Gönderen Konu: [Çözüldü] BleachBit (root) açılmıyor , Linux Mint 20.1 Ulyssa ,masa üstü Xfce 4.16.0 Gün.  (Okunma sayısı 7311 defa)
Çevrimdışı indirdivx1967
  • İleti: 183
  • Grafik Kartı: Device-1: Intel vendor: Acer Incorporated ALI
  • İşlemci: Dual Core model: Intel Celeron N4000 bits: 64 type
Merhaba Linux Mint 20.1 Ulyssa ,masa üstü Xfce 4.16.0 yükseltmesi yaptıktan sonra  BleachBit (root) açılmıyor , BleachBit  açılıyor
[code]
System:    Kernel: 5.8.0-36-generic x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.16.0
           tk: Gtk 3.24.20 wm: xfwm4 dm: LightDM Distro: Linux Mint 20.1 Ulyssa
           base: Ubuntu 20.04 focal
Machine:   Type: Laptop System: eMachines product: eMachines E527 v: V1.06 serial: <filter>
           Mobo: eMachines model: eMachines E527 v: V1.06 serial: <filter> BIOS: eMachines v: 1.06
           date: 04/25/2011
Battery:   ID-1: BAT0 charge: 7.0 Wh condition: 7.0/47.5 Wh (15%) volts: 12.1/10.8
           model: SANYO AS09A31 serial: <filter> status: Full
CPU:       Topology: Dual Core model: Celeron T3300 bits: 64 type: MCP arch: Penryn rev: A
           L2 cache: 1024 KiB
           flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7979
           Speed: 1995 MHz min/max: N/A Core speeds (MHz): 1: 1995 2: 1995
Graphics:  Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Acer Incorporated ALI
           driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:2a42
           Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
           compositor: compton resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG) v: 2.1 Mesa 20.2.6
           direct render: Yes
Audio:     Device-1: Intel 82801I HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
           v: kernel bus ID: 00:1b.0 chip ID: 8086:293e
           Sound Server: ALSA v: k5.8.0-36-generic
Network:   Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Foxconn
           driver: ath9k v: kernel port: 5000 bus ID: 04:00.0 chip ID: 168c:002b
           IF: wlp4s0 state: up mac: <filter>
           Device-2: Qualcomm Atheros AR8132 Fast Ethernet vendor: Acer Incorporated ALI
           driver: atl1c v: kernel port: 1000 bus ID: 05:00.0 chip ID: 1969:1062
           IF: enp5s0 state: down mac: <filter>
Drives:    Local Storage: total: 298.09 GiB used: 21.06 GiB (7.1%)
           ID-1: /dev/sda vendor: Toshiba model: MK3265GSX size: 298.09 GiB speed: 3.0 Gb/s
           serial: <filter>
Partition: ID-1: / size: 291.92 GiB used: 21.06 GiB (7.2%) fs: ext4 dev: /dev/sda5
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0 chip ID: 1d6b:0002
           Device-1: 2-4:3 info: Chicony 1.3M Webcam type: Video driver: uvcvideo rev: 2.0
           chip ID: 04f2:b1d8
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 chip ID: 1d6b:0001
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 chip ID: 1d6b:0001
           Device-2: 4-1:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
           type: Keyboard,Mouse,HID driver: hid-generic,usbhid rev: 2.0 chip ID: 045e:0745
           Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 chip ID: 1d6b:0001
           Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 chip ID: 1d6b:0001
           Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 chip ID: 1d6b:0001
Sensors:   System Temperatures: cpu: 69.0 C mobo: N/A
           Fan Speeds (RPM): N/A
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/kelebek333-xfce-4_16-focal.list
           1: deb http: //ppa.launchpad.net/kelebek333/xfce-4.16/ubuntu focal main
           Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
           1: deb http: //packages.linuxmint.com ulyssa main upstream import backport #id:linuxmint_main
           2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
           3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
           4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ focal partner
           Active apt repos in: /etc/apt/sources.list.d/spotify.list
           1: deb http: //repository.spotify.com stable non-free
Info:      Processes: 160 Uptime: 48m Memory: 3.78 GiB used: 1.44 GiB (38.1%) Init: systemd v: 245
           runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Client: Unknown python3.8 client inxi: 3.0.38
[/code]
« Son Düzenleme: 10 Ocak 2021, 17:03:23 Gönderen: indirdivx1967 »
Aşağıdaki komutu çalıştırıp, oturumu kapatıp açın.
sudo apt install xfce4-whiskermenu-plugin/$(lsb_release -cs)
Oturumu açtıktan sonra, sonucu kontrol edin.
  • İleti: 183
Düzeldi, ama arkasından Günceleme Yöneticisine güncelleme belirdi bunu günceller sem tekrar bozulur değil mi?
Bununla ilgili bir hata kaydı açılmış, ama henüz bir düzeltme mevcut değil. https://gitlab.xfce.org/panel-plugins/xfce4-whiskermenu-plugin/-/issues/32
PPA deposuna sorun yaşanmayan 2.4.6 sürümü, güncel sürüm gibi paketleyerek gönderdim. Güncelleme Yöneticisini yenileyerek bu sürümü kurun. Böylece geçici olarak sorunun etrafından dolaşılmış olur. Sorunu çözen bir düzeltme olursa, güncel sürümü depoya ekleriz.
  • İleti: 183
Daha önce etiketlemiş tim kaldırayım, benim tarafta her şey OK, teşekkür ederim
Etiketi kaldırmaya gerek yok. Sorun bu şekilde çözülmüş oldu. Hatası giderilse, güncel sürümü depoya ekleriz.
Düzenleme: Bu sorun güncellenen paketle birlikte, Whisker menünün 2.5.1 güncel sürümünde de çözüldü.
« Son Düzenleme: 15 Ocak 2021, 15:22:37 Gönderen: Butterfly »
