Gönderen Konu: [Çözüldü] Ekran Kartı Sürücüsünü kurduktan sonra gelen uyarı ve sorun.  (Okunma sayısı 7612 defa)
Çevrimdışı cokomayi
  • İleti: 13
  • Dağıtım: Ubuntu 18.04
  • Grafik Kartı: GTX 1060 6GB
Arkadaşlar sürücü yöneticisinden sahipli sürücüyü seçtim ekran kartı için fakat sonra yeniden başlatınca ekran çözünürlüğü küçüldü ve şu uyarı çıktı;
https://i.hizliresim.com/mnyjVF.png
inxi -SMGxx
System:
  Host: erdi-G20CI Kernel: 5.0.0-32-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.4.8 wm: muffin dm: LightDM
Machine:
  Type: Desktop System: ASUSTeK product: G20CI v: 1301
  serial: <root required> Chassis: type: 3 v: 1.0 serial: <root required>
  Mobo: ASUSTeK model: G20CI v: Rev 1.xx serial: <root required>
  UEFI: American Megatrends v: 1301 date: 07/12/2017
Graphics:
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: N/A
  bus ID: 01:00.0 chip ID: 10de:1c03
  Display: x11 server: X.Org 1.20.5 driver: fbdev,nouveau
  unloaded: modesetting,vesa resolution: 1024x768~76Hz
  OpenGL: renderer: llvmpipe (LLVM 9.0 256 bits) v: 3.3 Mesa 19.2.8
  compat-v: 3.1 direct render: Yes
    GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
OpenGL renderer string: llvmpipe (LLVM 9.0, 256 bits)
    GL_MESA_ycbcr_texture, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_MESA_shader_integer_functions, GL_NV_conditional_render,
01:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1)
Screen 0: minimum 1024 x 768, current 1024 x 768, maximum 1024 x 768
default connected primary 1024x768+0+0 0mm x 0mm
   1024x768      76.00*
ii  libdrm-amdgpu1:amd64                       2.4.99-1ubuntu1~18.04.2                     amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                        2.4.99-1ubuntu1~18.04.2                     i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libnvidia-cfg1-435:amd64                   435.21-0ubuntu0.18.04.2                     amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.116-0ubuntu0.18.04.3                    all          Shared files used by the NVIDIA libraries
ii  libnvidia-common-435                       435.21-0ubuntu0.18.04.2                     all          Shared files used by the NVIDIA libraries
rc  libnvidia-compute-390:amd64                390.116-0ubuntu0.18.04.3                    amd64        NVIDIA libcompute package
rc  libnvidia-compute-390:i386                 390.116-0ubuntu0.18.04.3                    i386         NVIDIA libcompute package
ii  libnvidia-compute-435:amd64                435.21-0ubuntu0.18.04.2                     amd64        NVIDIA libcompute package
ii  libnvidia-compute-435:i386                 435.21-0ubuntu0.18.04.2                     i386         NVIDIA libcompute package
ii  libnvidia-decode-435:amd64                 435.21-0ubuntu0.18.04.2                     amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-435:i386                  435.21-0ubuntu0.18.04.2                     i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-435:amd64                 435.21-0ubuntu0.18.04.2                     amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-435:i386                  435.21-0ubuntu0.18.04.2                     i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-435:amd64                   435.21-0ubuntu0.18.04.2                     amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-435:i386                    435.21-0ubuntu0.18.04.2                     i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-435:amd64                     435.21-0ubuntu0.18.04.2                     amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-435:i386                      435.21-0ubuntu0.18.04.2                     i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-435:amd64                   435.21-0ubuntu0.18.04.2                     amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-435:i386                    435.21-0ubuntu0.18.04.2                     i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
rc  nvidia-compute-utils-390                   390.116-0ubuntu0.18.04.3                    amd64        NVIDIA compute utilities
ii  nvidia-compute-utils-435                   435.21-0ubuntu0.18.04.2                     amd64        NVIDIA compute utilities
rc  nvidia-dkms-390                            390.116-0ubuntu0.18.04.3                    amd64        NVIDIA DKMS package
ii  nvidia-dkms-435                            435.21-0ubuntu0.18.04.2                     amd64        NVIDIA DKMS package
ii  nvidia-driver-435                          435.21-0ubuntu0.18.04.2                     amd64        NVIDIA driver metapackage
rc  nvidia-kernel-common-390                   390.116-0ubuntu0.18.04.3                    amd64        Shared files used with the kernel module
ii  nvidia-kernel-common-435                   435.21-0ubuntu0.18.04.2                     amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-435                   435.21-0ubuntu0.18.04.2                     amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8.2                                     all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.0.8                                       all          An applet for NVIDIA Prime
ii  nvidia-settings                            390.77-0ubuntu0.18.04.1                     amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-435                           435.21-0ubuntu0.18.04.2                     amd64        NVIDIA driver support binaries
ii  xserver-xorg-video-amdgpu-hwe-18.04        19.0.1-1ubuntu1~18.04.1                     amd64        X.Org X server -- AMDGPU display driver
ii  xserver-xorg-video-nvidia-435              435.21-0ubuntu0.18.04.2                     amd64        NVIDIA binary Xorg driver
dkms status
nvidia, 435.21, 5.0.0-32-generic, x86_64: installed
« Son Düzenleme: 17 Nisan 2020, 04:06:46 Gönderen: cokomayi »
Çevrimdışı cokomayi
  • İleti: 13
Ek olarak aşağıdaki komutun çıktısını da paylaşın.
mokutil --sb-state
Çevrimdışı cokomayi
  • İleti: 13
mokutil --sb-state
SecureBoot enabled
Secureboot etkinmiş, kapatırsanız sorun düzelir.
Çevrimdışı cokomayi
  • İleti: 13
teşekkür ederim. nasıl kapatabilirim?
Sisteminizdeki BIOS/EFI ayarlarında kapatmak için bir seçenek oluyor. Aşağıdaki resimlerdeki gibi, her sistemde farklı yerlerde olabiliyor.
Çevrimdışı cokomayi
  • İleti: 13
çok teşekkür ederim. benim bios farklı fakat bir şekilde bulurum. umarım sorun düzelir. sağ olun.
Rica ederiz.
Sorun çözülünce başlığı etiketlerseniz, konuyu kilitleyebiliriz.
