Gönderen Konu: Bilgisayarımda genel bir yavaşlık var.  (Okunma sayısı 3198 defa)
« : 02 Temmuz 2015, 11:29:14 »
2 gb lık ram ve intel pentium processor 1.73 GHz lik işlemcili bir laptopa linux mint 17.1 mate 1.8.1 kurulumu yaptım. Pc de bir klasöre yada herhangi bir icona tıladığımda işlemci %100 oluyor ve pc donuyor işlem yapmama izin vermiyor.
Bu konuda yardımcı olabilirmisiniz lütfen.
cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17.1
DISTRIB_CODENAME=rebecca
lspci -nnk | grep -iA2 net
06:05.0 Network controller [0280]: Intel Corporation PRO/Wireless 2200BG [Calexico2] Network Connection [8086:4220] (rev 05)
Subsystem: Hewlett-Packard Company nc6120/nx8220/nw8240 [103c:12f6]
Kernel driver in use: ipw2200
06:07.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [10ec:8139] (rev 10)
Subsystem: Hewlett-Packard Company Device [103c:309d]
Kernel driver in use: 8139too
uname -rm
3.13.0-37-generic i686
lsusb
Bus 004 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
inxi -Nx
Network:   Card-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
           driver: 8139too ver: 0.9.28 port: 3000 bus-ID: 06:07.0
           Card-2: Intel PRO/Wireless 2200BG [Calexico2] Network Connection driver: ipw2200 ver: 1.2.2kmprq bus-ID: 06:05.0
inxi -Nx
mehmet@mehmethp ~ $ inxi -Gx
Graphics:  Card: Intel Mobile 915GM/GMS/910GML Express Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1280x800@60.0hz
           GLX Renderer: Mesa DRI Intel 915GM x86/MMX/SSE2 GLX Version: 1.4 Mesa 10.1.3 Direct Rendering: Yes
OpenGL renderer string: Mesa DRI Intel(R) 915GM x86/MMX/SSE2
00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04)
00:02.1 Display controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 04)
Screen 0: minimum 320 x 200, current 1280 x 800, maximum 32767 x 32767
LVDS1 connected 1280x800+0+0 (normal left inverted right x axis y axis) 331mm x 207mm
   1280x800       60.0*+
   1024x768       60.0
   800x600        60.3     56.2
   640x480        59.9
TV1 disconnected (normal left inverted right x axis y axis)
Ynt: Bilgisayarımda genel bir yavaşlık var.
« Yanıtla #1 : 02 Temmuz 2015, 11:57:05 »
Öncelikle aşağıdaki şekilde sisteminizi güncellemeyi deneyiniz.
Güncelleme Yöneticisi => Düzenle menüsü => Tercihler => 4. seviye güncelleme seviyesini etkinleştiriniz ve sisteminizi güncelleyiniz.
Güncelleme Yöneticisi => Görünüm menüsü => Linux Çekirdekleri => En son çekirdek (şu an için 3.19.0-21) sürümünü yüklemeyi ve sisteminizi yeniden başlatmayı deneyiniz.
Sonrasında sisteminizi yeniden başlatınız.
« Yanıtla #2 : 02 Temmuz 2015, 12:33:17 »
Hocam yaptım dediğinizi. bir klasör açtığım zaman işlemci  %100 lerde oluyor tekrardan.
« Yanıtla #3 : 02 Temmuz 2015, 13:03:56 »
Caja dosya yöneticisi => Değiştir menüsü => Tercihler => Önizleme sekmesi => tüm önizleme seçeneklerini Asla olrak değiştirmeyi dener misiniz?
Referans
Çevrimdışı ertanx
  • İleti: 59
  • Dağıtım: Linux Mint 18.1 Cinnamon x64
  • Grafik Kartı: APU Radeon R7
  • İşlemci: AMD A10-7870K
« Yanıtla #4 : 02 Temmuz 2015, 13:29:46 »
Bir ihtimal sabit sürücünüze bozuk sektör taraması ve  bellek testi yapmanizi tavsiye ederim.
« Yanıtla #5 : 02 Temmuz 2015, 13:52:10 »
sabit diski yeni aldık hocam.
« Yanıtla #6 : 03 Temmuz 2015, 14:22:31 »
İşlemciyi çok kullanan süreçler neler?
inxi -Cxçıktısında ne görünüyor?
