Gönderen Konu: Uygulama yükleyemiyorum  (Okunma sayısı 4313 defa)
Çevrimdışı dev@mehmet
  • İleti: 189
  • Dağıtım: Linux Mint 19
« : 02 Şubat 2015, 20:46:31 »
apache server yüklemek istiyorum ama olmuyor.
Hata iletisi :
cd /home/metrekup/Workspaces/java
metrekup: ~ $ cd /home/metrekup/Workspaces/java
metrekup: ~/Workspaces/java $ sudo apt-get install apache2
Reading package lists... Done
Building dependency tree
apache2 is already the newest version.
The following packages were automatically installed and are no longer required:
  acl at-spi2-core colord dconf-gsettings-backend dconf-service desktop-file-utils fontconfig fonts-dejavu-extra
  gconf-service gconf-service-backend gconf2 gconf2-common gvfs gvfs-common gvfs-daemons gvfs-libs
  hicolor-icon-theme libasound2 libasound2-data libasyncns0 libatasmart4 libatk-bridge2.0-0 libatk1.0-0
  libatk1.0-data libatspi2.0-0 libavahi-client3 libavahi-common-data libavahi-common3 libavahi-glib1 libbonobo2-0
  libbonobo2-common libcairo-gobject2 libcairo2 libcanberra0 libcolord1 libcolorhug1 libcups2 libdatrie1 libdconf1
  libexif12 libflac8 libgconf-2-4 libgconf2-4 libgd3 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgif4 libgnome2-0
  libgnome2-bin libgnome2-common libgnomevfs2-0 libgnomevfs2-common libgphoto2-6 libgphoto2-l10n libgphoto2-port10
  libgraphite2-3 libgtk-3-0 libgtk-3-bin libgtk-3-common libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libgudev-1.0-0
  libgusb2 libharfbuzz0b libice-dev libidl-common libidl0 libieee1284-3 libjasper1 libjbig0 libjpeg-turbo8 libjpeg8
  liblcms2-2 libltdl7 libnspr4 libnss3 libnss3-nssdb libogg0 liborbit-2-0 liborbit2 libpango-1.0-0
  libpangocairo-1.0-0 libpangoft2-1.0-0 libpixman-1-0 libpthread-stubs0-dev libpulse0 libsane libsane-common
  libsecret-1-0 libsecret-common libsm-dev libsndfile1 libtdb1 libthai-data libthai0 libtiff5 libudisks2-0 libv4l-0
  libv4lconvert0 libvorbis0a libvorbisenc2 libvorbisfile3 libvpx1 libwayland-client0 libwayland-cursor0 libx11-dev
  libx11-doc libxau-dev libxcb-render0 libxcb-shm0 libxcb1-dev libxcursor1 libxdmcp-dev libxkbcommon0 libxt-dev
  policykit-1-gnome sound-theme-freedesktop tzdata-java udisks2 x11proto-core-dev x11proto-input-dev x11proto-kb-dev
  xorg-sgml-doctools xtrans-dev
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 135 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up mysql-server-5.5 (5.5.41-0ubuntu0.14.04.1) ...
Package configuration
                                   ┌──────┤ Configuring mysql-server-5.5 ├───────┐
                                   │ Repeat password for the MySQL "root" user:  │
                                   │ *****______________________________________ │
                                   │                   <Ok>                      │
150202 18:44:13 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be r
emoved in a future release. Please use the full name instead.
 ┌────────────────────────────────────────┤ Configuring mysql-server-5.5 ├─────────────────────────────────────────┐
 │ Unable to set password for the MySQL "root" user        │
 │ An error occurred while setting the password for the MySQL administrative user. This may have happened because  │
 │ the account already has a password, or because of a communication problem with the MySQL server.                │
 │ You should check the account's password after the package installation.                                         │
 │ Please read the /usr/share/doc/mysql-server-5.5/README.Debian file for more information.                        │
 │                                                     <Ok>                                                        │
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.5 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.5; however:
  Package mysql-server-5.5 is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
        Errors were
encountered while processing:
 mysql-server-5.5
 mysql-server
Ynt: Uygulama yükleyemiyorum
« Yanıtla #1 : 02 Şubat 2015, 23:39:58 »
burada anlatıldığı biçimde kurmayın deneyin.
  • İleti: 189
« Yanıtla #2 : 03 Şubat 2015, 18:03:20 »
Aslında sorunumu tam olarak açıklamamıştım. Hata yaşadığım makine koding.com üzerindeki sanal makineydi.Sorunumu ingilizce kaynaklar kullanarak sorunu çözmeye çalışmıştım. Ama olmamıştı. Ben de sonradan farkettiğim resetleme tuşunu kullanarak makineyi resetlemiştim. Sorunumu o şekilde çözdüm. Geciken cevabım için özür diler, ilginiz için teşekkür ederim.
