Gönderen Konu: [Çözüldü] Amd Dahili + Nvidia Harici GPU - HDMI Çıkışından Harici Ekranı Görmüyor  (Okunma sayısı 11233 defa)
Çevrimdışı yetisbey
  • İleti: 10
Laptopuma HDMI dan taktığım monitör açılmıyor. Display kısmında sadece laptop ekranı var. Windows'da bir problem yaşamıyorum.
System:
  Host: erdo-HP-Pavilion-Gaming-Laptop-15-ec0xxx
  Kernel: 5.3.0-51-generic x86_64 bits: 64 compiler: gcc v: 7.5.0
  Desktop: Cinnamon 4.4.8 wm: muffin 4.4.2 dm: LightDM 1.26.0
Machine:
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx
  v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 86D5 v: 96.15 serial: <filter> UEFI: AMI v: F.01
  date: 08/15/2019
Battery:
  ID-1: BAT0 charge: 48.8 Wh condition: 48.8/48.8 Wh (100%) volts: 12.8/11.6
  model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
  cycles: 439
CPU:
  Topology: Quad Core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen rev: 1 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 33537
  Speed: 1277 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
  1: 1258 2: 1291 3: 1282 4: 1231 5: 1229 6: 1327 7: 1267 8: 1282
Graphics:
  Device-1: NVIDIA vendor: Hewlett-Packard driver: N/A bus ID: 01:00.0
  chip ID: 10de:1f91
  Device-2: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus ID: 05:00.0 chip ID: 1002:15d8
  Display: x11 server: X.Org 1.20.5 driver: amdgpu,ati
  unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD RAVEN (DRM 3.33.0 5.3.0-51-generic LLVM 9.0.1)
  v: 4.5 Mesa 19.2.2 direct render: Yes
Audio:
  Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus ID: 01:00.1 chip ID: 10de:10fa
  Device-2: AMD vendor: Hewlett-Packard driver: N/A bus ID: 05:00.5
  chip ID: 1022:15e2
  Device-3: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
  bus ID: 05:00.6 chip ID: 1022:15e3
  Sound Server: ALSA v: k5.3.0-51-generic
Network:
  Device-1: Realtek vendor: Hewlett-Packard driver: rtw_pci v: N/A
  port: e000 bus ID: 03:00.0 chip ID: 10ec:c822
  IF: wlo1 state: up mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: d000 bus ID: 04:00.0
  chip ID: 10ec:8168
  IF: eno1 state: down mac: <filter>
Drives:
  Local Storage: total: 476.94 GiB used: 30.97 GiB (6.5%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0 scheme: GPT
Partition:
  ID-1: / size: 124.46 GiB used: 30.90 GiB (24.8%) fs: ext4
  dev: /dev/nvme0n1p5
Sensors:
  System Temperatures: cpu: 51.1 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 272 Uptime: 1m Memory: 5.78 GiB used: 1.30 GiB (22.4%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Shell: bash
  v: 4.4.20 running in: terminator inxi: 3.0.32
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1920x1080     60.00*+  40.00
   1680x1050     60.00
   1280x1024     60.00
   1440x900      60.00
   1280x800      60.00
   1280x720      60.00
   1024x768      60.00
   800x600       60.00
   640x480       60.00
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
    GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method,
OpenGL renderer string: AMD RAVEN (DRM 3.33.0, 5.3.0-51-generic, LLVM 9.0.1)
    GL_NVX_gpu_memory_info, GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
    GL_MESA_shader_integer_functions, GL_NV_conditional_render,
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1f91 (rev a1)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso (rev c2)
ii  amdgpu-core                                19.50-967956                                     all          Core meta package for unified amdgpu driver.
ii  amdgpu-dkms                                19.50-967956                                     all          amdgpu driver in DKMS format.
ii  amdgpu-hwe                                 19.50-967956                                     amd64        Meta package to install amdgpu-hwe components.
ii  amdgpu-lib-hwe                             19.50-967956                                     amd64        Meta package to install amdgpu userspace components.
ii  amdgpu-lib32                               19.50-967956                                     amd64        Meta package to support i386 runtime on amd64 architecture
ii  amdgpu-pro-pin                             19.50-967956                                     all          Meta package to pin a specific amdgpu driver version.
ii  gst-omx-amdgpu                             1.0.0.1-967956                                   amd64        GStreamer OpenMAX plugins
ii  libdrm-amdgpu-amdgpu1:amd64                1:2.4.99-967956                                  amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu-amdgpu1:i386                 1:2.4.99-967956                                  i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu-common                       1.0.0-967956                                     all          List of AMD/ATI cards' device IDs, revision IDs and marketing names
ii  libdrm-amdgpu1:amd64                       2.4.99-1ubuntu1~18.04.2                          amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                        2.4.99-1ubuntu1~18.04.2                          i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm2-amdgpu:amd64                       1:2.4.99-967956                                  amd64        Userspace interface to kernel DRM services -- runtime
ii  libdrm2-amdgpu:i386                        1:2.4.99-967956                                  i386         Userspace interface to kernel DRM services -- runtime
ii  libegl1-amdgpu-mesa:amd64                  1:19.2.2-967956                                  amd64        free implementation of the EGL API -- runtime
ii  libegl1-amdgpu-mesa:i386                   1:19.2.2-967956                                  i386         free implementation of the EGL API -- runtime
ii  libegl1-amdgpu-mesa-drivers:amd64          1:19.2.2-967956                                  amd64        free implementation of the EGL API -- hardware drivers
ii  libegl1-amdgpu-mesa-drivers:i386           1:19.2.2-967956                                  i386         free implementation of the EGL API -- hardware drivers
ii  libgbm1-amdgpu:amd64                       1:19.2.2-967956                                  amd64        generic buffer management API -- runtime
ii  libgbm1-amdgpu:i386                        1:19.2.2-967956                                  i386         generic buffer management API -- runtime
ii  libgl1-amdgpu-mesa-dri:amd64               1:19.2.2-967956                                  amd64        free implementation of the OpenGL API -- DRI modules
ii  libgl1-amdgpu-mesa-dri:i386                1:19.2.2-967956                                  i386         free implementation of the OpenGL API -- DRI modules
ii  libgl1-amdgpu-mesa-glx:amd64               1:19.2.2-967956                                  amd64        free implementation of the OpenGL API -- GLX runtime
ii  libgl1-amdgpu-mesa-glx:i386                1:19.2.2-967956                                  i386         free implementation of the OpenGL API -- GLX runtime
ii  libglapi-amdgpu-mesa:amd64                 1:19.2.2-967956                                  amd64        free implementation of the GL API -- shared library
ii  libglapi-amdgpu-mesa:i386                  1:19.2.2-967956                                  i386         free implementation of the GL API -- shared library
ii  libgles1-amdgpu-mesa:amd64                 1:19.2.2-967956                                  amd64        free implementation of the OpenGL|ES 1.x API -- runtime
ii  libgles1-amdgpu-mesa:i386                  1:19.2.2-967956                                  i386         free implementation of the OpenGL|ES 1.x API -- runtime
ii  libgles2-amdgpu-mesa:amd64                 1:19.2.2-967956                                  amd64        free implementation of the OpenGL|ES 2.x API -- runtime
ii  libgles2-amdgpu-mesa:i386                  1:19.2.2-967956                                  i386         free implementation of the OpenGL|ES 2.x API -- runtime
ii  libllvm9.0-amdgpu:amd64                    1:9.0-967956                                     amd64        Modular compiler and toolchain technologies, runtime library
ii  libllvm9.0-amdgpu:i386                     1:9.0-967956                                     i386         Modular compiler and toolchain technologies, runtime library
ii  libnvidia-cfg1-435:amd64                   435.21-0ubuntu0.18.04.2                          amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-435                       435.21-0ubuntu0.18.04.2                          all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-435:amd64                435.21-0ubuntu0.18.04.2                          amd64        NVIDIA libcompute package
ii  libnvidia-compute-435:i386                 435.21-0ubuntu0.18.04.2                          i386         NVIDIA libcompute package
ii  libnvidia-decode-435:amd64                 435.21-0ubuntu0.18.04.2                          amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-435:i386                  435.21-0ubuntu0.18.04.2                          i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-435:amd64                 435.21-0ubuntu0.18.04.2                          amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-435:i386                  435.21-0ubuntu0.18.04.2                          i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-435:amd64                   435.21-0ubuntu0.18.04.2                          amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-435:i386                    435.21-0ubuntu0.18.04.2                          i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-435:amd64                     435.21-0ubuntu0.18.04.2                          amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-435:i386                      435.21-0ubuntu0.18.04.2                          i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-435:amd64                   435.21-0ubuntu0.18.04.2                          amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-435:i386                    435.21-0ubuntu0.18.04.2                          i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libosmesa6-amdgpu:amd64                    1:19.2.2-967956                                  amd64        Mesa Off-screen rendering extension
ii  libosmesa6-amdgpu:i386                     1:19.2.2-967956                                  i386         Mesa Off-screen rendering extension
ii  libwayland-amdgpu-client0:amd64            1.15.0-967956                                    amd64        wayland compositor infrastructure - client library
ii  libwayland-amdgpu-client0:i386             1.15.0-967956                                    i386         wayland compositor infrastructure - client library
ii  libwayland-amdgpu-egl1:amd64               1.15.0-967956                                    amd64        wayland compositor infrastructure - cursor library
ii  libwayland-amdgpu-egl1:i386                1.15.0-967956                                    i386         wayland compositor infrastructure - cursor library
ii  libwayland-amdgpu-server0:amd64            1.15.0-967956                                    amd64        wayland compositor infrastructure - server library
ii  libwayland-amdgpu-server0:i386             1.15.0-967956                                    i386         wayland compositor infrastructure - server library
ii  libxatracker2-amdgpu:amd64                 1:19.2.2-967956                                  amd64        X acceleration library -- runtime
ii  libxatracker2-amdgpu:i386                  1:19.2.2-967956                                  i386         X acceleration library -- runtime
ii  mesa-amdgpu-omx-drivers:amd64              1:19.2.2-967956                                  amd64        Mesa OpenMAX video drivers
ii  mesa-amdgpu-va-drivers:amd64               1:19.2.2-967956                                  amd64        Mesa VA-API video acceleration drivers
ii  mesa-amdgpu-va-drivers:i386                1:19.2.2-967956                                  i386         Mesa VA-API video acceleration drivers
ii  mesa-amdgpu-vdpau-drivers:amd64            1:19.2.2-967956                                  amd64        Mesa VDPAU video acceleration drivers
ii  mesa-amdgpu-vdpau-drivers:i386             1:19.2.2-967956                                  i386         Mesa VDPAU video acceleration drivers
ii  nvidia-compute-utils-435                   435.21-0ubuntu0.18.04.2                          amd64        NVIDIA compute utilities
ii  nvidia-dkms-435                            435.21-0ubuntu0.18.04.2                          amd64        NVIDIA DKMS package
ii  nvidia-driver-435                          435.21-0ubuntu0.18.04.2                          amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-435                   435.21-0ubuntu0.18.04.2                          amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-435                   435.21-0ubuntu0.18.04.2                          amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.8.2                                          all          Tools to enable NVIDIA's Prime
ii  nvidia-settings                            440.44-0ubuntu0.18.04.1                          amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-435                           435.21-0ubuntu0.18.04.2                          amd64        NVIDIA driver support binaries
ii  xserver-xorg-hwe-amdgpu-video-amdgpu       1:19.0.1-967956                                  amd64        X.Org X server -- AMD/ATI Radeon display driver
ii  xserver-xorg-video-amdgpu-hwe-18.04        19.0.1-1ubuntu1~18.04.1                          amd64        X.Org X server -- AMDGPU display driver
ii  xserver-xorg-video-nvidia-435              435.21-0ubuntu0.18.04.2                          amd64        NVIDIA binary Xorg driver
amdgpu, 19.50-967956: added
nvidia, 435.21, 5.3.0-46-generic, x86_64: installed
nvidia, 435.21, 5.3.0-51-generic, x86_64: installed
Düzenleme: Konu başlığı
« Son Düzenleme: 17 Mayıs 2020, 23:22:32 Gönderen: yetisbey »
Ynt: HDMI Çıkışından Harici Ekranı Görmüyor
« Yanıtla #1 : 16 Mayıs 2020, 14:34:08 »
Aşağıdaki komutun çıktısını, HDMI çıkışa ekran takılıyken alıp paylaşınız.
xrandr --verbose
Birde, sistemde hem Nvidia hem de AMD GPU görünüyor. Bu klasik sistemlrden biraz farklı sanırım. Sistem özellikleri hakkında biraz daha bilgi paylaşınız. Hangi GPU dahili, hangisi harici?
« Son Düzenleme: 16 Mayıs 2020, 14:35:37 Gönderen: Butterfly »
Çevrimdışı yetisbey
  • İleti: 10
« Yanıtla #2 : 16 Mayıs 2020, 15:46:50 »
Dahili ekran kartı AMD harici NVIDIA
eDP connected primary 1920x1080+0+0 (0x56) normal (normal left inverted right x axis y axis) 344mm x 193mm
Identifier: 0x53
Timestamp:  12197
Subpixel:   unknown
Gamma:      1.0:1.1:1.2
Brightness: 1.0
Clones:
CRTC:       0
CRTCs:      0 1 2 3
Transform:  1.000000 0.000000 0.000000
            0.000000 1.000000 0.000000
            0.000000 0.000000 1.000000
           filter:
EDID:
00ffffffffffff000daef51500000000
2e1b0104952213780228659759548e27
1e505400000001010101010101010101
010101010101b23b804a71383440503c
680058c11000001ab23b804a71386a42
503c680058c11000001a000000000000
00000000000000000000000000000002
000c44ff0b3c6e0f11206e0000000055
GAMMA_LUT_SIZE: 4096
range: (0, -1)
DEGAMMA_LUT_SIZE: 4096
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
supported: off, on, auto
vrr_capable: 0
range: (0, 1)
abm level: 0
range: (0, 4)
max bpc: 8
range: (8, 16)
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
scaling mode: None
supported: None, Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 64
supported: 64
non-desktop: 0
range: (0, 1)
  1920x1080 (0x56) 152.820MHz +HSync -VSync *current +preferred
        h: width  1920 start 2000 end 2060 total 2250 skew    0 clock  67.92KHz
        v: height 1080 start 1086 end 1094 total 1132           clock  60.00Hz
  1920x1080 (0x57) 152.820MHz +HSync -VSync
        v: height 1080 start 1086 end 1094 total 1698           clock  40.00Hz
  1680x1050 (0x58) 152.820MHz +HSync -VSync
        h: width  1680 start 2000 end 2060 total 2250 skew    0 clock  67.92KHz
        v: height 1050 start 1086 end 1094 total 1132           clock  60.00Hz
  1280x1024 (0x59) 152.820MHz +HSync -VSync
        h: width  1280 start 2000 end 2060 total 2250 skew    0 clock  67.92KHz
        v: height 1024 start 1086 end 1094 total 1132           clock  60.00Hz
  1440x900 (0x5a) 152.820MHz +HSync -VSync
        h: width  1440 start 2000 end 2060 total 2250 skew    0 clock  67.92KHz
        v: height  900 start 1086 end 1094 total 1132           clock  60.00Hz
  1280x800 (0x5b) 152.820MHz +HSync -VSync
        v: height  800 start 1086 end 1094 total 1132           clock  60.00Hz
  1280x720 (0x5c) 152.820MHz +HSync -VSync
        v: height  720 start 1086 end 1094 total 1132           clock  60.00Hz
  1024x768 (0x5d) 152.820MHz +HSync -VSync
        h: width  1024 start 2000 end 2060 total 2250 skew    0 clock  67.92KHz
        v: height  768 start 1086 end 1094 total 1132           clock  60.00Hz
  800x600 (0x5e) 152.820MHz +HSync -VSync
        h: width   800 start 2000 end 2060 total 2250 skew    0 clock  67.92KHz
        v: height  600 start 1086 end 1094 total 1132           clock  60.00Hz
  640x480 (0x5f) 152.820MHz +HSync -VSync
        h: width   640 start 2000 end 2060 total 2250 skew    0 clock  67.92KHz
        v: height  480 start 1086 end 1094 total 1132           clock  60.00Hz
Identifier: 0x54
Timestamp:  12197
Subpixel:   unknown
Clones:
CRTCs:      0 1 2 3
           filter:
range: (0, -1)
range: (0, -1)
GAMMA_LUT: 0
range: (0, 65535)
CTM: 0
DEGAMMA_LUT: 0
range: (0, 65535)
TearFree: auto
vrr_capable: 0
range: (0, 1)
max bpc: 8
range: (8, 16)
range: (0, 128)
range: (0, 128)
underscan: off
scaling mode: None
link-status: Good
CONNECTOR_ID: 69
supported: 69
non-desktop: 0
range: (0, 1)
« Yanıtla #3 : 16 Mayıs 2020, 16:47:59 »
Böyle bir sistemle ilk defa karşılaştım. Sanırım Ryzen+Nvidia GPU'lu bir sistem bu.
HDMI çıkışı Nvidia GPU üzerinden olabilir mi? Bu konuda bilginiz var mı?
Ayrıca Nvidia sürücüsünü kurmuşsunuz ama, sanırım BIOS/EFI ayarlarından secureboot özelliğini kapatmamışsınız. Öncelikle secureboot'u kapatmayı dener misiniz?
Çevrimdışı yetisbey
  • İleti: 10
« Yanıtla #4 : 16 Mayıs 2020, 16:59:06 »
HDMI çıkışının hangisi üzerinden olduğunu bilmiyorum.
Secureboot'u kapattım sorun çözülmedi.
« Yanıtla #5 : 16 Mayıs 2020, 18:07:04 »
Burada AMD ve Nvidia GPU arasında geçiş için bir proje hazırlanmış. İsterseniz, bunun yardımıyla Nvidia GPU'yu etkinleştirmeyi deneyebiliriz. Bir sorun yaşanması ihtimaline karşı, sisteminizi Timeshift ile farklı bir disk bölümüne yedeklemenizi öneririz. Böylece sorun yaşandığında, Timeshift ile sistemi eski haline getirebilirsiniz. Bu süreçte elinizin altında, sistemi kurduğunuz çalışan DVD/USB olmasını da tedbiren öneriyoruz. Geri dönüşünüze göre öneri sunmayı deneyelim.
« Son Düzenleme: 16 Mayıs 2020, 18:09:31 Gönderen: Butterfly »
Çevrimdışı yetisbey
  • İleti: 10
« Yanıtla #6 : 16 Mayıs 2020, 19:23:55 »
Bununlada olmadı.
Ben daha önce nvidia driverlarını silmiştim. Bu sefer monitoru görüyordu displayde fakat monitor de renli çizgiler vardı sadece mouse cursoru görebiliyordum.
« Yanıtla #7 : 16 Mayıs 2020, 19:34:32 »
Ben sizden bir şey uygulamanızı istemedim. "Eğer istiyorsanız, bağlantısını verdiğim projeyi için yönlendirme yapalım" dedim sadece. Bir önceki mesajımı inceleyip dönüş yapınız. Uygusa, öncelikle mesajımda bahsettiğim hususları uygulayınız. Ardından bağlantısını verdiğim proje için yönlendirelim.
Çevrimdışı yetisbey
  • İleti: 10
« Yanıtla #8 : 16 Mayıs 2020, 19:52:13 »
Peki dediğiniz gibi olsun ne yapmamız gerekiyor.
« Yanıtla #9 : 16 Mayıs 2020, 20:07:28 »
Bunlarla ilgili ne yaptınız? Önceki mesajımda belirtmiştim, bu hususla ilgili geri dönüş yapmanızı.
Çevrimdışı yetisbey
  • İleti: 10
« Yanıtla #10 : 17 Mayıs 2020, 00:24:04 »
Hallettim onlarıda.
« Yanıtla #11 : 17 Mayıs 2020, 00:54:28 »
Tamamdır, bunları kurulu sistemde sorun oluşma ihtimaline karşı tedbiren yaptırdım. Çünkü bu projeyi daha önce deneme imkanım olmadı.
Öncelikle kurulu değilse, Nvidia sürücüsünün kurunuz ve sistemi yeniden başlatınız.
Sistemi yeniden başlattıktan sonra, aşağıdaki komutla git ve acpi-call-dkms paketlerini kurunuz.
sudo apt install git acpi-call-dkms
Aşağıdaki komutlarla, gerekli dizinleri oluşturunuz.
sudo mkdir -p /etc/X11/xorg.conf.d/
sudo mkdir -p /etc/modules-load.d/
Sonra aşağıdaki komutlarla, github deposundaki projeyi sisteminize kurmayı deneyiniz.
git clone https://github.com/dglt1/optimus-switch-amd
cd optimus-switch-amd
chmod +x ./install.sh
sudo sh ./install.sh
En sonra olarak aşağıdaki komutu uçbirimde çalıştırıp, Nvidia GPU'nun etkinleşmesini sağlamayı deneyiniz. Bu komuttan sonra sistemi yeniden başlatınız.
sudo set-nvidia.sh
Sistemi yeniden başlattıktan sonra, aşağıdaki komutla sürücü durumunu kontrol ediniz. Teyit için komutun çıktısını paylaşırsınız.
inxi -Gxx
Tekrar dahili AMD GPU'nun etkin olmasını isterseniz, aşağıdaki komutu çalıştırıp sistemi yeniden başlatmanız gerekecek.
sudo set-amd.sh
Düzenleme: konudaki geri dönüşe istinaden, dizin oluşturma aşaması eklendi.
« Son Düzenleme: 18 Mayıs 2020, 00:30:10 Gönderen: Butterfly »
Çevrimdışı yetisbey
  • İleti: 10
« Yanıtla #12 : 17 Mayıs 2020, 04:13:54 »
Montor hala gelmedi.
Graphics:
  Device-1: NVIDIA vendor: Hewlett-Packard driver: nvidia v: 440.59
  bus ID: 01:00.0 chip ID: 10de:1f91
  unloaded: fbdev,modesetting,nouveau,nvidia,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: AMD RAVEN (DRM 3.33.0 5.3.0-51-generic LLVM 9.0.0)
  v: 4.5 Mesa 19.2.8 direct render: Yes
« Yanıtla #13 : 17 Mayıs 2020, 12:24:00 »
Şu an AMD GPU etkin görünüyor, aşağıdaki komutların çıktısını paylaşınız.
sudo set-nvidia.sh
ls /etc/X11/xorg.conf.d/*
ls /usr/local/bin/*optimus*
Çevrimdışı yetisbey
  • İleti: 10
« Yanıtla #14 : 17 Mayıs 2020, 16:30:17 »
sudo set-nvidia.sh
Removing amd only mode setup......
Setting nvidia prime mode.......
cp: cannot create regular file '/etc/X11/xorg.conf.d/99-nvidia.conf': No such file or directory
Done! After reboot you will be using nvidia prime mode.
ls: cannot access '/etc/X11/xorg.conf.d/*': No such file or directory
/usr/local/bin/optimus.sh
