Gönderen Konu: [Çözüldü] FM 2014 açılmıyor  (Okunma sayısı 9403 defa)
Çevrimdışı noneednick
  • İleti: 43
« : 25 Şubat 2014, 16:42:49 »
Resimdeki hatayı veriyor ve açılmıyor sizce neden olabilir?
Steamde fm 2014 için sistem gereksinimleri:
Minimum:
OS: Ubuntu 12.04 LTS Linux
Processor: Intel Pentium 4, Intel Core AMD Athlon: 1.8GHz+
Memory: 1 GB RAM
Graphics: NVidia GeForce 7300 GT, AMD Radeon HD 2400 Pro, Intel HD 3000/4000: 128MB VRAM
Hard Drive: 3 GB available space
Additional Notes: OpenGL 2.0 compliant
Mint ubuntu tabanlı değil miydi sorun olmaması gerekmez mi?
00:00.0 Host bridge: Intel Corporation 4 Series Chipset DRAM Controller (rev 03)
00:01.0 PCI bridge: Intel Corporation 4 Series Chipset PCI Express Root Port (rev 03)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01)
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
01:00.0 VGA compatible controller: NVIDIA Corporation G94 [GeForce 9600 GT] (rev a1)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03)
04:01.0 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 62)
04:01.1 USB controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 62)
04:01.2 USB controller: VIA Technologies, Inc. USB 2.0 (rev 65)
sadece baştakini çalıştırabildim diğerlerinden çıktı alamadım :/
« Son Düzenleme: 05 Mart 2014, 09:14:45 Gönderen: Ocean »
Ynt: FM 2014 açılmıyor
« Yanıtla #1 : 25 Şubat 2014, 17:19:41 »
Öncelikle aşağıdaki komutları sırasıyla uçbirimde çalıştırıp aldığınız çıktıları paylaşınız.
lspci | egrep 'VGA|3D'
Football Manager 2014 uygulamasının başlatıcı kısayoluna sağ tıklayın ve özellikleri açın. Özellikler alanında Komut (Command) yazan bölümün karşısındaki komutun tamamını koyyalayıp paylaşınız.
Burasını referans olarak unutmamak için ekleyelim.
« Yanıtla #2 : 26 Şubat 2014, 00:29:09 »
Kurulu değilse Sürücü Yöneticisinden Nvidia kapalı kaynak sürücüsünü kurmayı dener misiniz?
Kurulum sonrası aşağıdaki komutların çıktılarını paylaşın ki, kurulum sorunsuz gerçekleşmiş mi kontrol edelim.
(Not: Hata yapmamak için; komutları elle yazmak yerine sırasıyla kopyalayıp sağ tık ile yapıştırmak daha uygun olabilir.)
dpkg -l | grep nvidia
« Son Düzenleme: 26 Şubat 2014, 16:48:26 Gönderen: Butterfly »
  • İleti: 43
« Yanıtla #3 : 26 Şubat 2014, 16:35:42 »
OpenGL vendor string: nouveau
OpenGL renderer string: Gallium 0.4 on NV94
OpenGL version string: 1.4 (3.0 Mesa 9.2.1)
ii  nvidia-319     319.32-0ubun amd64        NVIDIA binary Xorg driver, kernel
rc  nvidia-setting 304.88-0ubun amd64        Tool for configuring the NVIDIA g
ii  nvidia-setting 319.32-0ubun amd64        Tool for configuring the NVIDIA g
nvidia 319 önerilen sürücüyü kullanıyorum.
grep render
grep nvidia
bu iki komutla ilgili herhangi birşey vermedi uçbirim
« Son Düzenleme: 26 Şubat 2014, 16:46:03 Gönderen: Butterfly »
« Yanıtla #4 : 26 Şubat 2014, 16:42:30 »
Komutları elle yazmak yerine kopyalayıp yapıştırmayı denediniz mi? Komutdaki | kısmı küçük L harfi değil çünkü.
Aşağıdaki komutu uçbirimde çalıştırıp xorg.conf ayar dosyasını oluşturmayı deneyiniz. Şu an sürücüler kurulu ama ayar dosyası oluşturulmadığı için sanırım etkin değil.
sudo nvidia-xconfig
Sistemi yeniden başlatınca aşağıdaki komutun çıktısını paylaşınız.
« Son Düzenleme: 26 Şubat 2014, 16:51:05 Gönderen: Butterfly »
  • İleti: 43
« Yanıtla #5 : 26 Şubat 2014, 19:41:31 »
  GL_NV_register_combiners2, GL_NV_shader_buffer_load,
    GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
    GL_NV_texture_expand_normal, GL_NV_texture_multisample,
    GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
    GL_NV_texture_shader3, GL_NV_transform_feedback, GL_NV_vdpau_interop,
    GL_NV_vertex_array_range, GL_NV_vertex_array_range2,
    GL_NV_vertex_buffer_unified_memory, GL_NV_vertex_program,
    GL_NV_vertex_program1_1, GL_NV_vertex_program2,
    GL_NV_vertex_program2_option, GL_NV_vertex_program3, GL_S3_s3tc,
    GL_SGIS_generate_mipmap, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
    GL_SGIX_shadow, GL_SUN_slice_accum
204 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
grep render komutunu kopyalayıp yapıştırıyorum lakin yine de birşey vermiyor. beklemek filan mı gerekiyor vermesi için yada başka bir ayar mı lazım direk alt satıra geçiyor tepki yok başka.
  • İleti: 43
« Yanıtla #6 : 28 Şubat 2014, 21:32:13 »
STEAM_RUNTIME=1 LC_ALL=C %command% kodunu steam üzerinden çalıştırınca sorun çözüldü. yardım ve ilgileriniz için teşekkür ederim :)
Ynt: [Çözüldü] FM 2014 açılmıyor
« Yanıtla #7 : 05 Mart 2014, 09:15:41 »
Sorun çözüldüğüne göre başlığı çözüldü olarak değiştirip konuyu kilitledim.
