Gönderen Konu: [Çözüldü] Fan Sürekli Çalışıyor  (Okunma sayısı 10503 defa)
Çevrimdışı Akila
  • İleti: 11
  • Dağıtım: Linux Mint 17.2 Rafaela KDE & Mate 64 bit
« : 04 Ocak 2015, 10:21:27 »
Merhaba, Windows 8.1 yanına linux Mint 17.1 kurdum. Rebecca da fan, sürekli ve yüksek devirde çalışıyor. Dizüstünde herhangi bir ısınma sorunu yok. Ölçülen sıcaklık (temp1 44 C; core 0 35 C; core 1 36 C). Ayrıca Windows 8.1 de fan normal (sessiz) çalışıyor. Yardımınızı rica ediyorum. Çıktılar:
xxxxxx@Tosba ~ $ cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17.1
DISTRIB_CODENAME=rebecca
xxxxxx@Tosba ~ $ lspci | egrep 'VGA|3D|Display'
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV620/M82 [Mobility Radeon HD 3450/3470]
xxxxxx@Tosba ~ $ glxinfo | grep render
OpenGL renderer string: Gallium 0.4 on AMD RV620
xxxxxx@Tosba ~ $ inxi -F
System:    Host: Tosba Kernel: 3.13.0-37-generic i686 (32 bit) Desktop: N/A Distro: Linux Mint 17.1 Rebecca
Machine:   System: TOSHIBA (portable) product: Satellite P300 version: PSPCCE-00H00XTE
           Mobo: TOSHIBA model: Satellite P300 Bios: TOSHIBA version: V3.40 date: 04/07/2009
CPU:       Dual core Intel Core2 Duo CPU P8400 (-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx)
           Clock Speeds: 1: 800.00 MHz 2: 2267.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV620/M82 [Mobility Radeon HD 3450/3470]
           X.Org: 1.15.1 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1280x854@59.9hz
           GLX Renderer: Gallium 0.4 on AMD RV620 GLX Version: 3.0 Mesa 10.1.3
Audio:     Card-1: Advanced Micro Devices [AMD/ATI] RV620 HDMI Audio [Radeon HD 3400 Series] driver: snd_hda_intel
           Card-2: Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel
Network:   Card-1: Intel WiFi Link 5100 driver: iwlwifi
           IF: wlan0 state: up mac: 00:16:ea:8c:c6:bc
           Card-2: Marvell 88E8040T PCI-E Fast Ethernet Controller driver: sky2
           IF: eth0 state: down mac: 00:1e:68:b3:de:03
Drives:    HDD Total Size: 500.1GB (1.0% used) 1: id: /dev/sda model: TOSHIBA_MK2552GS size: 250.1GB
           2: id: /dev/sdb model: TOSHIBA_MK2552GS size: 250.1GB
Partition: ID: / size: 71G used: 4.5G (7%) fs: ext4 ID: swap-1 size: 3.21GB used: 0.00GB (0%) fs: swap
Info:      Processes: 164 Uptime: 4 min Memory: 434.3/3025.1MB Client: Shell inxi: 1.8.4
Düzenleme : Çıktılar kod etiketi içine alındı.
« Son Düzenleme: 04 Ocak 2015, 23:37:14 Gönderen: Akila »
Ynt: Fan Sürekli Çalışıyor
« Yanıtla #1 : 04 Ocak 2015, 10:59:34 »
Aşağıdaki komut ile grub dosyasını açınız.
sudo gedit /etc/default/grub
tırnak işaretleri arasında  acpi_osi=Linux  açılış değişkenini ekleyiniz.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux"
Dosyayı kaydedip aşağıdaki komut ile grub ayar dosyasını güncellemeyi deneyiniz.
sudo update-grub
Sistemi yeniden başlatınız.
Çevrimdışı Akila
  • İleti: 11
« Yanıtla #2 : 04 Ocak 2015, 11:38:52 »
Belirttiğiniz düzenlemeyi yaptığım halde herhangi bir değişiklik olmadı.
« Yanıtla #3 : 04 Ocak 2015, 13:29:43 »
Burada anlatıldığı biçimde açık kaynak sürücüler için güç yönetimini etkinleştirmeyi deneyebilirsiniz. Güç profilini battery olarak belirleyiniz.
Çevrimdışı Akila
  • İleti: 11
« Yanıtla #4 : 04 Ocak 2015, 15:08:49 »
Teşekkür ederim.  Fan sesi (devri) hissedilir derecede azaldı. Bu arada fan sorunu çözer diye" Thermald" kurmuştum ama nasıl kullanıldığını çözemedim.
« Yanıtla #5 : 04 Ocak 2015, 15:17:07 »
Thermald elle ayar yapılabilen bir servis. İnce ayarları /etc/thermald/thermal-conf.xml dosyasını düzenleyerek yapılabiliyormuş. Varsayılan ayarlarla sistem başlangıcında otomatik olarak etkin olmuştur. Ayarlarla ilgili ayrıntıları aşağıdaki komut ile görebilirsiniz.
man thermal-conf.xml
« Son Düzenleme: 04 Ocak 2015, 15:20:07 Gönderen: Butterfly »
Çevrimdışı meda
  • İleti: 408
  • Grafik Kartı: GT 940MX
  • İşlemci: İ7 7500U
« Yanıtla #6 : 04 Ocak 2015, 21:40:14 »
Batarya tasarrufu için TLP uygulamasını kullanabilirsin.
                   Orhan VELİ"
Çevrimdışı Akila
  • İleti: 11
« Yanıtla #7 : 04 Ocak 2015, 22:48:38 »
Dosyayı açma kısmı nı çözdüm de, xml dosyasını sıcaklığa göre nasıl ayarlayacağımı çözemedim.
TLP yüklü görünüyor sistemde (ben mi yükledim yoksa 17.1 sürümüyle beraber mi geliyor bilmiyorum :) ). TLP programı geri planda otomatik çalışıyor galiba.
Peşpeşe mesaj göndermek yerine önceki mesajınızı düzenleyiniz.
« Son Düzenleme: 04 Ocak 2015, 22:58:08 Gönderen: Butterfly »
« Yanıtla #8 : 04 Ocak 2015, 23:01:19 »
Thermald ile gelen gelen varsayılan ayarlar yeterli olacaktır, kullanmadığım için ince yapılandırmanın nasıl yapılacağını bilemiyorum.
TLP varsayılan olarak gelmez, elle yüklemişsinizdir.
Fan ile ilgili sorun çözüldü ise bu konunun başlığını düzenleyip başına [Çözüldü] etiketi ekleyiniz.
Aynı başlık altında sedece bir konu hakkında konuşuyoruz. TLP ve Thermald ile ilgili farklı konular açabilirsiniz.
