Gönderen Konu: yine rescue sorunu  (Okunma sayısı 9715 defa)
Ynt: yine rescue sorunu
« Yanıtla #15 : 09 Mayıs 2015, 11:41:34 »
karakartala, bir kurulum gerçekleşti gibi oldu, sistemi yeniden başlattım, ancak söz konusu boot menüleri gelmedi.
Şu anda sisteminizde Windows açılıyor değil mi? Konu hakkında fazla bilgim yok ama, kurulumda görünen çıktıları paylaşırsanız araştırabilirim.
http://www.rodsbooks.com/refind/installing.html#windows
Çevrimdışı ihsaniye
  • İleti: 108
  • Dağıtım: linux Mint 19
« Yanıtla #16 : 10 Mayıs 2015, 21:59:35 »
Windows PowerShell
Copyright (C) 2015 Microsoft Corporation. All rights reserved.
PS C:\Windows\system32> WindowsCopyright (C) 2015 Microsoft Corporation. All rights reserved. PowerShell
C : The term 'C' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spell
ing of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:19
+ WindowsCopyright (C) 2015 Microsoft Corporation. All rights reserved. ...
    + CategoryInfo          : ObjectNotFound: (C:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
PS C:\Windows\system32> PS C:\Windows\system32>
PS : Cannot find a process with the name "C:\Windows\system32>". Verify the process name and call the cmdlet again.
At line:1 char:1
+ PS C:\Windows\system32>
    + CategoryInfo          : ObjectNotFound: (C:\Windows\system32>:String) [Get-Process], ProcessCommandException
    + FullyQualifiedErrorId : NoProcessFoundForGivenName,Microsoft.PowerShell.Commands.GetProcessCommand
PS C:\Windows\system32> PS C:\Windows\system32> # ./install.sh
At line:1 char:1
+ PS C:\Windows\system32> # ./install.sh
PS C:\Windows\system32> PS C:\Windows\system32> InstallingESPInstallingCopied rEFInd binary files driver for ext4 (ext4_
x64.efioot/efiext4_x64.efiogram.At++    + FullyQualifiedErrorId : CommandNotFoundException    + CategoryInfo          :
ObjectNotFound: (ext4_x64.efi:String) [], CommandNotFoundException
~~~~~~~~~~~~ ... llingCopied rEFInd binary files driver for ext4 (ext4_x64.efi) was fo ... line:1 char:68 Check the spel
ling of the name, or if a path was included, verify that the path is correct and try again. : The term 'ext4_x64.efi' is
 not recognized as the name of a cmdlet, function, script file, or operable pr using vfat rEFInd on Linux....) was found
 at /b
ext4_x64.efi:String : The term 'ext4_x64.efi:String' is not recognized as the name of a cmdlet, function, script file,
or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try
 again.
At line:1 char:234
+ ...  CategoryInfo          : ObjectNotFound: (ext4_x64.efi:String) [], Co ...
    + CategoryInfo          : ObjectNotFound: (ext4_x64.efi:String:String) [], CommandNotFoundException
PS C:\Windows\system32> PS C:\Windows\system32> CopyingrEFInd. sample configuration file as refind.conf; editCopyingrEFI
nd.eAt++    + FullyQualifiedErrorId : CommandNotFoundException    + CategoryInfo          : ObjectNotFound: (CopyingrEFI
nd.:String) [], CommandNotFoundException ~~~~~~~~~~~~~~ CopyingrEFInd. sample configuration file as refind.conf; edit th
is fi ... line:1 char:1 program. Check the spelling of the name, or if a path was included, verify that the path is corr
ect and try again. : The term 'CopyingrEFInd.' is not recognized as the name of a cmdlet, function, script file, or oper
abl this file to configure
Get-Process : A positional parameter cannot be found that accepts argument 'CopyingrEFInd.'.
At line:1 char:1
+ PS C:\Windows\system32> CopyingrEFInd. sample configuration file as r ...
    + CategoryInfo          : InvalidArgument: ( [Get-Process], ParameterBindingException
    + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.GetProcessCommand
CopyingrEFInd.:String : The term 'CopyingrEFInd.:String' is not recognized as the name of a cmdlet, function, script fi
le, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and
 try again.
At line:1 char:206
+ ... ategoryInfo          : ObjectNotFound: (CopyingrEFInd.:String) [], Co ...
    + CategoryInfo          : ObjectNotFound: (CopyingrEFInd.:String:String) [], CommandNotFoundException
edit : The term 'edit' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the
 spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:330
+ ... CopyingrEFInd. sample configuration file as refind.conf; edit this fi ...
    + CategoryInfo          : ObjectNotFound: (edit:String) [], CommandNotFoundException
PS C:\Windows\system32> editAt++    + FullyQualifiedErrorId : CommandNotFoundException    + CategoryInfo          : Obje
ctNotFound: (edit:String) [], CommandNotFoundException                                                          ~~~~ Cop
yingrEFInd. sample configuration file as refind.conf; edit this fi ... line:1 char:58 spelling of the name, or if a path
 was included, verify that the path is correct and try again. : The term 'edit' is not recognized as the name of a cmdle
edit:String : The term 'edit:String' is not recognized as the name of a cmdlet, function, script file, or operable prog
ram. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:110
+ ... ion    + CategoryInfo          : ObjectNotFound: (edit:String) [], Co ...
    + CategoryInfo          : ObjectNotFound: (edit:String:String) [], CommandNotFoundException
At line:1 char:271
At line:1 char:1
PS C:\Windows\system32> PS C:\Windows\system32> Installation has completed successfully.
Düzenleme: Çıktılar code etiketi içine alındı.
karakartala
« Son Düzenleme: 11 Mayıs 2015, 15:56:30 Gönderen: karakartala »
Çevrimdışı ihsaniye
  • İleti: 108
« Yanıtla #17 : 10 Mayıs 2015, 22:03:03 »
Buraya aktarmak için epey uğraştım.
« Yanıtla #18 : 11 Mayıs 2015, 16:06:33 »
Ubuntu-Tr'deki anlatım Linux altında kurulum içindi. Linux altında kurulumu belgesini incelemişsiniz. Windows için kurulumun anlatıldığı bağlantı önceki iletimde mevcut. Çıktılar için kusura bakmayın. Çıktılar direk kopyalanamıyor muydu?
« Son Düzenleme: 11 Mayıs 2015, 21:29:47 Gönderen: karakartala »
Çevrimdışı ihsaniye
  • İleti: 108
« Yanıtla #19 : 11 Mayıs 2015, 20:22:21 »
Usta, beni biraz aşıyor, teşekkür ederim ilginize.
