Gönderen Konu: [Çözüldü] Kurulum Sonrası Siyah Ekran ve Masaüstüne Ulaşamama  (Okunma sayısı 29604 defa)
Çevrimdışı smtlcasm
  • İleti: 40
Ynt: Kurulum Sonrası Siyah Ekran ve Masaüstüne Ulaşamama
« Yanıtla #45 : 10 Haziran 2015, 10:03:54 »
[sudo] password for smtlcasm:
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  fglrx-updates-core lib32gcc1 libc6-i386
The following NEW packages will be installed:
  fglrx-amdcccle-updates fglrx-updates fglrx-updates-core lib32gcc1 libc6-i386
0 upgraded, 5 newly installed, 0 to remove and 7 not upgraded.
Need to get 117 MB of archives.
After this operation, 490 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu/ trusty-updates/main libc6-i386 amd64 2.19-0ubuntu6.6 [2.206 kB]
Get:2 http://archive.ubuntu.com/ubuntu/ trusty-updates/main lib32gcc1 amd64 1:4.9.1-0ubuntu1 [47,6 kB]
Get:3 http://archive.ubuntu.com/ubuntu/ trusty-updates/restricted fglrx-updates-core amd64 2:15.200-0ubuntu0.3 [72,1 MB]
Get:4 http://archive.ubuntu.com/ubuntu/ trusty-updates/restricted fglrx-updates amd64 2:15.200-0ubuntu0.3 [37,4 MB]
Get:5 http://archive.ubuntu.com/ubuntu/ trusty-updates/restricted fglrx-amdcccle-updates amd64 2:15.200-0ubuntu0.3 [5.125 kB]
Fetched 117 MB in 2min 16s (855 kB/s)
Selecting previously unselected package libc6-i386.
(Reading database ... 194675 files and directories currently installed.)
Preparing to unpack .../libc6-i386_2.19-0ubuntu6.6_amd64.deb ...
Unpacking libc6-i386 (2.19-0ubuntu6.6) ...
Replaced by files in installed package libc6:i386 (2.19-0ubuntu6.6) ...
Selecting previously unselected package lib32gcc1.
Preparing to unpack .../lib32gcc1_1%3a4.9.1-0ubuntu1_amd64.deb ...
Unpacking lib32gcc1 (1:4.9.1-0ubuntu1) ...
Selecting previously unselected package fglrx-updates-core.
Preparing to unpack .../fglrx-updates-core_2%3a15.200-0ubuntu0.3_amd64.deb ...
Unpacking fglrx-updates-core (2:15.200-0ubuntu0.3) ...
Selecting previously unselected package fglrx-updates.
Preparing to unpack .../fglrx-updates_2%3a15.200-0ubuntu0.3_amd64.deb ...
Unpacking fglrx-updates (2:15.200-0ubuntu0.3) ...
Selecting previously unselected package fglrx-amdcccle-updates.
Preparing to unpack .../fglrx-amdcccle-updates_2%3a15.200-0ubuntu0.3_amd64.deb ...
Unpacking fglrx-amdcccle-updates (2:15.200-0ubuntu0.3) ...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for ureadahead (0.100.0-16) ...
ureadahead will be reprofiled on next reboot
Setting up libc6-i386 (2.19-0ubuntu6.6) ...
Setting up lib32gcc1 (1:4.9.1-0ubuntu1) ...
Setting up fglrx-updates-core (2:15.200-0ubuntu0.3) ...
update-alternatives: using /usr/lib/fglrx-core/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GFXCORE.conf (x86_64-linux-gnu_gfxcore_conf) in auto mode
Loading new fglrx-updates-core-15.200 DKMS files...
First Installation: checking all kernels...
Building only for 3.16.0-38-generic
Building for architecture amd64
Building initial module for 3.16.0-38-generic
Done.
fglrx_updates:
 - Original module
 - Installation
   - Installing to /lib/modules/3.16.0-38-generic/kernel/drivers/char/drm/
depmod...........
DKMS: install completed.
Setting up fglrx-updates (2:15.200-0ubuntu0.3) ...
update-alternatives: using /usr/lib/fglrx/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in auto mode
update-alternatives: using /usr/lib/fglrx/alt_ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in auto mode
Setting up fglrx-amdcccle-updates (2:15.200-0ubuntu0.3) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
Processing triggers for initramfs-tools (0.103ubuntu4.2) ...
update-initramfs: Generating /boot/initrd.img-3.16.0-38-generic
Warning: No support for locale: en_US.utf8
böyle bir şey oldu. Tamamlandı galiba, simdi ne yapıcam?
« Yanıtla #46 : 10 Haziran 2015, 10:10:01 »
Aşağıdaki komutu çalıştırınız.
sudo amdconfig --initial -f --adapter=all
Sonra aşağıdaki komut ile yapılandırma dosyasının oluşup oluşmadığını kontrol ediniz.
Çevrimdışı smtlcasm
  • İleti: 40
« Yanıtla #47 : 10 Haziran 2015, 10:12:03 »
Section "ServerLayout"
Section "Module"
Section "Monitor"
   Option       "VendorName" "ATI Proprietary Driver"
   Option       "ModelName" "Generic Autodetecting Monitor"
   Option       "DPMS" "true"
   Driver      "fglrx"
   BusID       "PCI:1:0:0"
Section "Screen"
   DefaultDepth     24
   SubSection "Display"
      Viewport   0 0
      Depth     24
   EndSubSection
böyle bir şey çıktı.
« Yanıtla #48 : 10 Haziran 2015, 10:20:07 »
Tamam sürücü kurulmuş ve yapılandırma dosyası oluşturulmuş görünüyor, sistemi yeniden başlatmayı deneyiniz. Bakalım acpi=force değişkeni olmadan başlatabilecek misiniz?
Intel & Ati GPU'ları arasındaki geçiş için  burada anlatıldığı biçimde AMD Indicator uygulamacığını kurup GPU değişimini yapmayı deneyebilirsiniz. Uygulamacığın düzgün çalışması için buradaki düzenlemeyi de yapmayı unutmayınız. GPU'lar arasındaki bu geçiş dinamik değildir, değişiklik sonrası sistemi yeniden başlatmanız gerekiyor.
Çevrimdışı smtlcasm
  • İleti: 40
« Yanıtla #49 : 10 Haziran 2015, 10:46:28 »
böyle oluyor yardım edin, artık acpi=off yazıncada giremiyorum
« Son Düzenleme: 10 Haziran 2015, 10:50:47 Gönderen: smtlcasm »
« Yanıtla #50 : 10 Haziran 2015, 10:57:30 »
CTRL+ALT+F1 tuşlarına birlikte basarak TTY1 uçbirimine (siyah bir terminal ekranıdır) ulaşmayı deneyiniz. Bu alanda kullanıcı adı ve şifrenizi girerek oturum açınız. Sonra aşağıdaki komut ile oluşturulan xorg.conf dosyasını siliniz (Dikkat, X11'deki x harfi büyük olacak).
Sonra aşağıdaki komut ile masaüstüne ulaşmayı deneyiniz.
startx
Çevrimdışı smtlcasm
  • İleti: 40
« Yanıtla #51 : 10 Haziran 2015, 11:07:27 »
Böyle bir şey cıktı. Şimdi ne yapıcam?
« Yanıtla #52 : 10 Haziran 2015, 11:45:51 »
Şimdi aşağıdaki komutlarla yapılandırma dosyası oluşturup sistemi yeniden başlatmayı deneyiniz.
sudo amdconfig --px-dgpu
Sorun olursa yine TTY1 üzerinden yapılan işlemleri uygularsınız.
Çevrimdışı smtlcasm
  • İleti: 40
« Yanıtla #53 : 10 Haziran 2015, 12:04:45 »
Yüklenmiş ama masaüstü hatası veriyor bir önceki yanıttaki gibi ne yapmam lazım.
« Yanıtla #54 : 10 Haziran 2015, 12:09:18 »
fglrxinfo
amdconfig --pxl
Çevrimdışı smtlcasm
  • İleti: 40
« Yanıtla #55 : 10 Haziran 2015, 12:17:59 »
fglrxinfo
amdconfig --pxl
uç birime nasıl gireceğim buradan Fallback Mode'dayım
« Yanıtla #56 : 10 Haziran 2015, 12:32:47 »
Uçbirim, Donatılar (Accessories) altındadır.
Çevrimdışı smtlcasm
  • İleti: 40
« Yanıtla #57 : 10 Haziran 2015, 12:42:25 »
Bakın uçbirim yok ne yapıcam?
« Yanıtla #58 : 10 Haziran 2015, 12:47:59 »
Masaüstüne sağ tıklayın, açılan içerik menüsünde "Open in Terminal" seçeneği olmalı. Bu şekilde ulaşamdı iseniz menü içinde arayın, ismi Terminal olarak geçer.
Çevrimdışı smtlcasm
  • İleti: 40
« Yanıtla #59 : 10 Haziran 2015, 12:49:16 »
tamam buldum.Cıktı burada:
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  155 (GLX)
  Minor opcode of failed request:  19 (X_GLXQueryServerString)
  Serial number of failed request:  12
  Current serial number in output stream:  12
smtlcasm@memo-PC ~/Desktop $ glxinfo | grep render
smtlcasm@memo-PC ~/Desktop $ amdconfig --pxl
No layout section was found in the file: '/etc/X11/xorg.conf'.
Please run 'aticonfig --initial' first or modify your configuration file manually and run aticonfig again.
amdconfig: parsing the command-line failed.
