Değişen bir şey olmadı gene. Cahil kafasıyla LinuxMinti yendien kurdum,fakat, aynı durum söz konusu. Tekrardan sizlere komut girdi-çıktılarını gönderiyorum.
glxgears
umerye@merifsin ~ $ glxgears
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
298 frames in 5.0 seconds = 59.564 FPS
300 frames in 5.0 seconds = 60.000 FPS
301 frames in 5.0 seconds = 60.002 FPS
301 frames in 5.0 seconds = 60.000 FPS
299 frames in 5.0 seconds = 59.603 FPS
298 frames in 5.0 seconds = 59.599 FPS
XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
after 47 requests (47 known processed) with 0 events remaining.
humerye@merifsin ~ $
vblank_mode=0 glxgears
umerye@merifsin ~ $ vblank_mode=0 glxgears
301 frames in 5.0 seconds = 60.153 FPS
301 frames in 5.0 seconds = 59.999 FPS
297 frames in 5.0 seconds = 59.399 FPS
humerye@merifsin ~ $ uname -rminxi -Gxhumerye@merifsin ~ $ inxi -Gx
Graphics: Card: NVIDIA GK104 [GeForce GTX 680] bus-ID: 01:00.0 X.Org: 1.15.1 driver: nvidia Resolution: 1920x1080@60.0hz
GLX Renderer: GeForce GTX 680/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 349.16 Direct Rendering: Yes
glxinfo | grep render[
humerye@merifsin ~ $ glxinfo | grep render
OpenGL renderer string: GeForce GTX 680/PCIe/SSE2
GL_NV_compute_program5, GL_NV_conditional_render,
$ lspci | egrep 'VGA|3D|Display'
01:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 680] (rev a1)
xrandrhumerye@merifsin ~ $ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected primary (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 160mm x 90mm
1920x1080 60.0*+ 59.9 50.0 30.0 25.0 24.0 60.0 50.0
1680x1050 60.0
1600x1200 60.0
1440x900 75.0 59.9
1360x768 60.0
1280x1024 75.0 60.0
1280x960 60.0
1280x800 59.8
1280x720 59.9 50.0
1152x864 75.0
1024x768 75.0 70.1 60.0
800x600 75.0 72.2 60.3
720x576 50.0
720x480 59.9
640x480 75.0 72.8 59.9
DP-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
humerye@merifsin ~ $ cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 349.16 (buildmeister@swio-display-x86-rhel47-06) Wed Apr 8 00:52:19 PDT 2015
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Section "Files"
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
Identifier "Keyboard0"
Driver "kbd"
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
Değerli zamanınızı çalmak istemiyorum daha fazla. Selametle kalın.
