Gönderen Konu: update sorunu [Çözüldü]  (Okunma sayısı 4871 defa)
Çevrimdışı berkturk
  • İleti: 2
« : 18 Eylül 2014, 12:13:57 »
Merhaba. Update Manager dan güncelleme yapmaya çalıştığımda bu hataları alıyorum. sorunumu gidermemde yardımcı olursanız sevinirim.
W: Failed to fetch http://dists/archive.canonical.com/ubuntu/Release.gpg  Could not resolve 'dists'
W: Failed to fetch http:/archive.canonical.com/dists/natty/Release.gpg  Unable to connect to :http:
W: Failed to fetch http:/archive.canonical.com/dists/natty/backports/binary-amd64/Packages  Unable to connect to :http:
W: Failed to fetch http:/archive.canonical.com/dists/natty/backports/binary-i386/Packages  Unable to connect to :http:
W: Failed to fetch http:/archive.canonical.com/dists/natty/backports/i18n/Translation-en_US  Unable to connect to :http:
W: Failed to fetch http:/archive.canonical.com/dists/natty/backports/i18n/Translation-en  Unable to connect to :http:
W: Failed to fetch http://deb.playonlinux.com/dists/precise/Release  Unable to find expected entry 'main/source/Sources' in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/main/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/restricted/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/universe/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/multiverse/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/main/binary-amd64/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/restricted/binary-amd64/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/universe/binary-amd64/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/multiverse/binary-amd64/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/raring-security/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.14 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/main/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/restricted/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/universe/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/multiverse/binary-amd64/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/raring-updates/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.15 80]
W: Some index files failed to download. They have been ignored, or old ones used instead.
« Son Düzenleme: 18 Eylül 2014, 17:04:35 Gönderen: berkturk »
Ynt: update sorunu
« Yanıtla #1 : 18 Eylül 2014, 14:05:15 »
Aşağıdaki komutları sırasıyla uçbirimde çalıştırmayı deneyin.
sudo rm -rf /etc/apt/sources.list.d/*archive.canonical*
Ynt: update sorunu
« Yanıtla #2 : 18 Eylül 2014, 14:40:49 »
Kaynak listesi bayağı karışmış sanırım. Böyle bir konu açmadan önce hangi sürümü kullandığınız, bu sorun ortaya çıkmadan önce neler yaptığınız hakkında bilgi paylaşmanız daha uygun olurdu. Bunlara istinaden aşağıdaki komutların çıktılarını rica edelim.
cat /etc/lsb-release
cat /etc/apt/sources.list
cat /etc/apt/sources.list.d/official-package-repositories.list
cat /etc/apt/sources.list.d/additional-repositories.list
Çevrimdışı berkturk
  • İleti: 2
Ynt: update sorunu
« Yanıtla #3 : 18 Eylül 2014, 17:04:08 »
bunu yaptım düzeldi. teşekkürler.
