Gönderen Konu: Manjaro kurulumu sonrası Nvidia Optimus destkli grafik kartımı kuramıyorum.  (Okunma sayısı 3632 defa)
Çevrimdışı jaws61
  • İleti: 29
  • Dağıtım: Manjaro-Deepin-Mint
  • Masaüstü Ortamı: Cinnamon-Deepin
  • Grafik Kartı: Nvidia optimus Gt 540 M
  • İşlemci: İntel
Azönce Manjaro son sürümünü kurdum. Kurulumu sonrası ekran kartı driverını kurmayı bir türlü beceremedim.
[sedat[member=5978]sedat[/member]-portablepc ~]$ inxi -Fxxz
System:
  Host: sedat-portablepc Kernel: 5.4.23-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 9.2.1 Desktop: Cinnamon 4.4.8 dm: LightDM
  Distro: Manjaro Linux
Machine:
  Type: Laptop System: TOSHIBA product: Portable PC v: Version 1.0
  serial: <filter> Chassis: type: 10 v: Version 1.0 serial: <filter>
  Mobo: TOSHIBA model: Portable PC v: Version A0 serial: <filter>
  BIOS: TOSHIBA v: Version 2.00 date: 11/10/2011
Battery:
  ID-1: BAT1 charge: 31.0 Wh condition: 31.0/47.1 Wh (66%) volts: 11.0/10.8
  model: G71C000AJ410 serial: <filter> status: Full
CPU:
  Topology: Dual Core model: Intel Core i5-2410M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18366
  Speed: 798 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 798 2: 798
  3: 798 4: 798
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Toshiba driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0116
  Device-2: NVIDIA GF108M [GeForce GT 540M] vendor: Toshiba driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:0df4
  Display: x11 server: X.Org 1.20.7 driver: intel,nouveau
  unloaded: modesetting alternate: fbdev,nv,vesa
  resolution: 1366x768~60Hz, 1024x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.3.4
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  vendor: Toshiba driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20
  Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0bea
  Sound Server: ALSA v: k5.4.23-1-MANJARO
Network:
  Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
  v: kernel port: 3000 bus ID: 03:00.0 chip ID: 8086:0083
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: Toshiba driver: r8169 v: kernel port: 2000 bus ID: 04:00.0
  chip ID: 10ec:8168
Drives:
  Local Storage: total: 698.64 GiB used: 7.93 GiB (1.1%)
  ID-1: /dev/sda vendor: Western Digital model: WD7500BPKX-75HPJT0
  size: 698.64 GiB speed: 6.0 Gb/s serial: <filter>
Partition:
  ID-1: / size: 47.81 GiB used: 7.93 GiB (16.6%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 53.0 C mobo: N/A gpu: nouveau temp: 65 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 203 Uptime: 22m Memory: 7.68 GiB used: 1.64 GiB (21.4%)
  Init: systemd v: 242 Compilers: gcc: 9.2.1 Shell: bash v: 5.0.16
  running in: gnome-terminal inxi: 3.0.37
Şu bağlantıdaki https://archman.org/forum/index.php?topic=2151.msg19078#msg19078 manjaro için yazılan kodların daha ilkinde hata verdi.
[sedat[member=5978]sedat[/member]-portablepc ~]$ sudo mhwd -i pci video-hybrid-intel-nvidia-bumblebee
[sudo] password for sedat:
Error: config 'video-hybrid-intel-nvidia-bumblebee' does not exist!
Etkinleştirmeye çalıştığın yapılandırma eksik diyor. Bir ihtimal yapılandırma değişmiştir. Aşağıdaki komutla listelemeyi deneyip, listelenen profillerden uygun olanını uygularsın.
mhwd -l pci
Çevrimdışı jaws61
  • İleti: 29
  • İşlemci: İntel
[sedat[member=5978]sedat[/member]-portablepc ~]$ mhwd -l pci
Error: invalid option: pci
Usage: mhwd [OPTIONS] <config(s)>
  --pci list only pci devices and driver configs
  --usb list only usb devices and driver configs
  -h/--help show help
  -v/--version show version of mhwd
  -f/--force force reinstallation
  -d/--detail show detailed info for -l/-li/-lh
  -l/--list list available configs for devices
  -la/--listall list all driver configs
  -li/--listinstalled list installed driver configs
  -lh/--listhardware list hardware information
  -i/--install <usb/pci> <config(s)> install driver config(s)
  -ic/--installcustom <usb/pci> <path> install custom config(s)
  -r/--remove <usb/pci> <config(s)> remove driver config(s)
  -a/--auto <usb/pci> <free/nonfree> <classid> auto install configs for classid
  --pmcachedir <path> set package manager cache path
  --pmconfig <path> set package manager config
  --pmroot <path> set package manager root
Komutu uyguladım fakat yine hata verdi.
Çıktılara bakarsan nerede hata yaptığımı görebilirsin. Bu durumda komutu aşağıdaki şekilde düzenlemen gerekir. Bu komut sadece, PCI aygıtlarla ilgili sisteme uygun profilleri listeleyecek.
mhwd -l --pci
« Son Düzenleme: 07 Mart 2020, 23:44:51 Gönderen: Butterfly »
Çevrimdışı jaws61
  • İleti: 29
  • İşlemci: İntel
Çıktılar bu şekilde.
[sedat[member=5978]sedat[/member]-portablepc ~]$ mhwd -l --pci
> 0000:01:00.0 (0300:10de:0df4) Display controller nVidia Corporation:
                  NAME               VERSION          FREEDRIVER           TYPE
video-hybrid-intel-nvidia-390xx-bumblebee            2019.10.25               false            PCI
video-hybrid-intel-nvidia-340xx-bumblebee            2019.10.25               false            PCI
    video-nvidia-390xx            2019.10.25               false            PCI
    video-nvidia-340xx            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
     video-modesetting            2020.01.13                true            PCI
            video-vesa            2017.03.12                true            PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:00:02.0 (0300:8086:0116) Display controller Intel Corporation:
Desteklenen profiller listelenmiş, bunlardan birisini uygulamayı deneyebilirsin. Bunun grafik arayüzü yok mu?
Çevrimdışı jaws61
  • İleti: 29
  • İşlemci: İntel
Ayarlar - sürücüler kısmından Nvidia grafik kartı bölümünden yukarıdaki 390x bumblebee yi işaretleyip kurdum. Sonrasınfa yeniden başlatınca cinnamon güvenli kip te başlatmaya zorladı ve masaüstü başlamadı. Daha önceki manjaro sürümlerinde bumblebee kurulumunda hiç sorun olmazken bu sürümde neden böyle oldu hiç anlaöadım. Şu an ne yapmamı öneririsiniz ? Masaüstüne ulaşamıyorum.
TTY uçbiriminde profili kaldırmayı deneyebilirsiniz.
sudo mhwd -r pci video-hybrid-intel-nvidia-390xx-bumblebee
Sorunun kaynağı hakkında bir fikrim yok maalesef. Manjaro ya da Arch için destek veren alanlara sormanız daha uygun olabilir.
