Gönderen Konu: Sistem Yavaş Açılıyor  (Okunma sayısı 7541 defa)
Çevrimdışı Scipio
  • İleti: 353
« : 19 Haziran 2015, 11:32:00 »
Sistem çok yavaş açılıyor. dmesg çıktısı burada:
http://paste2.org/cKtG5K53
Ynt: Sistem Yavaş Açılıyor
« Yanıtla #1 : 19 Haziran 2015, 11:59:45 »
cat /etc/modprobe.d/*bbswitch*
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #2 : 19 Haziran 2015, 12:00:18 »
cat: /etc/modprobe.d/*bbswitch*: No such file or directory
« Yanıtla #3 : 19 Haziran 2015, 12:12:29 »
dpkg -l | egrep 'bbswitch|nvidia'
cat /etc/modprobe.d/*bumblebee*
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #4 : 19 Haziran 2015, 12:13:37 »
ii  bbswitch-dkms                               0.8-1~trustyppa1                                    all          Interface for toggling the power on NVIDIA Optimus video cards
ii  bumblebee-nvidia                            3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-349                                  349.16-0ubuntu0~xedgers14.04.1                      amd64        NVIDIA binary driver - version 349.16
ii  nvidia-settings                             352.09-0ubuntu0~xedgers14.04.1                      amd64        Tool for configuring the NVIDIA graphics driver
# installed by bumblebee-nvidia
# do not automatically load nouveau as it may prevent nvidia from loading
blacklist nouveau
# do not automatically load nvidia as it's unloaded anyway when bumblebeed
# starts and may fail bumblebeed to disable the card in a race condition.
blacklist nvidia
blacklist nvidia-current
blacklist nvidia-current-updates
# 304
blacklist nvidia-304
blacklist nvidia-304-updates
blacklist nvidia-experimental-304
# 310
blacklist nvidia-310
blacklist nvidia-310-updates
blacklist nvidia-experimental-310
# 313
blacklist nvidia-313
blacklist nvidia-313-updates
blacklist nvidia-experimental-313
# 319
blacklist nvidia-319
blacklist nvidia-319-updates
blacklist nvidia-experimental-319
# 325
blacklist nvidia-325
blacklist nvidia-325-updates
blacklist nvidia-experimental-325
# 331
blacklist nvidia-331
blacklist nvidia-331-updates
blacklist nvidia-experimental-331
# 334
blacklist nvidia-334
blacklist nvidia-334-updates
blacklist nvidia-experimental-334
# 337
blacklist nvidia-337
blacklist nvidia-337-updates
blacklist nvidia-experimental-337
« Yanıtla #5 : 19 Haziran 2015, 12:22:00 »
Aşağıdaki komut ile bumblebee.conf dosyasını açınız.
sudo gedit /etc/modprobe.d/bumblebee.conf
Dosyanın en altına aşağıdaki satırlerı ekleyip dosyayı kaydediniz.
blacklist nvidia-340
blacklist nvidia-346
blacklist nvidia-349
Sistemi yeniden başlatmayı deneyiniz.
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #6 : 19 Haziran 2015, 12:48:22 »
Bir faydası olmadı maalesef.
« Yanıtla #7 : 19 Haziran 2015, 13:58:00 »
Güncelleme Yöneticisi => Görünüm menüsü => Linux çekirdekleri bölümünden depodaki şu anson sürüm çekirdek olan 3.19.0-21 olanı kurunuz ve sistemi bununla açamayı deneyiniz. Sorun devam ederse dmesg komutunun çıktısını yeniden paylaşınız. Sorun çözülürse Linux çekirdekleri aracı ile elle kurduğunuz çekirdeğin 3.19.8-031908 sürümünü kaldırınız.
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #8 : 19 Haziran 2015, 14:19:15 »
Maalesef hala aynı. Süre tuttum 60 saniye sürdü tam olarak açılması. 40 saniye giriş ekranına gelmesi sürüyor. 20 saniye Cinnamon'un açılması.
http://paste2.org/HtvAxDA8
« Yanıtla #9 : 19 Haziran 2015, 14:50:35 »
Sistemi 3.16.x sürüm çekirdek ile açınca durum değişiyor mu?
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #10 : 19 Haziran 2015, 16:51:56 »
Onda da aynı.
« Yanıtla #11 : 22 Haziran 2015, 10:31:46 »
Peki bu sorun Nvidia-349 sürücüsüne geçiş sonrası mı oluştu?
http://forum.linuxmint.net.tr/index.php?topic=3415.msg21737#msg21737
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #12 : 22 Haziran 2015, 16:41:43 »
Hayır ondan önce oluştu. Tam olarak hatırlamıyorum ama ilk nvidia sürücüsünü kurmamla birlikte başlamış olabilir.
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #13 : 03 Eylül 2015, 10:24:55 »
[member=8]Butterfly[/member], sanırım bu durum belli bir kullanımdan sonra oluşuyor. Yeniden kurulum sonrası hızlıydı ama yine aynı durum oldu. 35 saniye falan boot etmesi sürüyor. Ayrıca Cinnamon'un açılışı da 10 saniye falan sürüyor. Sorun Cinnamon mu acaba diye Mate'yi kurdum. O da aynı.
Edit: dmesg çıktısı: http://paste2.org/bkkwKHU6
