Gönderen Konu: Toshiba Satellite L755 Ekran Parlaklığı Ayar Sorunu  (Okunma sayısı 7258 defa)
Çevrimdışı saprofit89
  • İleti: 6
  • Anime sever - hemşire
  • Dağıtım: Linux Mint 17
  • Masaüstü Ortamı: xfce
  • Grafik Kartı: Nvidia GT 525M
  • İşlemci: i5-2410M 2.30GHz
Ekran parlaklığımı ayarlayamıyorum. (Konu taşındığı için düzeltme ihtiyacı duydum.)
sonucu,
System:    Host: usermint-SATELLITE-L755 Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2)
           Desktop: Xfce 4.11.8 (Gtk 2.24.23) Distro: Linux Mint 17.1 Rebecca
Machine:   System: TOSHIBA (portable) product: SATELLITE L755 version: PSK2YE-04D00VTE
           Mobo: Intel model: N/A Bios: INSYDE version: 3.60 date: 06/26/2012
CPU:       Dual core Intel Core i5-2410M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9178.88
           Clock Speeds: 1: 800.00 MHz 2: 800.00 MHz 3: 800.00 MHz 4: 800.00 MHz
Graphics:  Card: NVIDIA GF108M [GeForce GT 525M] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1366x768@60.0hz
           GLX Renderer: GeForce GT 525M/PCIe/SSE2 GLX Version: 4.4.0 NVIDIA 331.113 Direct Rendering: Yes
Audio:     Card-1: NVIDIA GF108 High Definition Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
           Card-2: Intel 6 Series/C200 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet driver: atl1c ver: 1.0.1.1-NAPI port: 2000 bus-ID: 0a:00.0
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 09:00.0
Drives:    HDD Total Size: 640.1GB (46.6% used) 1: id: /dev/sda model: TOSHIBA_MK6475GS size: 640.1GB
Partition: ID: / size: 147G used: 15G (11%) fs: ext4 ID: swap-1 size: 8.17GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 63.0C mobo: N/A gpu: 0.0:56C
Info:      Processes: 205 Uptime: 1:45 Memory: 1359.2/3935.0MB Runlevel: 2 Gcc sys: 4.8.4 Client: Shell inxi: 1.8.4
« Son Düzenleme: 03 Ekim 2015, 10:51:45 Gönderen: saprofit89 »
Seni öldürmeyen güçlendirir...
Ynt: Toshiba Satellite L755 Ekran Parlaklığı Ayar Sorunu
« Yanıtla #1 : 09 Temmuz 2015, 15:48:58 »
Foruma hoşgeldiniz. Konu uygun kategoriye taşınmıştır. Konu Açarken Dikkat Edilmesi Gerekenler
4. ve 5. seviye güncelleştirmeleri yaptıktan sonra tekrar parlaklığı ayarlamayı dener misiniz?  [Rehber] Linux Mint Güncelleme Yöneticisi
sudo echo 40 > /sys/class/backlight/acpi_video0/brightnesskomutuyla parlaklıkta bir değişim oluyor mu?(40 yazan yer parlaklık yüzdesidir.)
  • İleti: 6
« Yanıtla #2 : 14 Eylül 2015, 17:13:08 »
Sistemim güncel.
Böyle oluyor...  :'(
usermint@usermint-SATELLITE-L755 ~ $ sudo echo 40 > /sys/class/backlight/acpi_video0/brightness
bash: /sys/class/backlight/acpi_video0/brightness: Erişim engellendi
« Yanıtla #3 : 14 Eylül 2015, 17:37:08 »
sudo sh -c "echo 40 > /sys/class/backlight/acpi_video0/brightness"
olarak denediğimizde değişen bir şey oluyor mu ?
  • İleti: 6
« Yanıtla #4 : 03 Ekim 2015, 10:26:39 »
Böyle oluyor... :(
usermint@usermint-SATELLITE-L755 ~ $ sudo sh -c "echo 40 > /sys/class/backlight/acpi_video0/brightness"
[sudo] password for usermint:
sh: echo: I/O error
Sıkıntının nereden olduğunu bilsem onu söyleyeceğim de ilk kez Linux kullanıyorum.  :-\
Sistem durumu ile alakalı bilgi alabileceğim başka kod var mı?
« Yanıtla #5 : 03 Ekim 2015, 10:29:02 »
Buradaki öneriyi dener misiniz?
Birde aşağıdaki komutların çıktısına bakalım.
dpkg -l | grep nvidia
« Son Düzenleme: 03 Ekim 2015, 10:31:28 Gönderen: Butterfly »
  • İleti: 6
« Yanıtla #6 : 22 Aralık 2016, 11:28:13 »
Konuyu hortlattığım için kusuruma bakmayın sorunu çözemediğim için devam ediyorum.
Söylediğinizi yaptım, şimdi ne yapmam gerekir?
usermint@usermint-SATELLITE-L755 ~ $ cat /etc/X!!/xorg.conf
cat /etc/Xsudo su /xorg.conf
cat: /etc/Xsudo: Böyle bir dosya ya da dizin yok
cat: su: Böyle bir dosya ya da dizin yok
cat: /xorg.conf: Böyle bir dosya ya da dizin yok
usermint@usermint-SATELLITE-L755 ~ $ dpkg -l | grep nvidia
ii  nvidia-331                                  340.76-0ubuntu0.1                                   amd64        Transitional package for nvidia-331
ii  nvidia-331-uvm                              340.76-0ubuntu0.1                                   amd64        Transitional package for nvidia-340-uvm
ii  nvidia-340                                  340.76-0ubuntu0.1                                   amd64        NVIDIA binary driver - version 340.76
ii  nvidia-340-uvm                              340.76-0ubuntu0.1                                   amd64        Transitional package for nvidia-340
rc  nvidia-libopencl1-331                       331.113-0ubuntu0.0.4                                amd64        NVIDIA OpenCL Driver and ICD Loader library
ii  nvidia-opencl-icd-331                       340.76-0ubuntu0.1                                   amd64        Transitional package for nvidia-opencl-icd-340
ii  nvidia-opencl-icd-340                       340.76-0ubuntu0.1                                   amd64        NVIDIA OpenCL ICD
ii  nvidia-settings                             331.20-0ubuntu8                                     amd64        Tool for configuring the NVIDIA graphics driver
« Yanıtla #7 : 22 Aralık 2016, 16:08:24 »
İlk komutun çıktısı hatalı, daha doğrusu komutu yanlış yazdığınız için hatalı çıktı almışsınız. Komutu kopyalayıp çıktısını bu şekilde almayı deneyiniz.
