Hocam, teşekkür ederim kurulumu yapıyorumda. Biz böyle uğraşmak yerine direk sitesinden indirip Windowstaki gibi tıklayıp kurulumu başlayamaz mıyız?
Hocam alttaki komut ile test ettim ama hata aldım.
optirun glxgears
[14179.706808] [ERROR]You've no permission to communicate with the Bumblebee daemon. Try adding yourself to the 'bumblebee' group
[14179.706890] [ERROR]Could not connect to bumblebee daemon - is it running?
optirun -vvv glxgears
[14311.409309] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[14311.409694] [INFO]Configured driver: nvidia
[14311.409771] [ERROR]You've no permission to communicate with the Bumblebee daemon. Try adding yourself to the 'bumblebee' group
[14311.409792] [DEBUG]Socket closed.
[14311.409816] [ERROR]Could not connect to bumblebee daemon - is it running?
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
# bbswitch - new in BB 3, recommended if available
# switcheroo - vga_switcheroo method, use at your own risk
# none - disable PM completely
[driver-nvidia]
KernelDriver=nvidia-331
PMMethod=auto
# default Xorg modules path
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
Identifier "Layout0"
Option "AutoAddDevices" "false"
Option "AutoAddGPU" "false"
Identifier "DiscreteNvidia"
Driver "nvidia"
VendorName "NVIDIA Corporation"
# If the X server does not automatically detect your VGA device,
# you can manually set it here.
# To get the BusID prop, run `lspci | egrep 'VGA|3D'` and input the data
# as you see in the commented example.
# This Setting may be needed in some platforms with more than one
# nvidia card, which may confuse the proprietary driver (e.g.,
# trying to take ownership of the wrong device). Also needed on Ubuntu 13.04.
BusID "PCI:01:00:0"
# Setting ProbeAllGpus to false prevents the new proprietary driver
# instance spawned to try to control the integrated graphics card,
# which is already being managed outside bumblebee.
# This option doesn't hurt and it is required on platforms running
# more than one nvidia graphics card with the proprietary driver.
# (E.g. Macbook Pro pre-2010 with nVidia 9400M + 9600M GT).
# If this option is not set, the new Xorg may blacken the screen and
# render it unusable (unless you have some way to run killall Xorg).
Option "ProbeAllGpus" "false"
Option "NoLogo" "true"
Option "UseEDID" "false"
ii bumblebee 3.2.1-90~trustyppa1 amd64 NVIDIA Optimus support
ii bumblebee-nvidia 3.2.1-90~trustyppa1 amd64 NVIDIA Optimus support using the proprietary NVIDIA driver
ii nvidia-331 331.113-0ubuntu0.0.4 amd64 NVIDIA binary driver - version 331.113
ii nvidia-settings 331.20-0ubuntu8 amd64 Tool for configuring the NVIDIA graphics driver
ii primus 20131127-1~trustyppa1 amd64 client-side GPU offloading for NVIDIA Optimus
ii primus-libs:amd64 20131127-1~trustyppa1 amd64 Shared libraries for primus
ii primus-libs:i386 20131127-1~trustyppa1 i386 Shared libraries for primus
ii primus-libs-ia32 20131127-1~trustyppa1 i386 Shared libraries for primus (32-bit)
ii virtualgl 2.3.3-1~trustyppa1 amd64 Toolkit for displaying OpenGL applications to thin clients
ii virtualgl-libs:amd64 2.3.3-1~trustyppa1 amd64 Library files for virtualgl
01:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/820M / GT 620M/625M/630M/720M] (rev a1)
inxi -Gx
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
Düzenleme : Mesajlar birleştirildi
