Gönderen Konu: LOL Siyah Ekran  (Okunma sayısı 10793 defa)
Çevrimdışı baris748
  • İleti: 6
LOL Siyah Ekran
« : 10 Eylül 2014, 17:25:22 »
İyi günler arkadaşlar oyuna giriyorum ses var fakat görüntü yok?
#baroramo
Çevrimdışı dest
  • İleti: 100
    • Facebook Adresi
  • Dağıtım: Xubuntu 18.04.1
Ynt: LOL Siyah Ekran
« Yanıtla #1 : 10 Eylül 2014, 19:53:14 »
Patchleri bitirdin mi ?
Intel Pentium Dual Core P6200 (3M cache, 2.13 GHz) | 4GB DDR3 | Integrated Intel GMA HD
facebook.com/destfuat
« Yanıtla #2 : 10 Eylül 2014, 23:05:40 »
inxi -Fx
Çevrimdışı dest
  • İleti: 100
    • Facebook Adresi
« Yanıtla #3 : 10 Eylül 2014, 23:41:42 »
Bende de aynı problem baş gösterdi.
Çıktı burda.
fuat@fuat-K52F ~ $ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Core Processor Integrated Graphics Controller (rev 18)
fuat@fuat-K52F ~ $ glxinfo | grep render
OpenGL renderer string: Mesa DRI Intel(R) Ironlake Mobile x86/MMX/SSE2
fuat@fuat-K52F ~ $ inxi -Fx
System:    Host: fuat-K52F Kernel: 3.13.0-24-generic i686 (32 bit, gcc: 4.8.2) Desktop: N/A Distro: Linux Mint 17 Qiana
Machine:   Mobo: ASUSTeK model: K52F version: 1.0 Bios: American Megatrends version: K52F.215 date: 03/09/2011
CPU:       Dual core Intel Core i3 CPU M 370 (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9575.68
           Clock Speeds: 1: 933.00 MHz 2: 933.00 MHz 3: 933.00 MHz 4: 933.00 MHz
Graphics:  Card: Intel Core Processor Integrated Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1360x768@59.8hz
           GLX Renderer: Mesa DRI Intel Ironlake Mobile x86/MMX/SSE2 GLX Version: 2.1 Mesa 10.1.0 Direct Rendering: Yes
Audio:     Card: Intel 5 Series/3400 Series Chipset High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: JMicron JMC250 PCI Express Gigabit Ethernet Controller
           driver: jme ver: 1.0.8 ports: a100 a000 bus-ID: 04:00.5
           IF: eth0 state: down mac: 14:da:e9:5d:83:6b
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 02:00.0
           IF: wlan0 state: up mac: 74:2f:68:74:76:7d
Drives:    HDD Total Size: 320.1GB (3.5% used) 1: id: /dev/sda model: ST9320325AS size: 320.1GB
Partition: ID: / size: 13G used: 11G (88%) fs: ext4 ID: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap
Info:      Processes: 167 Uptime: 7 min Memory: 460.6/1869.8MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
fuat@fuat-K52F ~ $
Oyunu açtığımda Masaüstüm 1024x768 oluyor ve oyunda sadece mause şekil değiştiriyor oyun açılıyor sesler geliyor.  Ama siyah ekran. Sadece mause var oda oyunun simgesi halinde oyuna sesler var ama görüntü yok. Oyundan çıkıncada dediğim gibi masaüstüm 1024x768 oluyor.
Gececi tayfa konusunda birisi oyunun çözünürlüğünü ayarlamamı önerdi ancak oyunun çözünürlüğünü ayarlayamam çünkü girince ayarlayabiliyosun şuan giremiyorumki.
Çevrimdışı dest
  • İleti: 100
    • Facebook Adresi
« Yanıtla #4 : 18 Eylül 2014, 02:58:05 »
Konu güncel. Tekrar mesaj attığım için üzgünüm başka bir yöntemi varsa öğretebilir ve mesajımıda konuyla ilgilenen arkadaşım silebilir :)
Sadece güncel olduğunu belirtmek istedim.
Çevrimdışı Halofalcon
  • İleti: 2
  • Dağıtım: Linux Mint 17
« Yanıtla #5 : 07 Kasım 2014, 21:48:19 »
Öncelikle herkese tekrardan merhabalar;
Bende aynı sorundan sıkıntı yaşamaktayım. Benim donanımlarıma sahip bir kaç kullanıcının bu oyun üzerinde sabit 60fps aldığını duydum. Çeşitli videolar izledim. Ve bende en basit şekilde PlayonLinux programını kullanarak oyunu kurdum. Hiç bir sıkıntı yaşamadım, giriş ekranım,mağaza vb hiç bir şeyde sorun yok sanki Windows üzerinde geziniyor gibiyim panelde. Fakat oyuna girince sadece simsiyah bir ekran alıyorum. İnternetten bazı konuları araştırdım kesin çözümler genellikle ingilizce olduğu için ve bir hata yaptıktan sonra geri dönecek kadar tecrübeli olamadığım için sizlere danışmak istedim. Diğer oyunlarda hiç bir sıkıntı yaşamamaktayım fps kaybı yaşamıyorum.
« Yanıtla #6 : 07 Kasım 2014, 22:47:28 »
Aşağıdaki komut ile winetricks'i kurup,
sudo apt-get install winetricks
sonrasında aşağıdaki komut ile ie8'i yüklemeyi dener misiniz?
winetricks ie8
  • İleti: 2
« Yanıtla #7 : 08 Kasım 2014, 00:22:08 »
Halen aynı ekranı almaktayım. Özel oyun kuruyorum denemek için karakter seçimime kadar her şey normal. Tam oyun başlarken oyuncuların yüklenme ekranı gözükeceğine sadece league of legends mouse iconu gözüküyor simsiyah ekranda yani bir tek mouse icon değişiyor. Oyuna giriyor sesler vb her şey Windows platformundaki gibi normal. Sadece yüklenme ekranından itibaren her şey simsiyah.
Çevrimiçi Danny
« Yanıtla #8 : 08 Kasım 2014, 10:02:10 »
siyah ekran sorunu, oyundan kaynaklanan bir sorun diye biliyorum geçen gün bununla ilgili bir duyuru geçilmişti ve yeni bir patch gelmişti, son gelen patch'dan sonra sorun hala devam ediyor mu ?
