Gönderen Konu: PlayonLinux - Microsoft Office 2010 kurulumu ve Mono  (Okunma sayısı 27248 defa)
Ynt: PlayonLinux - Microsoft Office 2010 kurulumu ve Mono
« Yanıtla #15 : 06 Mart 2014, 21:54:29 »
Uçbirimi açınız ve wine yazınız. Sonra bir boşluk bırakıp kurulum.exe dosyasını uçbirime sürükleyip bırakınız.
wine /kurulum/dosyası/sürükle/bırak
Uçbirimde oluşan komutu çalıştırınız ve aldığınız hata mesajını paylaşınız.
Çevrimdışı varulven
  • İleti: 123
  • non me tenent vincula, non me tenet clavis
  • Dağıtım: Linux Mint 16 Cinnamon Edition 32-Bit
« Yanıtla #16 : 06 Mart 2014, 21:56:51 »
Bu şekilde hocam
fixme:heap:HeapSetInformation 0x230000 0 0x22fce0 4
fixme:advapi:EventRegister {8736922d-e8b2-47eb-8564-23e77e728cf3}, 0x140013a64, 0x1400f2b08, 0x1400f2b00
fixme:heap:HeapSetInformation 0x8cc0000 0 0x22e650 4
fixme:advapi:EventRegister {8736922d-e8b2-47eb-8564-23e77e728cf3}, 0x1800fa454, 0x18050b5b8, 0x18050b5b0
fixme:system:SetProcessDPIAware stub!
fixme:htmlhelp:HtmlHelpW HH case HH_INITIALIZE not handled.
fixme:richedit:REExtendedRegisterClass semi stub
fixme:richedit:ME_HandleMessage EM_SETEDITSTYLE: stub
fixme:richedit:ME_HandleMessage EM_SETBIDIOPTIONS: stub
fixme:msxml:dom_pi_get_attributes created dummy map for <?xml ?>
wine: Call from 0x7f349bcf46d8 to unimplemented function KERNEL32.dll.RtlInstallFunctionTableCallback, aborting
wine: Unhandled exception 0x40000015 in thread 28 at address 0x7f349bcf46d8 (thread 0028), starting debugger...
ulas@orion ~ $ Process of pid=0023 has terminated
No process loaded, cannot execute 'echo Modules:'
Cannot get info on module while no process is loaded
No process loaded, cannot execute 'echo Threads:'
process  tid      prio (all id:s are in hex)
0000000e services.exe
0000001e    0
0000001d    0
0000001c    0
00000016    0
00000014    0
00000010    0
0000000f    0
00000012 winedevice.exe
0000001b    0
00000018    0
00000017    0
00000013    0
00000019 plugplay.exe
00000020    0
0000001f    0
0000001a    0
00000021 explorer.exe
00000022    0
winedbg: Internal crash at 0x7fd722fc6dd8
« Yanıtla #17 : 06 Mart 2014, 22:15:53 »
Aşağıdaki komutu uçbirimde çalıştırıp dotnet20, msxml6 ve corefonts uygulamalarını yükleyiniz.
winetricks dotnet20
winetricks msxml6
winetricks corefonts
Sonra Configure Wine kısayolu ile ayar pencerisini açınız.
Kitaplıklar için yeni öncelik satırına aşağıdakileri yazıp sırasıyla ekleyiniz.
gdiplus
msxml6
riched20
Kitaplıklara eklediğiniz öğeleri sırasıyla seçip Düzenle düğmesine tıklayınız.
Yükleme sırası seçeneğinden hepsi için Doğal (Windows) seçeneğini işaretleyiniz.
Şimdi kurulumu tekrar deneyiniz.
« Son Düzenleme: 06 Mart 2014, 22:28:51 Gönderen: Butterfly »
Çevrimdışı varulven
  • İleti: 123
« Yanıtla #18 : 06 Mart 2014, 22:24:08 »
Hocam dotnet20 de wine da pencere çıktı ve 64 bit sürüme yüklenmez yazdı.
Bu arada sistemim 64 bit petra cinnamon
Yüklemek istediğim ofis professional plus 2010 64-bit
Executing w_do_call dotnet20
Executing load_dotnet20
Executing w_do_call remove_mono
Executing load_remove_mono
Mono does not appear to be installed.
Executing w_do_call fontfix
Executing load_fontfix
Setting Windows version to win2k
Executing winetricks_early_wine regedit C:\windows\Temp\_dotnet20\set-winver.reg
Current wine does not have wine bug 10467, so not applying workaround
Executing mkdir -p /home/ulas/.cache/winetricks/dotnet20
Downloading http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkvantage_en/dotnetfx.exe to /home/ulas/.cache/winetricks/dotnet20
--2014-03-06 22:20:04--  http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkvantage_en/dotnetfx.exe
download.lenovo.com (download.lenovo.com) çözümleniyor... 2.21.40.27
download.lenovo.com (download.lenovo.com)[2.21.40.27]:80 bağlanılıyor... bağlantı kuruldu.
HTTP isteği gönderildi, cevap bekleniyor... 200 OK
Uzunluk: 23510720 (22M) [application/octet-stream]
Kayıt yeri: `dotnetfx.exe'
100%[======================================>] 23.510.720   174KB/s   in 2m 57s s
2014-03-06 22:23:01 (130 KB/s) - `dotnetfx.exe' kaydedildi [23510720/23510720]
Current wine does not have wine bug 30845, so not applying workaround
Executing wine dotnetfx.exe
fixme:advapi:DecryptFileA ("C:\\users\\ulas\\Temp\\IXP000.TMP\\", 00000000): stub
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/p11-kit-trust.so: /usr/lib/i386-linux-gnu/pkcs11/p11-kit-trust.so: paylaşımlı nesne dosyası açılamıyor: Böyle bir dosya ya da dizin yok
fixme:advapi:LsaOpenPolicy ((null),0x33f2f8,0x00000001,0x33f2e4) stub
fixme:advapi:LsaClose (0xcafe) stub
Note: command 'wine dotnetfx.exe' returned status 26.  Aborting.
« Son Düzenleme: 06 Mart 2014, 22:28:20 Gönderen: varulven »
« Yanıtla #19 : 06 Mart 2014, 22:27:04 »
Aşağıdaki komut ile wine kurulum/ayar dizinini siliniz.
rm -rf ~/.wine
Sonra aşağıdaki 32 bit uyumluluk için gerekli komutları çalıştırıp tekrar deneyiniz.
export WINEPREFIX=$HOME/wine32
export WINEARCH=win32
Çevrimdışı varulven
  • İleti: 123
« Yanıtla #20 : 06 Mart 2014, 22:58:57 »
Böyle bir hata verdi hocam :(
« Yanıtla #21 : 06 Mart 2014, 23:09:03 »
Ben hatayı göremiyorum.
Çevrimdışı varulven
  • İleti: 123
« Yanıtla #22 : 06 Mart 2014, 23:15:41 »
Kurulum aşağıdaki hatalar nedeniyle ilerleyemiyor.
Bu kurulumu yüklemek için aşağıdaki işletim sistemlerini çalıştırıyor olmanız gerekir.
Microsoft office 2010 yüklemesi bilgisayarınızda msxml 6.10.1129.0 sürümünün yüklü olmasını gerektirir.
« Yanıtla #23 : 06 Mart 2014, 23:41:54 »
Aşağıdaki komut ile regedit uygulamasını açınız.
regedit
Açılan kayıt düzenleyicide sırasıyla aşağıdaki anahtarları açınız.
HKEY_CLASSES_ROOT => TypeLib => {F5078F18-C551-11D3-89B9-0000F81FE221} => 6.0 => 0 => win32
win32 altında değer %SystemRoot%\System32\msxml6.dll olarak görünüyorsa üstüne çift tıklayıp açarak değeri C:\windows\system32\msxml6.dll olarak değiştirmeyi deneyiniz.
Çevrimdışı varulven
  • İleti: 123
« Yanıtla #24 : 06 Mart 2014, 23:45:45 »
Butterfly Hocam zaten yazdığınız gibi görünüyor. Yani yazmamı istediğiniz gibi. Ayrıca yılmadınız, helal olsun diyorum.
« Yanıtla #25 : 06 Mart 2014, 23:48:21 »
Kitaplıklar aşağıdaki gibi düzenlendi mi?
Çevrimdışı varulven
  • İleti: 123
« Yanıtla #26 : 06 Mart 2014, 23:50:37 »
Evet hocam düzenlendi.
https://forum.winehq.org/viewtopic.php?f=8&t=17789
Şöyle bir başlık var. Setup'ı terminalden çalıştır diyor. Tam anlamış değilim.
« Yanıtla #27 : 06 Mart 2014, 23:54:47 »
Kurulumu yukarıdaki gibi yapıp aldığınız hata mesajını paylaşır mısınız?
Çevrimdışı varulven
  • İleti: 123
« Yanıtla #28 : 06 Mart 2014, 23:58:20 »
Bu şekilde çıktı verdi hocam.
fixme:advapi:RegisterTraceGuidsA (0x1400139d8, 0x1400f2b08, {8736922d-e8b2-47eb-8564-23e77e728cf3}, 1, 0x22fb50, (null), (null), 0x1400f2b08): stub
fixme:advapi:RegisterTraceGuidsA (0x1800fa3c8, 0x18050b5b8, {8736922d-e8b2-47eb-8564-23e77e728cf3}, 1, 0x22e4c0, (null), (null), 0x18050b5b8): stub
err:ole:COMPOBJ_DllList_Add couldn't load in-process dll L"C:\\windows\\system32\\msxml6.dll"
err:ole:create_server class {88d96a05-f192-11d4-a65f-0040963251e5} not registered
fixme:ole:CoGetClassObject CLSCTX_REMOTE_SERVER not supported
err:ole:CoGetClassObject no class object {88d96a05-f192-11d4-a65f-0040963251e5} could be created for context 0x17
« Yanıtla #29 : 07 Mart 2014, 00:04:57 »
WINEARCH=win32 WINEPREFIX=~/.wine32 winecfg
Açılan ayar yöneticisinde aşağıdaki düzenlemeleri yapınız ve değişiklikleri uygulayınız.
Sonra uçbirime WINEPREFIX=~/.wine32 wine yazıp bir boşluk bırakınız. Kurulum dosyasını uçbirime sürükleyip bıraktıktan sonra oluşan komutu çalıştırmayı deneyiniz.
WINEPREFIX=~/.wine32 wine /kurulum/dosyası/sürükle/bırak
