Gönderen Konu: Sistem açılışında 4 GB. RAM'ın %35'i kullanılıyor  (Okunma sayısı 7200 defa)
Çevrimdışı zerrebey
  • İleti: 61
  • Dağıtım: linuxmint 20 & LMDE4
  • Grafik Kartı: AMD ATI Radeon HD 5670
  • İşlemci: AMD Phenom(tm) II X4 955 Processor
Sistem açılışında 4 GB. RAM'ın %35'i kullanılıyor, bunu sebebi ne olabilir?
System:    Host: lmde4-ev Kernel: 4.19.0-12-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
           Desktop: Cinnamon 4.6.7 wm: muffin dm: LightDM Distro: LMDE 4 Debbie
           base: Debian 10.2 buster
Machine:   Type: Desktop System: Gigabyte product: GA-MA785GT-UD3H v: N/A serial: <filter>
           Chassis: type: 3 serial: <filter>
           Mobo: Gigabyte model: GA-MA785GT-UD3H serial: <filter> BIOS: Award v: F4
           date: 12/03/2009
Battery:   Device-1: hidpp_battery_0 model: Logitech M505/B605 serial: <filter> charge: 90%
           status: Discharging
CPU:       Topology: Quad Core model: AMD Phenom II X4 955 bits: 64 type: MCP arch: K10 rev: 3
           L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 25715
           Speed: 800 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics:  Device-1: AMD Redwood XT [Radeon HD 5670/5690/5730] vendor: Hightech Information System
           driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:68d8
           Display: x11 server: X.Org 1.20.4 driver: radeon resolution: 1360x768~60Hz
           OpenGL: renderer: AMD REDWOOD (DRM 2.50.0 / 4.19.0-12-amd64 LLVM 7.0.1)
           v: 3.3 Mesa 18.3.6 compat-v: 3.1 direct render: Yes
Audio:     Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1002:4383
           Device-2: AMD Redwood HDMI Audio [Radeon HD 5000 Series]
           vendor: Hightech Information System driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 1002:aa60
           Device-3: Logitech HD Webcam C525 type: USB driver: snd-usb-audio,uvcvideo
           bus ID: 1-6.4:8 chip ID: 046d:0826
           Sound Server: ALSA v: k4.19.0-12-amd64
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
           driver: r8169 v: kernel port: de00 bus ID: 02:00.0 chip ID: 10ec:8168
           Device-2: TP-Link TL-WN822N Version 4 RTL8192EU type: USB driver: rtl8192eu
           bus ID: 1-5:4 chip ID: 2357:0108
           IF: wlxd03745652b55 state: up mac: <filter>
Drives:    Local Storage: total: 689.34 GiB used: 53.16 GiB (7.7%)
           ID-1: /dev/sda vendor: Western Digital model: WDS240G2G0A-00JH30 size: 223.58 GiB
           ID-2: /dev/sdb vendor: Seagate model: ST3500418AS size: 465.76 GiB speed: 3.0 Gb/s
           serial: <filter>
Partition: ID-1: / size: 109.28 GiB used: 53.16 GiB (48.6%) fs: ext4 dev: /dev/sda6
           ID-2: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdb5
Sensors:   System Temperatures: cpu: 71.5 C mobo: N/A gpu: radeon temp: 58 C
           Fan Speeds (RPM): N/A
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/additional-repositories.list
           1: deb http: //ppa.launchpad.net/linuxmint-tr/wireless-ppa/ubuntu bionic main
           Active apt repos in: /etc/apt/sources.list.d/jami-main.list
           1: deb https: //dl.jami.net/ring-nightly/debian_10 ring main
           Active apt repos in: /etc/apt/sources.list.d/megasync.list
           1: deb https: //mega.nz/linux/MEGAsync/Debian_10.0/ ./
           Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
           1: deb http: //packages.linuxmint.com debbie main upstream import backport #id:linuxmint_main
           2: deb https: //deb.debian.org/debian buster main contrib non-free
           3: deb https: //deb.debian.org/debian buster-updates main contrib non-free
           4: deb http: //security.debian.org buster/updates main contrib non-free
           5: deb https: //deb.debian.org/debian buster-backports main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/opera-stable.list
           1: deb https: //deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
           Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
           1: deb [arch=amd64] https: //repo.skype.com/deb stable main
           Active apt repos in: /etc/apt/sources.list.d/vivaldi.list
           1: deb http: //repo.vivaldi.com/stable/deb/ stable main
           Active apt repos in: /etc/apt/sources.list.d/yandex-browser-beta.list
           1: deb [arch=amd64] http: //repo.yandex.ru/yandex-browser/deb beta main
Info:      Processes: 215 Uptime: 3m Memory: 3.85 GiB used: 1.45 GiB (37.6%) Init: systemd v: 241
           runlevel: 5 Compilers: gcc: 8.3.0 alt: 8 Client: Unknown python3.7 client inxi: 3.0.32
Çevrimdışı KT
  • İleti: 87
  • Selamlar..
    • Kagan Tanrisundu
  • Dağıtım: Linux Mint 19.03
  • Masaüstü Ortamı: Cinnamon 4.4.8
  • Grafik Kartı: ASUS RX570 ROG STRIX 8GB GDDR5 OC 256Bit
  • İşlemci: AMD Ryzen 3 1300X Quad-Core Processor × 4
Ynt: Sistem açılışında 4 GB. RAM'ın %35'i kullanılıyor
« Yanıtla #1 : 24 Ekim 2020, 15:29:29 »
Üç birimden;
sudo apt install htop
Yükledikten sonra htop u çalıştır ve rm i işkal eden hangi uygulama ya da program onu bul.
Destek ve yardımlarınız için teşekkür ederim. Saygılarımla..
Çevrimdışı zerrebey
  • İleti: 61
« Yanıtla #2 : 26 Ekim 2020, 14:18:16 »
Skype ve Cinnamon replace gözüküyor en çok.
Çevrimdışı KT
  • İleti: 87
  • Selamlar..
    • Kagan Tanrisundu
« Yanıtla #3 : 26 Ekim 2020, 18:12:33 »
Skype yi kullanacağın zaman çalıştır. Cinnamon gördüğün masa üstüdür. Masa üstü temalar ya da masa sütü uygulamacıklar saatin orada açılan uygulamacıklar rm de yer teşkil eder. Bunlar Cinnamon rm de ki miktarını arttırır. Normal de sistemin açılışı 1 GB tı geçmez. Ayrıca zamanında yüklenmiş ve sonradan kurulumu kaldırılmış uygulamalar kalıntıları kalıyor. Kaldırılan programlar Yazılım kaynaklarından Ek depolardan uzantıları varsa kaldırılmalı! Ayrıca Bakım bölümündeki seçenekler değerlendirilmelidir. Ayrıca yazılım yöneticisinden '' Bleachbit '' yükle ve onla gereksiz bütün dosyaları sildir.
« Yanıtla #4 : 27 Ekim 2020, 01:12:28 »
Skype ne kadar RAM kullanıyormuş? Oturum açılırken otomatik çalışması için ayarladığınız başka uygulamalar da var mı?
Çevrimdışı zerrebey
  • İleti: 61
« Yanıtla #5 : 28 Ekim 2020, 00:45:43 »
Temizleme işlerini yaptım bir miktar faydası oldu %31-32 gibi başladı.
Skype  %6  gözüküyor,
Başlangıç uygulamaları şöyle;
« Yanıtla #6 : 28 Ekim 2020, 00:51:18 »
Skype ve Mega'yı pasifleştirip, oturum açınca durum ne oluyor?
Çevrimdışı zerrebey
  • İleti: 61
« Yanıtla #7 : 28 Ekim 2020, 11:34:56 »
Mega ve Skype çok sık kullandığım uygulamalar , bunları başlangıçta kapatınca mem:%25 oldu. Deneme amaçlı onlar kapalı iken Vivaldi tarayıcı açınca %33' yükseldi.
