Gönderen Konu: [Çözüldü] Çöp klasöründeki dosyalar kilitli silinmiyor  (Okunma sayısı 2408 defa)
Çevrimdışı inursal
  • İleti: 21
  • Dağıtım: Rosa
  • Masaüstü Ortamı: Rosa
  • Grafik Kartı: Nvida
  • İşlemci: i3
Çöp klasöründeki dosyalarda kilit işareti var. Çöpü boşalt komutu verseniz bile boşaltmıyor. Nasıl yapılır?
ibrahim[member=1691]ibrahim[/member]-Linuxmint19:~$ inxi -Fxxz
System:
  Host: ibrahim-Linuxmint19 Kernel: 5.3.0-53-generic x86_64 bits: 64
  compiler: gcc v: 7.5.0 Desktop: MATE 1.22.2 wm: marco dm: LightDM
Machine:
  Type: Desktop Mobo: ASUSTeK model: H61M-K v: Rev X.0x serial: <filter>
  BIOS: American Megatrends v: 0801 date: 07/21/2014
CPU:
  Topology: Dual Core model: Intel Core i3-3210 bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25542
  Speed: 1597 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 1596 2: 1597
  3: 1596 4: 1599
Graphics:
  Device-1: NVIDIA G96 [GeForce 9500 GT] driver: nvidia v: 340.108
  bus ID: 01:00.0 chip ID: 10de:0640
  Display: x11 server: X.Org 1.20.5 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa compositor: marco
  resolution: 1440x900~60Hz
  OpenGL: renderer: GeForce 9500 GT/PCIe/SSE2 v: 3.3.0 NVIDIA 340.108
  direct render: Yes
Audio:
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1c20
  Device-2: Biforst type: USB driver: hid-generic,snd-usb-audio,usbhid
  bus ID: 2-1.1:3 chip ID: 19a8:2036
  Sound Server: ALSA v: k5.3.0-53-generic
Network:
  vendor: ASUSTeK P8 series driver: r8169 v: kernel port: d000
  bus ID: 04:00.0 chip ID: 10ec:8168
  Device-2: Atheros AR9271 802.11n type: USB driver: ath9k_htc
  bus ID: 2-1.4:8 chip ID: 0cf3:9271
  IF: wlxc4e98417eb45 state: up mac: <filter>
Drives:
  Local Storage: total: 1.65 TiB used: 1008.51 GiB (59.6%)
  ID-1: /dev/sda vendor: Samsung model: HD502HJ size: 465.76 GiB
  speed: 3.0 Gb/s serial: <filter> temp: 38 C
  ID-2: /dev/sdb vendor: Samsung model: HD253GJ size: 232.89 GiB
  speed: 3.0 Gb/s serial: <filter> temp: 39 C
  ID-3: /dev/sdc type: USB vendor: Generic model: Generic size: 62.50 GiB
  serial: <filter>
  ID-4: /dev/sdd type: USB vendor: Samsung model: HD103SI size: 931.51 GiB
  serial: <filter>
Partition:
  ID-1: / size: 228.23 GiB used: 31.28 GiB (13.7%) fs: ext4 dev: /dev/sdb1
Sensors:
  System Temperatures: cpu: 54.0 C mobo: N/A gpu: nvidia temp: 46 C
  Fan Speeds (RPM): cpu: 0
Info:
  Processes: 233 Uptime: 9h 49m Memory: 5.76 GiB used: 1.87 GiB (32.4%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc: 7.5.0 alt: 7 Shell: bash
  v: 4.4.20 running in: mate-terminal inxi: 3.0.32
Düzenleme: Kod etiketi => İletilerde code Etiketi Kullanımı
« Son Düzenleme: 03 Haziran 2020, 08:54:07 Gönderen: inursal »
Ynt: Çöp klasöründeki dosyalar kilitli silinmiyor
« Yanıtla #1 : 02 Haziran 2020, 23:01:04 »
Aşağıdaki komutla, kullanıcının çöp dizinini silmeyi dener misiniz?
sudo rm -rf ~/.local/share/Trash
Çevrimdışı inursal
  • İleti: 21
  • Dağıtım: Rosa
  • İşlemci: i3
« Yanıtla #2 : 03 Haziran 2020, 08:52:14 »
Teşekkür, çözüldü
Ynt: [Çözüldü] Çöp klasöründeki dosyalar kilitli silinmiyor
« Yanıtla #3 : 03 Haziran 2020, 13:02:19 »
Rica ederiz.
