Gönderen Konu: [Çözüldü] Linux Mint 17.1 Mate - Nvidia Akıcılık Sorunu  (Okunma sayısı 6078 defa)
Çevrimdışı CrossKindar
  • İleti: 17
  • Dağıtım: Linux Mint 17.1 MATE
Arkadaşlar windowsu kaldırıp linux'a geçeyim dedim 2 gün önce Linux Mint 17.1 Rebecca Mate sürümünü kurmus bulundum, güncellemeleri yaptım ama bir şey eksik gibi geliyor bana akıcılığı çözmemiz lazım.. :) mesela açık olan bir pencereyi tutup sağa sola götürdüğümde siyahlıklar çıkıyor hafiften, tamamında değil ama üst kısımlarda oluyor.
System:    Host: linuxmint-RV420-RV520-RV720-E3530-S3530-E3420-E3520 Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2)
           Desktop: N/A Distro: Linux Mint 17.1 Rebecca
Machine:   System: SAMSUNG (portable) product: RV420/RV520/RV720/E3530/S3530/E3420/E3520 version: 0.1
           Mobo: SAMSUNG model: RV420/RV520/RV720/E3530/S3530/E3420/E3520 version: FAB1
           Bios: Phoenix version: 04PQ date: 09/03/2011
CPU:       Dual core Intel Core i5-2410M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9179.76
           Clock Speeds: 1: 800.00 MHz 2: 800.00 MHz 3: 800.00 MHz 4: 2300.00 MHz
Graphics:  Card: NVIDIA GF119M [GeForce GT 520M] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1366x768@60.0hz
           GLX Renderer: GeForce GT 520M/PCIe/SSE2 GLX Version: 4.4.0 NVIDIA 331.113 Direct Rendering: Yes
Audio:     Card-1: Intel 6 Series/C200 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2: NVIDIA GF119 HDMI Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
           driver: r8169 ver: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: e8:03:9a:19:32:82
           Card-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter driver: bcma-pci-bridge bus-ID: 02:00.0
           IF: wlan0 state: up mac: e0:ca:94:1c:cb:57
Drives:    HDD Total Size: 500.1GB (1.4% used) 1: id: /dev/sda model: ST500LM012_HN size: 500.1GB
Partition: ID: / size: 221G used: 6.4G (4%) fs: ext4
Info:      Processes: 183 Uptime: 52 min Memory: 669.7/3932.7MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
« Son Düzenleme: 20 Mart 2015, 17:49:40 Gönderen: CrossKindar »
Ynt: Linux Mint 17.1 Mate - Nvidia Akıcılık Sorunu
« Yanıtla #1 : 20 Mart 2015, 09:13:13 »
Aşağıdaki komutların çıktılarını da paylaşınız.
  • İleti: 17
« Yanıtla #2 : 20 Mart 2015, 15:36:29 »
Buyrun hocam
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce GT 520M] (rev a1)
linuxmint@linuxmint-RV420-RV520-RV720-E3530-S3530-E3420-E3520 ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime'
ii  nvidia-331                                                  331.113-0ubuntu0.0.4                                amd64        NVIDIA binary driver - version 331.113
ii  nvidia-331-uvm                                              331.113-0ubuntu0.0.4                                amd64        NVIDIA Unified Memory kernel module
ii  nvidia-libopencl1-331                                       331.113-0ubuntu0.0.4                                amd64        NVIDIA OpenCL Driver and ICD Loader library
ii  nvidia-opencl-icd-331                                       331.113-0ubuntu0.0.4                                amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                                0.6.2linuxmint1                                     amd64        Tools to enable NVIDIA's Prime
ii  nvidia-settings                                             331.20-0ubuntu8                                     amd64        Tool for configuring the NVIDIA graphics driver
« Yanıtla #3 : 20 Mart 2015, 15:42:57 »
Aşağıdaki komut ile nvidia-prime paketini kaldırınız.
Sonra aşağıdaki komut ile xorg.conf ayar dosyasını oluşturup sistemi yeniden başlatınız.
sudo nvidia-xconfig
Ek olarak aşağıdaki komutları sırasıyla uçbirimde çalıştırarak, samsung-tools paketini de bonus olarak kurabilirsiniz.
sudo add-apt-repository ppa:voria/ppa
sudoapt-get install samsung-tools
« Son Düzenleme: 20 Mart 2015, 15:51:46 Gönderen: Butterfly »
  • İleti: 17
« Yanıtla #4 : 20 Mart 2015, 16:23:54 »
hocam prime paketini kaldırdım
sudo nvidia-xconfig kodu ile dosyayıda kaldırdım sanırım yeniden başlattım tekrar yazdım bakın olmus mu
Using X configuration file: "/etc/X11/xorg.conf".
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
samsung toolsu da kurdum
« Yanıtla #5 : 20 Mart 2015, 16:43:02 »
Aşağıdaki komut ile xorg.conf dosya içeriğini görebilirsiniz, dosya oluşmuşsa yukarıdaki komutun çalışması ile ilgili sorun yok demektir.
Son durum nedir peki akıcılıkla ilgili?
  • İleti: 17
« Yanıtla #6 : 20 Mart 2015, 16:56:39 »
İlginiz alakanız için teşekkür ederim test ediyorum sistemi daha iyi gibi çıktıyı birde sizle paylaşayım anlamıyorum pek :)
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 331.113  (buildmeister@swio-display-x64-rhel04-03)  Mon Dec  1 21:15:34 PST 2014
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
Konuyla ilgili değil ama parlaklığımı değiştiremiyorum sarj takılı açıldıgında ful parlak sarj çıkınca minimum seviyede parlaklık ayarlıyor kendisi fn tusu ile birlikte kullandığımda değişiklik oluyor gibi duruyor ama değişmiyor ne yapmam gerekir bu durumda bilgilendirirseniz sevinirim
« Yanıtla #7 : 20 Mart 2015, 17:29:17 »
Akıcılık sorunu için ek olarak buradaki öneri uygulanabilir.
Aynı konu altında sadece bir soru/sorun hakkında konuşuyoruz. Parlaklık sorunu ile ilgili öncelikle forumdaki önerileri inceleyiniz. Eğer sorun mevcut konulardaki öneriler ile çözülmezse yeni bir konu açmanızı rica ediyoruz.
Bu konu ile ilgili sorun çözüldü ise etiketlerseniz kilitleyebiliriz. Çözülen başlıkların etiketlenmesi hakkında.
