
Çevrimdışı inursal
  • İleti: 21
  • Dağıtım: Rosa
  • İşlemci: i3
« Yanıtla #2 : 29 Şubat 2020, 22:36:05 »
ibrahim@AOC:~$ cheese
(cheese:8251): Gtk-WARNING **: 22:35:30.549: Theme parsing error: cheese.css:7:35: The style property GtkScrollbar:min-slider-length is deprecated and shouldn't be used anymore. It will be removed in a future version
** Message: 22:35:30.601: cheese-application.vala:211: Error during camera setup: Aygıt bulunamadı
(cheese:8251): cheese-CRITICAL **: 22:35:30.619: cheese_camera_device_get_name: assertion 'CHEESE_IS_CAMERA_DEVICE (device)' failed
(cheese:8251): GLib-CRITICAL **: 22:35:30.619: g_variant_new_string: assertion 'string != NULL' failed
(cheese:8251): GLib-CRITICAL **: 22:35:30.619: g_variant_ref_sink: assertion 'value != NULL' failed
(cheese:8251): GLib-GIO-CRITICAL **: 22:35:30.620: g_settings_schema_key_type_check: assertion 'value != NULL' failed
(cheese:8251): GLib-CRITICAL **: 22:35:30.620: g_variant_get_type_string: assertion 'value != NULL' failed
(cheese:8251): GLib-GIO-CRITICAL **: 22:35:30.620: g_settings_set_value: key 'camera' in 'org.gnome.Cheese' expects type 's', but a GVariant of type '(null)' was given
(cheese:8251): GLib-CRITICAL **: 22:35:30.620: g_variant_unref: assertion 'value != NULL' failed
** (cheese:8251): CRITICAL **: 22:35:30.620: cheese_preferences_dialog_setup_resolutions_for_device: assertion 'device != NULL' failed
« Yanıtla #3 : 29 Şubat 2020, 23:30:50 »
Aşağıdaki komutla başlatmak denenebilir.
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l2convert.so cheese
Eğer sorun bu şekilde çözülürse, Cheese uygulamasının başlatıcısını aşağıdaki şekilde düzenleyip, işlemi kalıcı hale getirebilirsiniz.
env LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l2convert.so cheese
Çevrimdışı inursal
  • İleti: 21
  • Dağıtım: Rosa
  • İşlemci: i3
« Yanıtla #4 : 01 Mart 2020, 10:59:36 »
Teşekkür sorun çözüldü.
