Gönderen Konu: Notebook Kablolu/Kablosuz Bağlantı Sorunu  (Okunma sayısı 10552 defa)
Çevrimdışı yen1_kullan1c1_
  • İleti: 7
  • Dağıtım: linuxmint 13 Mate
« : 13 Nisan 2014, 12:06:04 »
Merhaba. Dizüstü bilgisayarıma Linuxmint 13 Maya sürümünü kurdum. Ancak ne kablolu ne de kablosuz erişimim var. İki durumda da ağlar gözükmüyor. Konuyu açmadan önce biraz araştırdım forumda. Altta birkaç çıktı mevcuttur. Yardımlarınızı bekliyorum.
uname -r
3.2.0-23-generic
lspci -nnk | grep -iA2 net
02:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
Subsystem: Hewlett-Packard Company Device [103c:1508]
Kernel driver in use: b43-pci-bridge
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 02)
Subsystem: Hewlett-Packard Company Device [103c:3628]
Kernel driver in use: r8169
sudo lshw -C network
[sudo] password for administrator:
  *-network
       description: Network controller
       product: BCM4312 802.11b/g LP-PHY
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=b43-pci-bridge latency=0
       resources: irq:16 memory:d9000000-d9003fff
  *-network DISABLED
       product: RTL8111/8168B PCI Express Gigabit Ethernet controller
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: eth0
       version: 02
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=N/A latency=0 link=no multicast=yes port=MII speed=100Mbit/s
       resources: irq:47 ioport:5000(size=256) memory:d1010000-d1010fff memory:d1000000-d100ffff memory:d1020000-d102ffff
  *-network DISABLED
       physical id: 1
       logical name: wlan0
       serial: 00:25:56:87:23:ef
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=b43 driverversion=3.2.0-23-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bg
iwconfig | grep 'Power Management'
          Power Management:on
ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:24 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1680 (1.6 KB)  TX bytes:1680 (1.6 KB)
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hp-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
4: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo apt-get purge bcmwl-kernel-source
Reading package lists... Done
Building dependency tree
Package bcmwl-kernel-source is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 103 not upgraded.
echo "blacklist b43" | sudo tee -a /etc/modprobe.d/blacklist.conf
blacklist b43
echo "brcmsmac" | sudo tee -a /etc/modules
brcmsmac
sudo rfkill unblock all
lsmod
snd_hda_codec_hdmi     32474  1
parport_pc             32866  0
rfcomm                 47604  12
ppdev                  17113  0
bnep                   18281  2
hp_wmi                 18092  0
sparse_keymap          13890  1 hp_wmi
binfmt_misc            17540  1
uvcvideo               72627  0
videodev               98259  1 uvcvideo
v4l2_compat_ioctl32    17128  1 videodev
snd_hda_codec_idt      70795  1
psmouse                87603  0
serio_raw              13211  0
btusb                  18288  2
bluetooth             180104  23 rfcomm,bnep,btusb
snd_hda_intel          33773  5
snd_hda_codec         127706  3 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_intel
snd_hwdep              13668  1 snd_hda_codec
ir_lirc_codec          12859  0
lirc_dev               19204  1 ir_lirc_codec
joydev                 17693  0
ir_mce_kbd_decoder     12777  0
snd_rawmidi            30748  1 snd_seq_midi
snd_pcm                97188  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
ir_sony_decoder        12510  0
ir_jvc_decoder         12507  0
rc_rc6_mce             12502  0
ir_rc6_decoder         12507  0
ir_rc5_decoder         12507  0
ene_ir                 18457  0
ir_nec_decoder         12507  0
wmi                    19256  1 hp_wmi
rc_core                26412  10 ir_lirc_codec,ir_mce_kbd_decoder,ir_sony_decoder,ir_jvc_decoder,rc_rc6_mce,ir_rc6_decoder,ir_rc5_decoder,ene_ir,ir_nec_decoder
hp_accel               25976  0
lis3lv02d              19876  1 hp_accel
input_polldev          13896  1 lis3lv02d
video                  19596  0
snd_seq                61896  2 snd_seq_midi,snd_seq_midi_event
jmb38x_ms              17646  0
memstick               16569  1 jmb38x_ms
mac_hid                13253  0
snd_timer              29990  2 snd_pcm,snd_seq
snd_seq_device         14540  3 snd_seq_midi,snd_rawmidi,snd_seq
brcmsmac              570859  0
radeon                804372  2
mac80211              506816  1 brcmsmac
brcmutil               15139  1 brcmsmac
snd                    78855  20 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_rawmidi,snd_pcm,snd_seq,snd_timer,snd_seq_device
ttm                    76949  1 radeon
drm_kms_helper         46978  1 radeon
drm                   242038  4 radeon,ttm,drm_kms_helper
i2c_algo_bit           13423  1 radeon
cfg80211              205544  2 brcmsmac,mac80211
soundcore              15091  1 snd
snd_page_alloc         18529  2 snd_hda_intel,snd_pcm
crc8                   12893  1 brcmsmac
cordic                 12535  1 brcmsmac
lp                     17799  0
parport                46562  3 parport_pc,ppdev,lp
sdhci_pci              18826  0
sdhci                  33205  1 sdhci_pci
firewire_ohci          41000  0
usbhid                 47199  0
hid                    99559  1 usbhid
firewire_core          63558  1 firewire_ohci
crc_itu_t              12707  1 firewire_core
ssb                    52752  0
r8169                  62099  0
sudo apt-get install bcmwl-kernel-source
The following NEW packages will be installed:
  bcmwl-kernel-source
0 upgraded, 1 newly installed, 0 to remove and 103 not upgraded.
Need to get 1.151 kB of archives.
After this operation, 3.514 kB of additional disk space will be used.
Err http://archive.ubuntu.com/ubuntu/ precise-updates/restricted bcmwl-kernel-source amd64 5.100.82.38+bdcom-0ubuntu6.1
  Could not resolve 'archive.ubuntu.com'
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_5.100.82.38+bdcom-0ubuntu6.1_amd64.deb  Could not resolve 'archive.ubuntu.com'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
sudo modprobe -rv brcmsmac
rmmod /lib/modules/3.2.0-23-generic/kernel/drivers/net/wireless/brcm80211/brcmsmac/brcmsmac.ko
rmmod /lib/modules/3.2.0-23-generic/kernel/net/mac80211/mac80211.ko
rmmod /lib/modules/3.2.0-23-generic/kernel/drivers/net/wireless/brcm80211/brcmutil/brcmutil.ko
rmmod /lib/modules/3.2.0-23-generic/kernel/net/wireless/cfg80211.ko
rmmod /lib/modules/3.2.0-23-generic/kernel/lib/crc8.ko
rmmod /lib/modules/3.2.0-23-generic/kernel/lib/cordic.ko
sudo modprobe -v wl
FATAL: Module wl not found.
Ynt: Notebook Kablolu/Kablosuz Bağlantı Sorunu
« Yanıtla #1 : 13 Nisan 2014, 12:42:31 »
Sizin kablosuz ağ sürücünüz (BCM4312 802.11b/g LP-PHY) için sisteminize uygun aşağıdaki paketleri indirip sağ-tık gdebi ile kurmayı deneyebilirsiniz.
32 Bit için
archive.ubuntu.com/ubuntu/pool/main/b/b43-fwcutter/b43-fwcutter_015-9_i386.deb
64 Bit için
archive.ubuntu.com/ubuntu/pool/main/b/b43-fwcutter/b43-fwcutter_015-9_amd64.deb
Kablolu ağ kartı sürücü için bağlantı sağladıktan sonra aşağıdaki komutlar ile yapılacak güncelleme sorunu çözebilir.
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get install -f
Not : Yukarıdaki komutlar ile elle Güncelleme sırasında bazı ayar dosyalarının değiştirilmesi istenebilir. Bu durumda (N tuşu ile) varsayılan dosyaların korunmasını sağlamalısınız.
Sistemi yeniden başlattığınız güncel bir çekirdek yüklenmiş olacaktır ve varsayılan olarak başlatılıyor olacaktır.
Linux Mint 13 eski (fakat uzun süreli desteği mevcut) bir sürüm olduğu için bol miktarda güncelleme alacağınızı unutmayınız.
  • İleti: 7
« Yanıtla #2 : 13 Nisan 2014, 14:21:16 »
Önerilerinizi sırasıyla yaptım. Önce kablosuz bağdaştırıcı sürücüsünü yükledim. Sistemi yeniden başlattım. Ancak değişen birşey olmadı. Yine de komutları sırayla girdim. Sistemi tekrar yeniden başlattım. Sonuç hala aynı. Kablolu ağ da gözükmüyor. Kablosuz ağlar da gözükmüyor.
« Yanıtla #3 : 13 Nisan 2014, 15:51:01 »
Önce konuyu açmadan nce yaptıklarınızı geri alınız.
Aşağıdaki komut ile blacklist.conf dosyasını açınız.
sudo gedit /etc/modprobe.d/blacklist.conf
Açılan dosyada aşağıdaki satırı bulup siliniz.
blacklist b43
Aşağıdaki komut ile modules dosyasını açınız.
sudo gedit /etc/modules
brcmsmac
Sonra aşağıdaki bağlantıdan firmware-b43-lpphy-installer paketini indirip sağ tık Gdebi ile kurunuz.
archive.ubuntu.com/ubuntu/pool/multiverse/b/b43-fwcutter/firmware-b43-lpphy-installer_015-9_all.deb
Yukarıdaki firmware-b43-lpphy-installer paketi bağımlılık olarak b43-fwcutter paketinin kurulumasını ister, bu paketi önceki mesajda anlatılan biçimde kurmuş olmalısınız.
Şimdi sisteminizi yeniden başlatmayı deneyiniz.
« Yanıtla #4 : 13 Nisan 2014, 16:21:16 »
Kablolu ağ sorununu aşağıdaki komutları sırasıyla uçbirimde çalıştırarak çözmek denenebilir.
wget -c --no-check-certificate djlab.com/stuff/r8168-8.032.00.tar.bz2
tar xvf r8168-8.032.00.tar.bz2
cd r8168-8.032.00
make clean modules
sudo su
make install
depmod -a
echo "blacklist r8169" >> /etc/modprobe.d/blacklist-network.conf
echo "r8168" | sudo tee -a /etc/modules
update-initramfs -u
Aşağıdaki komut ile yeni kurulan sürücü modülünü etkinleştirmeyi deneyebilirsiniz.
sudo rmmod r8169
sudo modprobe r8168
  • İleti: 7
« Yanıtla #5 : 13 Nisan 2014, 16:24:49 »
Blacklist dosyasında söylediğiniz satır değil ama şöyle bir satır vardı:
# replaced by b43 and ssb.
blacklist bcm43xx
blacklist bcm43xx satırını sildim.
Modules dosyasında ise sadece şunlar vardı:
lp
rtc
O yüzden bu dosyaya dokunmadım.
Linkteki dosyayı kurdum.Sistemi yeniden başlattım. Ancak hala kablosuz ağlar görünmüyor.
« Yanıtla #6 : 13 Nisan 2014, 19:07:37 »
Ben sizin paylaştıklarınızdan dolayı, ilgili komutları uyguladınız varsaymıştım.
Aşağıdaki komut uçbirimde çalıştırıp bcm43xx modülünü tekrar dosyaya ekleyiniz.
echo "blacklist bcm43xx" | sudo tee -a /etc/modprobe.d/blacklist.conf
Aşağıdaki komutlar ile b43 modülünü etkinleştirmeyi deneyiniz.
sudo rmmod b43
echo "options b43 pio=1 qos=0" | sudo tee -a /etc/modprobe.d/b43.conf
sudo modprobe b43
Kablolu ağ ile ilgili komutları denediniz mi, denedinizse sonuç nedir?
  • İleti: 7
« Yanıtla #7 : 13 Nisan 2014, 20:17:20 »
Öncelikle "blacklist bcm43xx" satırın tekrar ekledim. Daha sonra kablolu bağlantı için yazdığınız komutları denedim. O isimde bir dosya bulunmadığı mesajını verdi.
--2014-04-13 20:05:31--  http://djlab.com/stuff/r8168-8.032.00.tar.bz2
Resolving djlab.com (djlab.com)... failed: Name or service not known.
wget: unable to resolve host address `djlab.com'
tar: r8168-8.032.00.tar.bz2: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
« Yanıtla #8 : 13 Nisan 2014, 20:44:26 »
Kablolu ağ için sürücüyü buradan indiriniz ve kullanıcı ev dizinine (home) taşıyınız/kopyalayınız.
Sonra aşağıdaki komutlar ile uçbirimden devam ediniz.
cd
cd r8168-8.032.00
make clean modules
sudo su
make install
depmod -a
update-initramfs -u
  • İleti: 7
« Yanıtla #9 : 13 Nisan 2014, 22:32:16 »
En azından sistem ilerleme kaydetti.  :) Kablo ağı görüyor ve sürekli bağlanmaya çalışıyor. Ancak bağlantı başarısız oluyor. Verdiğiniz komutlarda sadece sonuncusunda şöyle bir uyarı verdi. Bağlanamama sebebi bu olabilir mi? Ayrıca kablolu ağın özelliklerine baktığımda mac adress 00:00:00:00:00:00 gözüküyor.
update-initramfs -u
update-initramfs: Generating /boot/initrd.img-3.2.0-23-generic
« Yanıtla #10 : 13 Nisan 2014, 23:19:57 »
lsmod
dpkg - l | egrep 'lpphy|fwcutter'
  • İleti: 7
« Yanıtla #11 : 14 Nisan 2014, 00:23:01 »
lsmod
rfcomm                 47604  0
bnep                   18281  2
bluetooth             180104  10 rfcomm,bnep
parport_pc             32866  0
ppdev                  17113  0
hp_wmi                 18092  0
binfmt_misc            17540  1
uvcvideo               72627  0
psmouse                87603  0
arc4                   12529  2
serio_raw              13211  0
rc_rc6_mce             12502  0
joydev                 17693  0
ene_ir                 18457  0
b43                   365785  0
rc_core                26412  10 ir_lirc_codec,ir_mce_kbd_decoder,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,rc_rc6_mce,ir_rc5_decoder,ene_ir,ir_nec_decoder
mac80211              506816  1 b43
video                  19596  0
cfg80211              205544  2 b43,mac80211
jmb38x_ms              17646  0
hp_accel               25976  0
wmi                    19256  1 hp_wmi
radeon                804372  2
mac_hid                13253  0
bcma                   26696  1 b43
ttm                    76949  1 radeon
snd                    78855  20 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
lp                     17799  0
sdhci_pci              18826  0
usbhid                 47199  0
hid                    99559  1 usbhid
r8168                 244911  0
ssb                    52752  1 b43
dpkg -l | egrep 'lpphy|fwcutter'
ii  b43-fwcutter                           1:015-9                                 Utility for extracting Broadcom 43xx firmware
iF  firmware-b43-lpphy-installer           1:015-9                                 Installer package for firmware for the b43 driver (LP-PHY version)
« Yanıtla #12 : 14 Nisan 2014, 09:13:25 »
Aşağıdaki komut ile firmware-b43-lpphy-installer ve b43-fwcutter paketini kaldırıp,
sudo apt-get purge firmware-b43-lpphy-installer b43-fwcutter
Aşağıdaki bağlantılardan sisteminize uygun bcmwl-kernel-source paketini indirip sağ tık Gdebi ile kurmayı dener misiniz?
32 Bit için
archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_6.20.155.1+bdcom-0ubuntu0.0.2_i386.deb
64 bit için
archive.ubuntu.com/ubuntu/pool/restricted/b/bcmwl/bcmwl-kernel-source_6.20.155.1+bdcom-0ubuntu0.0.2_amd64.deb
Kurulum sonrası sistemi aşağıdaki komutları sırasıyla uçbirimde çalıştırıp wl sürücü modülünü etkinleştirmeyi deneyiniz.
sudo modprobe -rv brcmsmac b43
sudo modprobe -v wl
  • İleti: 7
« Yanıtla #13 : 14 Nisan 2014, 17:46:50 »
Kablosuz ağa bağlanabiliyor artık. Ancak kablolu ağ da aynı durum devam ediyor. Sanırım sürücü güncellemesinin ardından çözülür o da. Çok teşekkür ederim zaman ayırdığınız için.
« Yanıtla #14 : 14 Nisan 2014, 20:06:04 »
Güncelleme yaptıktan sonra aşağıdaki komut ile r8168 sürücü modülünü pasifleştirip, r8169 sürücü modülünü etkinleştirmeyi deneyiniz.
sudo rmmod r8168
sudo modprobe r8169
Bu şekilde sorun çözülürse ayarları kalıcı hale getirebiliriz.
Güncellemeyi önceki mesajlarda bahsedilen şekilde uçbirim yardımıyla elle yapmayı deneyiniz.
