Gönderen Konu: Broadcomm BCM4313 wireless sorunu  (Okunma sayısı 18035 defa)
Çevrimdışı pomakemir
  • İleti: 36
  • Dağıtım: Linux Mint 17.1 Mate
Ynt: Broadcomm BCM4313 wireless sorunu
« Yanıtla #30 : 18 Aralık 2014, 18:14:25 »
Tüm ubuntulu sistemleri denedim nereydese hepsinde bu driver sorunlu, Butterfly dışında yardımcı olabilecek bir arkadaş yok mudur ?
  • İleti: 36
« Yanıtla #31 : 19 Aralık 2014, 10:30:22 »
[member=8]Butterfly[/member] hocam mint 13 kurdum zor da olsa.
lsmod
bnep                   18281  2
rfcomm                 47604  12
parport_pc             32866  0
ppdev                  17113  0
binfmt_misc            17540  1
bcma                   26696  0
arc4                   12529  2
snd_hda_codec_idt      70795  1
snd_hda_codec_hdmi     32474  1
snd_hda_intel          33773  5
brcmsmac              570859  0
mac80211              506816  1 brcmsmac
snd_hda_codec         127706  3 snd_hda_codec_idt,snd_hda_codec_hdmi,snd_hda_intel
snd_hwdep              13668  1 snd_hda_codec
snd_pcm                97188  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_rawmidi            30748  1 snd_seq_midi
snd_seq                61896  2 snd_seq_midi,snd_seq_midi_event
brcmutil               15139  1 brcmsmac
cfg80211              205544  2 brcmsmac,mac80211
snd_timer              29990  2 snd_pcm,snd_seq
radeon                804372  2
snd_seq_device         14540  3 snd_seq_midi,snd_rawmidi,snd_seq
crc8                   12893  1 brcmsmac
btusb                  18288  2
hp_wmi                 18092  0
bluetooth             180104  23 bnep,rfcomm,btusb
snd                    78855  20 snd_hda_codec_idt,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
ttm                    76949  1 radeon
drm_kms_helper         46978  1 radeon
drm                   242038  4 radeon,ttm,drm_kms_helper
psmouse                87603  0
sparse_keymap          13890  1 hp_wmi
joydev                 17693  0
uvcvideo               72627  0
videodev               98259  1 uvcvideo
hp_accel               25976  0
lis3lv02d              19876  1 hp_accel
soundcore              15091  1 snd
cordic                 12535  1 brcmsmac
wmi                    19256  1 hp_wmi
mac_hid                13253  0
v4l2_compat_ioctl32    17128  1 videodev
serio_raw              13211  0
snd_page_alloc         18529  2 snd_hda_intel,snd_pcm
sp5100_tco             13791  0
input_polldev          13896  1 lis3lv02d
i2c_piix4              13301  0
i2c_algo_bit           13423  1 radeon
k10temp                13166  0
lp                     17799  0
parport                46562  3 parport_pc,ppdev,lp
video                  19596  0
usbhid                 47199  0
hid                    99559  1 usbhid
r8169                  62099  0
« Yanıtla #32 : 19 Aralık 2014, 10:56:07 »
Aşağıdaki komutlar ile bcmwl-kernel-source paketini kurup sistemi yeniden başlatınız. Paket kurulumu sonrası geçici olarak sistem güncellemesi yapmayınız.
sudo apt-get install dkms
wget http://launchpadlibrarian.net/119579412/bcmwl-kernel-source_5.100.82.112%2Bbdcom-0ubuntu3_amd64.deb
sudo dpkg -i *.deb
wget http://launchpadlibrarian.net/119579414/bcmwl-kernel-source_5.100.82.112%2Bbdcom-0ubuntu3_i386.deb
sudo dpkg -i *.deb
Kurulum sonrası sistemi yeniden başlatınız.
Eğer sorun çözülürse aşağıdaki komut ile bcmwl-kernel-source paketini güncelleme almaması için kilitleyiniz.
sudo apt-mark bcmwl-kernel-source
  • İleti: 36
« Yanıtla #33 : 19 Aralık 2014, 12:45:20 »
sudo dpkg -i *.deb
sudo dpkg -i *.deb
hocam pm den attıgınız kodları kullandım reboot ettim bi sorun yok bu verdiginiz kodlar düzgün calısmadılar sanırım sorun cözüldü. driver i falan hic ellemeyecegim bozulma olmaz herhalde.
Ynt: [Çözüldü] Broadcomm BCM4313 wireless sorunu
« Yanıtla #34 : 19 Aralık 2014, 14:02:13 »
Depodan kurduğunuz paket ile sıkıntı yoksa böyle devam edin. Sorun çözüldü ise tedbiren yukarıda verilen komut ile bcmwl-kernel-source paketini güncelleme almaması için kilitleyebilirsiniz.
Bir kaç gün kontrol edin. Sıkıntı kalmadı ise geri dönüş yaparsanız konuyu kilitleyebiliriz.
  • İleti: 36
« Yanıtla #35 : 19 Aralık 2014, 14:28:18 »
[sudo] password for emir:
N: Geçersiz bir dosya uzantısı içerdiğinden '10periodic.dpkg-dist' dosyası '/etc/apt/apt.conf.d/' dizininde yoksayıldı.
E: Geçersiz işlem: bcmwl-kernel-source
« Yanıtla #36 : 19 Aralık 2014, 14:31:19 »
Aşağıdaki komutu deneyiniz.
sudo apt-mark hold bcmwl-kernel-source
  • İleti: 36
« Yanıtla #37 : 19 Aralık 2014, 14:34:18 »
bcmwl-kernel-source paketi tutuluyor.
N: Geçersiz bir dosya uzantısı içerdiğinden 'local-repository.list.save' dosyası '/etc/apt/sources.list.d/' dizininde yoksayıldı.
« Yanıtla #38 : 19 Aralık 2014, 14:54:00 »
Tamamdır, şimdi paket kilitlemiş oldunuz.
Kozmetik düzenlemeler yapalım Linux Mint 13'e.
Aşağıdaki komut 10periodic.dpkg-dist dosyasını siliniz bu yedekleme dosyası sanırım.
sudo rm -rf /etc/apt/apt.conf.d/10periodic.dpkg-dist
List.save uzantılı yedekleme dosyları ile ilgili mesaj almamak için buradaki öneriyi uygulayınız.
Artık konuyu kilitlemek için sizin kablosuz ağ sorunu ile ilgili gözlemlerinizi bekleyelim.
  • İleti: 36
« Yanıtla #39 : 21 Aralık 2014, 10:33:09 »
hocam durup dururken gene gitti wireless  :( [member=8]Butterfly[/member]
  • İleti: 36
« Yanıtla #40 : 21 Aralık 2014, 21:01:48 »
1 hafta uğraşmama rağmen olmadı, olduramadım. Windows 8 kurdum konu kilitlenebilir.
