Gönderen Konu: [Çözüldü] ekranda hafif donma ve takılma sorunu  (Okunma sayısı 5267 defa)
« : 30 Haziran 2020, 10:05:16 »
Arkadaşlar merhabalar,
Bilgisayarıma linux mint 20 kurdum. Ara ara donma ve takılmalar oluyor. Sistem bilgileri aşağıdaki gibidir.
System:
  Kernel: 5.4.0-39-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 4.6.6 Distro: Linux Mint 20 Ulyana
  base: Ubuntu 20.04 focal
Machine:
  Type: Laptop System: HP product: HP Pavilion Laptop 15-cs1xxx
  v: Type1ProductConfigId serial: <filter>
  Mobo: HP model: 84C1 v: 15.21 serial: <filter> UEFI: Insyde v: F.07
  date: 12/11/2018
Battery:
  ID-1: BAT0 charge: 25.2 Wh condition: 32.3/32.3 Wh (100%)
  model: HP Primary status: Charging
CPU:
  Topology: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
  arch: Kaby Lake rev: B L2 cache: 8192 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  bogomips: 31999
  Speed: 2323 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 1142 2: 1099
  3: 1293 4: 1152 5: 1543 6: 1028 7: 1301 8: 1169
Graphics:
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0
  Device-2: NVIDIA GP108M [GeForce MX150] vendor: Hewlett-Packard
  driver: N/A bus ID: 02:00.0
  Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
  resolution: 1920x1080~60Hz, 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.0.4
  direct render: Yes
Audio:
  Device-1: Intel Cannon Point-LP High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1f.3
  Sound Server: ALSA v: k5.4.0-39-generic
Network:
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Hewlett-Packard driver: rtw_pci v: N/A port: 4000 bus ID: 03:00.0
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 04:00.0
  IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 700.52 GiB used: 214.36 GiB (30.6%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 476.94 GiB
  ID-2: /dev/sda type: USB vendor: JMicron Tech model: Generic
RAID:
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 bus ID: 00:17.0
Partition:
  ID-1: / size: 467.96 GiB used: 214.35 GiB (45.8%) fs: ext4
  dev: /dev/nvme0n1p2
Sensors:
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 272 Uptime: 1h 41m Memory: 15.53 GiB used: 3.15 GiB (20.3%)
  Init: systemd runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16
  inxi: 3.0.38
inxi -SMGxx
System:    Host: WS-LIN-40 Kernel: 5.4.0-39-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.6.6 wm: muffin
           dm: LightDM Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Machine:   Type: Laptop System: HP product: HP Pavilion Laptop 15-cs1xxx v: Type1ProductConfigId
           serial: <superuser/root required> Chassis: type: 10 serial: <superuser/root required>
           Mobo: HP model: 84C1 v: 15.21 serial: <superuser/root required> UEFI: Insyde v: F.07 date: 12/11/2018
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
           Device-2: NVIDIA GP108M [GeForce MX150] vendor: Hewlett-Packard driver: N/A bus ID: 02:00.0 chip ID: 10de:1d10
           OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.0.4 direct render: Yes
    GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method,
OpenGL renderer string: Mesa Intel(R) UHD Graphics 620 (WHL GT2)
    GL_NV_conditional_render, GL_NV_depth_clamp,
    GL_NV_compute_shader_derivatives, GL_NV_conditional_render,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
    GL_NV_conditional_render, GL_NV_draw_buffers, GL_NV_fbo_color_attachments,
ndex_uint, GL_OES_fbo_render_mipmap,
mehmet@WS-LIN-40:~$ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (Whiskey Lake)
02:00.0 3D controller: NVIDIA Corporation GP108M [GeForce MX150] (rev a1)
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1920x1080     60.01*+  60.01    59.97    59.96    59.93    40.00
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
HDMI-1 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 477mm x 268mm
   1920x1080     60.00*+  50.00    59.94
   1680x1050     59.88
   1600x900      60.00
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   832x624       74.55
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    72.81    66.67    60.00    59.94
   720x400       70.08
ii  libdrm-amdgpu1:amd64                       2.4.101-2                             amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                        2.4.101-2                             i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libnvidia-cfg1-440:amd64                   440.100-0ubuntu0.20.04.1              amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-440                       440.100-0ubuntu0.20.04.1              all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-440:amd64                440.100-0ubuntu0.20.04.1              amd64        NVIDIA libcompute package
ii  libnvidia-compute-440:i386                 440.100-0ubuntu0.20.04.1              i386         NVIDIA libcompute package
ii  libnvidia-decode-440:amd64                 440.100-0ubuntu0.20.04.1              amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-decode-440:i386                  440.100-0ubuntu0.20.04.1              i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-440:amd64                 440.100-0ubuntu0.20.04.1              amd64        NVENC Video Encoding runtime library
ii  libnvidia-encode-440:i386                  440.100-0ubuntu0.20.04.1              i386         NVENC Video Encoding runtime library
ii  libnvidia-extra-440:amd64                  440.100-0ubuntu0.20.04.1              amd64        Extra libraries for the NVIDIA driver
ii  libnvidia-fbc1-440:amd64                   440.100-0ubuntu0.20.04.1              amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-fbc1-440:i386                    440.100-0ubuntu0.20.04.1              i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-440:amd64                     440.100-0ubuntu0.20.04.1              amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-gl-440:i386                      440.100-0ubuntu0.20.04.1              i386         NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-440:amd64                   440.100-0ubuntu0.20.04.1              amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  libnvidia-ifr1-440:i386                    440.100-0ubuntu0.20.04.1              i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-compute-utils-440                   440.100-0ubuntu0.20.04.1              amd64        NVIDIA compute utilities
ii  nvidia-dkms-440                            440.100-0ubuntu0.20.04.1              amd64        NVIDIA DKMS package
ii  nvidia-driver-440                          440.100-0ubuntu0.20.04.1              amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-440                   440.100-0ubuntu0.20.04.1              amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-440                   440.100-0ubuntu0.20.04.1              amd64        NVIDIA kernel source package
ii  nvidia-prime                               0.8.14                                all          Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                        1.2.1                                 all          An applet for NVIDIA Prime
ii  nvidia-settings                            440.64-0ubuntu1                       amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-440                           440.100-0ubuntu0.20.04.1              amd64        NVIDIA driver support binaries
ii  screen-resolution-extra                    0.18build1                            all          Extension for the nvidia-settings control panel
ii  xserver-xorg-video-amdgpu                  19.1.0-1                              amd64        X.Org X server -- AMDGPU display driver
ii  xserver-xorg-video-nvidia-440              440.100-0ubuntu0.20.04.1              amd64        NVIDIA binary Xorg driver
dkms status
nvidia, 440.100, 5.4.0-39-generic, x86_64: installed
Aşağıda ki komutu çalıştırdım test ediyorum.. Bilgi vereceğim.
echo -e 'Section "Device"\n Identifier "card0"\n Driver "intel"\n Option "AccelMethod" "sna"\n Option "TearFree" "true"\n Option "DRI" "2"\n BusID "PCI:0:2:0"\nEndSection' | sudo tee /usr/share/X11/xorg.conf.d/10-intel.conf
Testimi yaptım, mouse takılma devam ediyor.
Ek bigli: intel gpu yu kullanmaya başladım benzer sorunlar orada da oldu.
« Son Düzenleme: 09 Temmuz 2020, 07:07:21 Gönderen: mehmethanifi »
Ynt: ekranda hafif donma ve takılma sorunu
« Yanıtla #1 : 30 Haziran 2020, 17:39:54 »
Çıktılara göre sistem pil gücünde çalışıyor, fişe takılıyken durumu gözlemleyin ve dönüş yapın.
« Yanıtla #2 : 01 Temmuz 2020, 07:17:52 »
Hocam merhaba,
Genelde fişi takılı çalışıyorum hocam. Durumun oluşturu an ise, fişin takılı olduğu andır.
« Yanıtla #3 : 01 Temmuz 2020, 13:22:51 »
Intel Kabylake/Skylake serisinde Cstate özelliğinden kaynaklı ve çekirdeğin 5.2 ve üstü sürümlerinde görülebilen bir sorun varmış. Çözümü için farklı çekirdek değişkenleri öneriliyor.
Bunun yerine öncelikle aşağıdaki komutlarla UXA hızlandırmayı etkinleştirmeyi ve sistemi yeniden başlatmayı deneyebilirsiniz.
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "uxa"\nEndSection' | sudo tee /usr/share/X11/xorg.conf.d/10-intel.conf
Sistemi yeniden başlattıktan sonra aşağıdaki komutun çıktısında modesetting yerine intel görünmeli.
inxi -Gxx
Eğer sorun bu şekilde çözülmezse çekirdek değişkenleri ya da çekirdek güncellemesi önerebiliriz.
« Yanıtla #4 : 01 Temmuz 2020, 14:04:58 »
inxi -Gxx
Graphics:
  Display: x11 server: X.Org 1.20.8 driver: intel
  direct render: Yes
Hocam şuan da takılma yok gayet iyi.. ama şöyle bir durum oluştu. Ben çift monitör kullanıyorum. Monitörü yansıtma işleminde sorun oluyor.
url alma
« Yanıtla #5 : 01 Temmuz 2020, 14:11:33 »
Bildiğiniz üzere, forumda aynı başlıkta farklı soru ve sorunları konuşmuyoruz. Bununla ilgili yeni bir konu açabilirsiniz.
Bu konu açık kalsın, anlık donma sorunuyla ilgili olarak duruma göre farklı öneriler sunulabilir.
« Yanıtla #6 : 01 Temmuz 2020, 14:33:20 »
Olur hocam ben gözlemleyip son durumu paylaşırım inşaallah. Diğeri için önce bir arama yapayım aynı durumda bir konu yoksa yeni bir başlık oluşturayım.
Ynt: Linux Mint 20 ile bilgisayar arada donuyor
« Yanıtla #7 : 07 Temmuz 2020, 10:51:22 »
Aşğaıdaki komutu uçbirimde çalıştırarak, Intel GPU için UXA hızlandırmayı etkinleştirmeyi deneyebilirsiniz. Ardından sistemi yeniden başlatıp durumu gözlemlersiniz. Olumlu olumsuz geri dönüş yaparsınız.
Eğer sorun çözülmezse, çekirdek yükseltmesi deneyebilriz. Çekirdeğin 5.2 sürümü ve sonrası ile bazı Intel GPU'larda anlık donma sorunları oluşabiliyor. Çekirdeğin daha güncel sürümleri ile bu sorunun büyük ihtimalle çözülmüştür. Linux Mint 19.x altında eski çekirdek sürümleri ile sorun yaşanıp yaşanmadığını bu sebeple gözlemlemenizi istemiştim.
Hocam komut satırından hangi bilgiye istinaden bu komut setini çalıştırmayı öneriyoruz.
« Yanıtla #8 : 08 Temmuz 2020, 23:25:01 »
İşlemci/GPU mikro mimari ailesi (Ivy bridge/Kabylake/Skylake) ve kullanılan sürücüye göre (intel / modesettings) farklı öneriler olabiliyor. Genellikle klasik intel sürücüsü ve uxa hızlandırma en sorunsuzu. Ama başarımı biraz daha düşük.
Kabylake/Skylake serisi için i915.enable_psr=0 değişkeni (farklı değişkenleri de kullanara sorunun etrafından dolaşmak mümkün) anlık donma sorunu çözülebiliyor. Çekirdeğin 5.2 ve üstünde görülebilen bu sorunun, güncel çekirdekler ile çözüldüğü görünüyor. Ama biz aşamalı olarak öneri sunuyoruz. Öncelikle UXA kipi, çözüm olmaz ise çekirdek değişkenleri, en son olarak çekirdek güncellemesini öneriyoruz.
Bu şeklde sorun çözüldü ise, başlığı etiketlerseniz konu kilitlenebilir. Lütfen açılan konulara dönüş yapmayı ihmal etmeyelim.
[okay]Çözülen başlıkların etiketlenmesi hakkında[/okay]
Ynt: [Çözüldü] ekranda hafif donma ve takılma sorunu
« Yanıtla #9 : 09 Temmuz 2020, 07:08:45 »
Hocam yaptığım testlerde sorun göremedim sanırım düzeldi. Bu sebeple konuyu çözümlendi olarak etiketledim. Kilitleyebiliriz.
Teşekkür ederim. :)
