Gönderen Konu: [Çözüldü] ATI Radeon HD 7600M Isınma Sorunu  (Okunma sayısı 8605 defa)
Çevrimdışı Unal
  • İleti: 66
  • Dağıtım: Linux Mint 17.3
  • Grafik Kartı: ATI RADEON 7600M
  • İşlemci: Intel core i5
« : 25 Şubat 2015, 19:38:49 »
Merhaba Butterfly,
benim de ayni sorunum var fakat laptopun modeli ve ekran karti birbirine cok benziyor ayri konu acip acmayacagima karar veremedim.
Insallah bu isinma sorunundan kurtulurum. Simdiden tesekkürler.
uname -rm
3.13.0-37-generic x86_64
inxi -G
           Card-2: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7500M/7600M Series]
           X.Org: 1.15.1 drivers: fglrx,intel Resolution: 1366x768@60.0hz
           GLX Renderer: AMD Radeon HD 7600M Series GLX Version: 4.3.12798 - CPC 13.35.1005
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Thames [Radeon HD 7500M/7600M Series]
   1366x768       60.0*+   40.0
   1360x768       59.8     60.0
   1024x768       60.0
   800x600        60.3     56.2
   640x480        59.9
Section "ServerLayout"
    Identifier "amd-layout"
    Screen 0 "amd-screen" 0 0
    Identifier "intel"
    Driver "intel"
    Option "AccelMethod" "uxa"
    BusID "PCI:0@0:2:0"
    Identifier "amd-device"
    Driver "fglrx"
    BusID "PCI:1:0:0"
Section "Monitor"
    Identifier "amd-monitor"
    Option "VendorName" "ATI Proprietary Driver"
    Option "ModelName" "Generic Autodetecting Monitor"
    Option "DPMS" "true"
Section "Screen"
    Identifier "amd-screen"
    Device "amd-device"
    Monitor "amd-monitor"
    DefaultDepth 24
    SubSection "Display"
        Viewport   0 0
        Depth     24
    EndSubSection
inxi -FX
System:    Host: rechner Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2)
Machine:   System: Hewlett-Packard (portable) product: HP Pavilion m6 Notebook PC version: 0791100000205610000620100
           Mobo: Hewlett-Packard model: 18A5 version: 73.50 Bios: Insyde version: F.25 date: 01/21/2013
CPU:       Dual core Intel Core i5-3210M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9977.06
           Clock Speeds: 1: 1200.00 MHz 2: 1200.00 MHz 3: 1200.00 MHz 4: 1200.00 MHz
           Card-2: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7500M/7600M Series] bus-ID: 01:00.0
           GLX Renderer: AMD Radeon HD 7600M Series GLX Version: 4.3.12798 - CPC 13.35.1005 Direct Rendering: Yes
Audio:     Card: Intel 7 Series/C210 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Intel Centrino Wireless-N 2230 driver: iwlwifi ver: in-tree: bus-ID: 08:00.0
           IF: wlan0 state: up mac: 68:5d:43:b8:3a:53
           driver: r8169 ver: 2.3LK-NAPI port: 2000 bus-ID: 07:00.2
           IF: eth0 state: down mac: 28:92:4a:19:14:5b
Drives:    HDD Total Size: 1000.2GB (3.5% used) 1: id: /dev/sda model: TOSHIBA_MQ01ABD1 size: 1000.2GB
Partition: ID: / size: 909G used: 33G (4%) fs: ext4 ID: swap-1 size: 8.48GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 62.0C mobo: 62.0C gpu: 52.00C
Info:      Processes: 176 Uptime: 34 min Memory: 1142.6/7881.4MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
lspci | grep VGA
lspci | grep VGA
OpenGL renderer string: AMD Radeon HD 7600M Series
« Son Düzenleme: 26 Şubat 2015, 20:55:47 Gönderen: Unal »
Ey gönül üzülme, Ne bu dertler baki ne de bu dünya....
Ynt: ATI Radeon HD 7600M Isınma Sorunu
« Yanıtla #1 : 25 Şubat 2015, 23:43:34 »
Burada anlatıldığı biçimde AMD indicator uygulamacığını kurup, akabinde buradaki düzenlemeyi yapınız. Sonrasında Intel GPU'yu etkinleştirip sistemi yeniden başlatmayı deneyiniz.
Çevrimdışı Unal
  • İleti: 66
[Çözüldü] Ynt: ATI Radeon HD 7600M Isınma Sorunu
« Yanıtla #2 : 26 Şubat 2015, 20:55:31 »
Yazdiklarinizi uyguladim. Sorun suan ortadan kalkmis gözüküyor.
Vakit ayirdiginiz ve tavsiyeleriniz icin COK COK TESEKKÜRLER.
