Gönderen Konu: Küp efekti için gerekli OpenGL hata veriyor  (Okunma sayısı 4516 defa)
Çevrimdışı hwpplayer1
  • İleti: 139
« : 14 Temmuz 2015, 01:16:00 »
Küp efekti için gerekli OpenGL seçeneği hata veriyor.Panel tarafı ve drop down menü seçenekleri tamamen kararıyor.Nerede hasar var acaba ? Teşekkürler.
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > uname -rm
4.1.2-040102-generic x86_64
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > inxi -Gx
           X.Org: 1.15.1 drivers: (unloaded: fbdev,vesa) FAILED: nouveau,intel Resolution: 1600x900@60.0hz
           GLX Renderer: Mesa DRI Intel Haswell Mobile GLX Version: 3.0 Mesa 10.1.3 Direct Rendering: Yes
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > glxinfo | grep render
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > lspci | egrep 'VGA|3D|Display'
01:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev ff)
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > xrandr
Screen 0: minimum 8 x 8, current 1600 x 900, maximum 32767 x 32767
eDP1 connected primary 1600x900+0+0 (normal left inverted right x axis y axis) 388mm x 219mm
   1600x900       60.0*+
   1440x900       59.9
   1368x768       60.0
   1360x768       59.8     60.0
   1152x864       60.0
   1280x720       60.0
   1024x768       60.0
   1024x576       60.0
   960x540        60.0
   800x600        60.3     56.2
   864x486        60.0
   800x450        60.0
   640x480        59.9
   720x405        60.0
   640x360        60.0
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > cat /etc/X11/xorg.conf
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > sudo cat /etc/X11/xorg.conf
[sudo] password for hwpplayer1:
« Son Düzenleme: 14 Temmuz 2015, 01:27:10 Gönderen: hwpplayer1 »
GNU Emacs :)
  • İleti: 139
Ynt: Küp efekti için gerekli OpenGL hata veriyor
« Yanıtla #2 : 15 Temmuz 2015, 21:36:35 »
Aradığınız şey burada : [Nasıl] Intel + Nvidia Optimus Destekli Hibrid GPU İçin Bumblebee Kurulumu
Buradan devam etmemiz uygunsa yazıyorum :
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > optirun -vvv glxgears
[ 8694.936563] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 8694.937107] [INFO]Configured driver: nvidia
[ 8694.937347] [DEBUG]optirun version 3.2.1 starting...
[ 8694.937386] [DEBUG]Active configuration:
[ 8694.937409] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 8694.937430] [DEBUG] X display: :8
[ 8694.937452] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-352:/usr/lib32/nvidia-352
[ 8694.937475] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 8694.937496] [DEBUG] Accel/display bridge: auto
[ 8694.937517] [DEBUG] VGL Compression: proxy
[ 8694.937538] [DEBUG] VGLrun extra options:
[ 8694.937559] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 8694.937667] [DEBUG]Using auto-detected bridge virtualgl
[ 8696.317145] [INFO]Response: Yes. X is active.
[ 8696.317162] [INFO]Running application using virtualgl.
[ 8696.317279] [DEBUG]Process vglrun started, PID 18894.
11783 frames in 5.0 seconds = 2356.433 FPS
11952 frames in 5.0 seconds = 2390.345 FPS
[VGL] ERROR: in readback--
[VGL]    247: Window has been deleted by window manager
[ 8706.565270] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 8706.565313] [DEBUG]Socket closed.
[ 8706.565360] [DEBUG]Killing all remaining processes.
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > cat /etc/bumblebee/bumblebee.conf
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-352
PMMethod=auto
LibraryPath=/usr/lib/nvidia-352:/usr/lib32/nvidia-352
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-352/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > cat /etc/bumblebee/xorg.conf.nvidia
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl'
ii  bumblebee                                   3.2.1-90~trustyppa1                                    amd64        NVIDIA Optimus support
ii  bumblebee-nvidia                            3.2.1-90~trustyppa1                                    amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
rc  nvidia-331                                  331.113-0ubuntu0.0.4                                   amd64        NVIDIA binary driver - version 331.113
rc  nvidia-349                                  349.16-0ubuntu0~xedgers14.04.1                         amd64        NVIDIA binary driver - version 349.16
ii  nvidia-352                                  352.21-0ubuntu0~xedgers14.04.1                         amd64        NVIDIA binary driver - version 352.21
ii  nvidia-common                               1:0.2.91.4linuxmint1                                   amd64        transitional package for ubuntu-drivers-common
ii  nvidia-settings                             352.21-0ubuntu0~xedgers14.04.1                         amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20131127-1~trustyppa1                                  amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20131127-1~trustyppa1                                  amd64        Shared libraries for primus
ii  primus-libs:i386                            20131127-1~trustyppa1                                  i386         Shared libraries for primus
ii  primus-libs-ia32                            20131127-1~trustyppa1                                  i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.3.3-1~trustyppa1                                     amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.3.3-1~trustyppa1                                     amd64        Library files for virtualgl
Bana öyle geliyor ki Bumblebee sorunsuz çalışıyor.Sorun küçük bir yazılım parçasında olabilir.Nomodeset ile açmayı denersem düzelebilir.Teşekkürler.
GNU Emacs :)
Çevrimdışı oaydik
  • İleti: 75
  • Dağıtım: Debian-Gnome, LMDE
« Yanıtla #3 : 15 Temmuz 2015, 22:01:37 »
17.1 sürümünde bende de benzer hatalar vermişti ama 17.2 sürümünde gayet güzel çalışıyor ve her yönden daha kararlı.
