Gönderen Konu: [Çözüldü] Firefox youtube videosu oynatmama sorunu  (Okunma sayısı 11417 defa)
Çevrimdışı green
  • İleti: 54
  • Dağıtım: linux mint 20
  • Grafik Kartı: r5 m230
  • İşlemci: a6-6310
« : 26 Haziran 2020, 19:16:27 »
Firefox youtube'da video oynatmıyor. her zaman oynatırken birden bu sorun oluştu. Başka siterlerde problem yok. Acaba sorun ne olabilir?
tek eklenti adguard reklam engelleyici
System:
  Host: greenwolf Kernel: 5.3.0-28-generic x86_64 bits: 64
  Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
Machine:
  Type: Portable System: Dell product: Inspiron 3541 v: N/A
  serial: <root required>
  Mobo: Dell model: Inspiron 3541 v: A07 serial: <root required> UEFI: Dell
  v: A07 date: 11/27/2015
Battery:
  ID-1: BAT0 charge: 6.1 Wh condition: 6.1/41.4 Wh (15%)
CPU:
  Topology: Quad Core model: AMD A6-6310 APU with AMD Radeon R4 Graphics
  bits: 64 type: MCP L2 cache: 2048 KiB
  Speed: 1158 MHz min/max: 1000/1800 MHz Core speeds (MHz): 1: 1080 2: 1082
  3: 1090 4: 1051
Graphics:
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] driver: radeon v: kernel
  Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] driver: radeon v: kernel
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.3.0-28-generic LLVM 9.0.0)
  v: 4.5 Mesa 19.2.8
Audio:
  Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel
  Device-2: AMD FCH Azalia driver: snd_hda_intel
  Sound Server: ALSA v: k5.3.0-28-generic
Network:
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: enp2s0 state: down mac: 34:e6:d7:fe:67:87
  Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
  driver: ath9k
  IF: wlp3s0 state: up mac: 4c:bb:58:45:08:b6
  Device-3: Atheros type: USB driver: btusb
Drives:
  Local Storage: total: 465.76 GiB used: 112.47 GiB (24.1%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
Partition:
  ID-1: / size: 196.84 GiB used: 112.45 GiB (57.1%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 50.0 C mobo: 50.0 C
  Fan Speeds (RPM): cpu: 3098
  GPU: device: radeon temp: 46 C device: radeon temp: 50 C
Info:
  Processes: 194 Uptime: 18m Memory: 3.28 GiB used: 1.32 GiB (40.2%)
  Shell: bash inxi: 3.0.32
« Son Düzenleme: 28 Haziran 2020, 19:37:36 Gönderen: green »
Ynt: Firefox youtube videosu oynatmama sorunu
« Yanıtla #1 : 26 Haziran 2020, 19:40:32 »
Kısıtılı mod uyarısı mı veriyor? Ortamı oynatmak için çalma düğmesine tıkladığınızda, tam olarak ne oluyor?
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #2 : 26 Haziran 2020, 20:13:06 »
hocam sayfa açılıyor ama video kısmı bomboş kalıyor. aşağıda resimdeki gibi . operada sorun yok. firefox da başka video sitelerinde de sorun yok.
« Son Düzenleme: 26 Haziran 2020, 20:15:15 Gönderen: green »
« Yanıtla #3 : 26 Haziran 2020, 20:23:02 »
Bağlantıdaki videoyu açınca, bende de "Video kullanılamıyor" yazıyor. Youtube'daki tüm videolarda aynı sorun var mı? Buradaki videoyu seyredebiliyor musunuz?
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #4 : 26 Haziran 2020, 20:36:19 »
hocam linkteki bağlantı da diğer videolar gibi. sayfa açılıyor. yan tarafta önerilen videolar görünüyor. fakat sayfa komple donuyor. video hiç gelmiyor. sorun youtube ile alakalı oldugunu varsaysak operada açıyor.
atmış oldugunuz link sizin pcde çalışıyor mu?
« Yanıtla #5 : 26 Haziran 2020, 20:43:05 »
Paylaştığım bağlantı ben de sorunsuz çalışıyor. Firefox'u kapatıp aşağıdaki komutla uçbirimden başlatın ve Start in Safe Mode seçeneği ile açın. Bu şekilde eklentiler pasifleşecek ve tarayıcı varsayılan olarak çalışacaktır. Bu durumda sonuç ne oluyor?
firefox --safe-mode
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #6 : 26 Haziran 2020, 20:49:09 »
butterfly reis güvenli modda videoları açıyor.
« Yanıtla #7 : 26 Haziran 2020, 20:53:29 »
DNS adresi değiştirmeyi deneyin.
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #8 : 26 Haziran 2020, 21:02:38 »
değişen birşey olmadı.
« Yanıtla #9 : 26 Haziran 2020, 21:14:31 »
DNS değiştirdikten sonra bağlantıyı kapatıp yeniden açtınız mı? Bu husus genelikle gözden kaçıyor. Ayrıca tarayıcıyı da kapatıp yeniden başlatabilirsiniz.
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #10 : 27 Haziran 2020, 13:46:51 »
butteryfly bağlantıyı kapatıp açtım. firefox da kapatıp açtım. sonra olmayınca sistemi yeniden başlattım gene olmadı maalesef. bu sorun adguard ile alakalı olabilir tahminimce ya da youtube ile alakalı olabilir. şimdilik sorunu opera kullanarak bertaraf ediyorum.
« Yanıtla #11 : 27 Haziran 2020, 15:36:05 »
Aşağıdaki komutun çıktısını paylaşır mısınız?
grep "nameserver" /etc/resolv.conf
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #12 : 28 Haziran 2020, 12:07:51 »
nameserver 127.0.0.53
çıktı bu şekilde.
butterfly reis çözümü buldum. sorun adguard reklam engelleyicisi ile alakalı. eklentiyi devre dışı bırakıp firefox'u kapatıp açtıktan sonra tekrar aktif edince düzeldi. uğraştığın için saol.
« Son Düzenleme: 28 Haziran 2020, 19:37:12 Gönderen: green »
Ynt: [Çözüldü] Firefox youtube videosu oynatmama sorunu
« Yanıtla #13 : 28 Haziran 2020, 22:55:51 »
Rica ederiz. Ama sorunu kendi kendinize çözmüş oldunuz.
Bahsettiğiniz eklenti yerine Ublock eklentisini ya da buradaki Hblock betiğini kullanmayı deneyebilirsiniz.
Çevrimdışı green
  • İleti: 54
  • İşlemci: a6-6310
« Yanıtla #14 : 29 Haziran 2020, 12:14:32 »
pek çok eklenti denedim butterfly fakat hepsinde reklam gördüm. adguard kullanmamın sebebi bu eklenti bütün reklamları engelliyor. öneri için saol. iyi günler.
