Gönderen Konu: [Çözüldü] Ekran kartı Driverı kurulduktan sonra siyah ekran  (Okunma sayısı 3661 defa)
Çevrimdışı Zeldari
  • İleti: 9
  • Masaüstü Ortamı: Cinnamon 4.6.6
  • Grafik Kartı: Nvidia620m+Intel Corporation 3rd Gen Core processo
  • İşlemci: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
Açılışta gelen hoşgeldin ekranından sürücü yükleyicisinden ekran kartı driverı yükledim sonra yeniden başlattım ama siyah ekran geldi şimdi format attım ne yapmam gerekiyor yine siyah ekran verir diye driver kurmadım, linuxda yeniyim yardımcı olursanız sevinirim
Çıktılar:
emre[member=690]Emre[/member]-300E4C-300E5C-300E7C:~$ inxi -SMGxx
System:
  Host: emre-300E4C-300E5C-300E7C Kernel: 5.4.0-26-generic x86_64 bits: 64
  compiler: gcc v: 9.3.0 Desktop: Cinnamon 4.6.6 wm: muffin dm: LightDM
  Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Machine:
  Type: Laptop System: SAMSUNG product: 300E4C/300E5C/300E7C v: 0.1
  serial: <superuser/root required> Chassis: type: 9 v: 0.1
  Mobo: SAMSUNG model: NP300E5C-S0BTR v: FAB1
  serial: <superuser/root required> UEFI: Phoenix v: P09RAP date: 11/01/2013
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0166
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
  620M/625M/630M/720M]
  vendor: Samsung Co driver: nouveau v: kernel bus ID: 01:00.0
  chip ID: 10de:1140
  Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
  v: 4.2 Mesa 20.0.8 compat-v: 3.0 direct render: Yes
emre[member=690]Emre[/member]-300E4C-300E5C-300E7C:~$ glxinfo | grep render
    GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_OML_swap_method,
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 4000 (IVB GT2)
    GL_NV_compute_shader_derivatives, GL_NV_conditional_render,
    GL_NV_conditional_render, GL_NV_draw_buffers, GL_NV_fbo_color_attachments,
emre[member=690]Emre[/member]-300E4C-300E5C-300E7C:~$ lspci | egrep 'VGA|3D|Display'
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)
emre[member=690]Emre[/member]-300E4C-300E5C-300E7C:~$ xrandr
   1366x768      60.01*+
   1360x768      59.80    59.96
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
emre[member=690]Emre[/member]-300E4C-300E5C-300E7C:~$ cat /etc/X11/xorg.conf
Düzenleme: Kod etiketi
« Son Düzenleme: 28 Temmuz 2020, 18:53:57 Gönderen: Zeldari »
Ynt: Ekran kartı Driverı kurulduktan sonra siyah ekran
« Yanıtla #1 : 28 Temmuz 2020, 13:49:37 »
Komut çıktılarının tamamını paylaşmamışsınız. Lütfen çıktılarda kod etiketi kullanmaya özen gösteriniz.
dkms status
Çevrimdışı Zeldari
  • İleti: 9
« Yanıtla #2 : 28 Temmuz 2020, 15:46:12 »
emre[member=690]Emre[/member]-300E4C-300E5C-300E7C:~$ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx|amdgpu'
ii  libdrm-amdgpu1:amd64                       2.4.101-2                             amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                        2.4.101-2                             i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  nvidia-prime-applet                        1.2.1                                 all          An applet for NVIDIA Prime
ii  xserver-xorg-video-amdgpu                  19.1.0-1                              amd64        X.Org X server -- AMDGPU display driver
diğer komutta hiçbir şey gelmiyor
emre[member=690]Emre[/member]-300E4C-300E5C-300E7C:~$ dkms status
« Son Düzenleme: 28 Temmuz 2020, 16:46:01 Gönderen: Butterfly »
« Yanıtla #3 : 28 Temmuz 2020, 16:47:00 »
Lütfen çıktıları kod etiketi içinde paylaşmaya özen gösteriniz, çıktı paylaşımı ile ilgili konularda nasıl yapılacağı hakkında bilgi mevcut. Farkedeceğiniz üzere bu şekilde hem daha düzenli hem de daha anlaşılır oluyor.
Şu bağlantıya göre kurulum yapabilirsiniz. https://forum.linuxmint.net.tr/index.php?topic=10536.msg64437#msg64437
Ayrıca BIOS/EFI ayarlarından secureboot özelliğini kapatınız.
Çevrimdışı Zeldari
  • İleti: 9
« Yanıtla #4 : 28 Temmuz 2020, 17:45:16 »
Çok teşekür ederim sürücü kuruldu her şey çalışıyor bu ekran kartı yüzünden 3 tane distro değiştirmiştim sonunda çözüldü, kod etiketi için kusura bakmayın yeniyim daha dikkatli olucam
« Yanıtla #5 : 28 Temmuz 2020, 18:32:31 »
Rica ederiz.
Yaşanan sorunun kaynağı paylaştığım bağlantıda mevcut. Bu aygıt için depodan elle Nvidia-390 sürücüsünü kurarsanız sorun yaşamazsınız. Sürücü Yöneticisi hatalı yönlendiriyor.
Başlığı etiketlerseniz, konuyu kilitleyebiliriz.
« Son Düzenleme: 28 Temmuz 2020, 18:54:40 Gönderen: Butterfly »
