Gönderen Konu: [Çözüldü] Ram sistemde az gözüküyor.  (Okunma sayısı 9008 defa)
Çevrimdışı nymphs
  • İleti: 6
« : 02 Haziran 2015, 16:33:22 »
Merhaba , 2 adet sabit diskim mevcut 1 tanesinde Windows , diğerinde Linux Mint kurulu.
Bios ekranında , sistem belleği 8 gb gözüküyor. Windows 8 de de 8 gb gözüküyor ancak Linux mint da 3 gb
$ free -m
             total       used       free     shared    buffers     cached
Mem:          3264       2745        518          0         46        901
-/+ buffers/cache:       1797       1466
Swap:            0          0          0
« Son Düzenleme: 02 Haziran 2015, 22:11:31 Gönderen: nymphs »
Ynt: Ram sistemde az gözüküyor.
« Yanıtla #1 : 02 Haziran 2015, 16:42:05 »
Çevrimdışı nymphs
  • İleti: 6
« Yanıtla #2 : 02 Haziran 2015, 17:00:58 »
System:    Host: sinan Kernel: 3.11-2-amd64 x86_64 (64 bit, gcc: 4.8.1) Desktop: Cinnamon 2.0.14  Distro: LinuxMint 1 debian
Machine:   Mobo: INTEL model: INTEL H55 version: INTEL Bios: American Megatrends version: 080015 date: 01/25/2013
CPU:       Quad core Intel Core i7 CPU 870 (-HT-MCP-) cache: 8192 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 23406.7
           Clock Speeds: 1: 1200.00 MHz 2: 1200.00 MHz 3: 1200.00 MHz 4: 1200.00 MHz 5: 1200.00 MHz 6: 1200.00 MHz 7: 1200.00 MHz 8: 1200.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Turks LE [Radeon HD 5570/6510/7510/8510] bus-ID: 01:00.0
           X.Org: 1.14.3 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1600x900@60.0hz
           GLX Renderer: Gallium 0.4 on AMD TURKS GLX Version: 3.0 Mesa 9.2.2 Direct Rendering: Yes
Audio:     Card-1: Intel 5 Series/3400 Series High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2: Advanced Micro Devices [AMD/ATI] Turks/Whistler HDMI Audio [Radeon HD 6000 Series]
           Sound: Advanced Linux Sound Architecture ver: k3.11-2-amd64
Network:   Card: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller
           driver: r8169 ver: 2.3LK-NAPI port: e800 bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (0.7% used) 1: id: /dev/sda model: TOSHIBA_DT01ACA0 size: 500.1GB
           2: id: /dev/sdb model: ST500DM002 size: 500.1GB
Partition: ID: / size: 459G used: 6.9G (2%) fs: ext4
Sensors:   System Temperatures: cpu: 48.0C mobo: N/A gpu: 51.0
Info:      Processes: 211 Uptime: 2:06 Memory: 1819.1/3264.4MB Runlevel: 2 Gcc sys: 4.8.2
           Client: Shell (bash 4.3.25) inxi: 1.9.14
« Yanıtla #3 : 02 Haziran 2015, 17:16:15 »
Aslında LMDE 32 sürümün kurulu olabileceğini öngörmüştüm, çünkü ilgili sürüm non-PAE çekirdekle geliyor 4 gb. RAM üstü için kısıtları var. Bu durumun 32 bit PAE destekli çekirdek sürümünü kurarak dolaşılabiliyor. Ama sisteminizde LMDE 1'in eski sürümünün 64 bit olanı kurulu. Bu durumda bir miktar araştırma gerekebilir.
Eğer sisteminizi yeni kurdu iseniz, bunun yerine LMDE 2'yi kurmanızı önerebilirim. Ya da LMDE 2'yi USB bellek gibi bir ortama yazdırıp, sistemi çalışan DVD/USB olarak açarak, durumu bu sürüm ile kontrol edebilirsiniz.
Çevrimdışı nymphs
  • İleti: 6
« Yanıtla #4 : 02 Haziran 2015, 17:18:38 »
http://www.linuxmint.com/edition.php?id=188
bu adresteki sözünü ettiğiniz sürüm sanırım
bir de usb ye dosyaları doğrudan atamam yeterli midir. daha önceki yüklememi windows üzerinden iso yazdırma programı ile usb ye yazdırmıştım bootable durumları vardı
« Son Düzenleme: 02 Haziran 2015, 17:21:08 Gönderen: nymphs »
« Yanıtla #5 : 02 Haziran 2015, 17:28:44 »
Evet bağlantıdaki LMDE 2 Mate 64 bit sürümü deneyebilirsiniz. Linux'da yeni iseniz, bunun yerine aşağıdaki sürümü denemenizi öneririm.
http://www.linuxmint.com/edition.php?id=174
Linux altında ISO dosyasını USB belleğe yazdırmak için aşağıdaki konuyu inceleyebilirsiniz.
http://forum.linuxmint.net.tr/index.php?topic=56.0
Çevrimdışı nymphs
  • İleti: 6
« Yanıtla #6 : 02 Haziran 2015, 17:40:33 »
Peki rebecca sürümünü indiriyorum şu anda kurulum bittikten sonra sonucu tekrar bilreceğim
Çevrimdışı nymphs
  • İleti: 6
« Yanıtla #7 : 02 Haziran 2015, 19:41:29 »
Su anda kurulum asamasindayim
Kurmadan once bir kontrol etmek istedim
Memmory yine 3.2 gb gozukuyor kurulumdan sonra duzelme olasiligi var midir acaba
Çevrimdışı meda
  • İleti: 408
  • Grafik Kartı: GT 940MX
  • İşlemci: İ7 7500U
« Yanıtla #8 : 02 Haziran 2015, 20:22:44 »
Windows ortamında yanlış bakıyor olabilirsiniz. Sistem yöneticisinden bakınca 500-900 arası RAM kullanılan olur. Olması da gerek. Mesela bende öyledir. Bu açıdan bakınca Mint üzerinde herhangi hata yok.  :)
                   Orhan VELİ"
Çevrimdışı nymphs
  • İleti: 6
[Çözüldü] Ynt: Ram sistemde az gözüküyor.
« Yanıtla #9 : 02 Haziran 2015, 20:59:49 »
$ free -m
             toplam       kull.       boş     paylaş.    tampon     önbellk.
Bellek:       7976       1225       6750         12         49        540
-/+ tampon/önbellek:        636       7339
Takas:        3317          0       3317
Sorunu hallettim sorun linux değil bios kaynaklıymış,
Sırası ile şu adımlar gerçekleşti :
Bios menüsünden Advanced Chipset Settings -> Memory Remap seçeneği Disable'dan Enable a geçirdim.
Yardımlarınız için teşekkürler
« Yanıtla #10 : 02 Haziran 2015, 21:28:18 »
