Gönderen Konu: [Çözüldü] Linux Mint 17.2 UEFI kurulumu sonrası  (Okunma sayısı 4625 defa)
Çevrimdışı enesscelik
  • İleti: 55
« : 14 Temmuz 2015, 01:23:37 »
Merhaba arkadaşlar. Bugün sizlere kurulum sonrasında yaşadığım bir sorundan bahsedeceğim. Daha öncelerden de Linux Mint kullanmış biri olarak bu sefer Linux'a geçme sebebim Python oldu. Linux Mint'i Windows 8.1'in yanına UEFI modunda kurdum. Ancak kurulumdan sonra bootloader tarzı birşey beklerken direk Linux Mint açıldı. Acaba nerede yanlış yapmış olabilirim?
Sistemden bazı görüntüler
enesscelik@KASIMENES-PC ~ $ inxi -Fxz
System:    Host: KASIMENES-PC Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2)
           Desktop: Cinnamon 2.6.11  Distro: Linux Mint 17.2 Rafaela
Machine:   System: SAMSUNG product: 350V5C/351V5C/3540VC/3440VC version: P09ABE.012.CP
           Mobo: SAMSUNG model: NP350V5C-S0KTR version: BOARD 00 Bios: American Megatrends version: P09ABE date: 07/04/2013
CPU:       Dual core Intel Core i5-3230M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10376.1
           Clock Speeds: 1: 1202.601 MHz 2: 2453.140 MHz 3: 1200.164 MHz 4: 1200.367 MHz
           Card-2: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD 7500M/7600M Series] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: ati,radeon,intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.1hz
Audio:     Card: Intel 7 Series/C210 Series Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k bus-ID: 03:00.0
           driver: r8169 ver: 2.3LK-NAPI port: 2000 bus-ID: 02:00.0
           Card-3: Atheros usb-ID: 001-006
Drives:    HDD Total Size: 750.2GB (0.7% used) 1: id: /dev/sda model: Hitachi_HTS72757 size: 750.2GB
Partition: ID: / size: 20G used: 4.6G (25%) fs: ext4 ID: /home size: 71G used: 72M (1%) fs: ext4
           ID: swap-1 size: 8.59GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 54.0C mobo: N/A gpu: N/A
Info:      Processes: 193 Uptime: 2 min Memory: 530.1/7876.8MB Runlevel: 2 Gcc sys: 4.8.2
Edit: Windows Boot Manager'dan boot edince Windows sorunsuz şekilde açılıyor. Diğer iki seçenekte ise Mint açılıyor direk.
« Son Düzenleme: 14 Temmuz 2015, 13:38:07 Gönderen: enesscelik »
Ynt: Linux Mint 17.2 UEFI kurulumu sonrası
« Yanıtla #1 : 14 Temmuz 2015, 08:45:42 »
Aşağıdaki komut ile Windows'u Grub önyükleyici menüsüne eklemeyi deneyiniz.
sudo update-grub
  • İleti: 55
« Yanıtla #2 : 14 Temmuz 2015, 09:00:38 »
Verdiğiniz komutu verince şu şekilde bir çıktı verdi:
enesscelik@KASIMENES-PC ~ $ sudo update-grub
[sudo] password for enesscelik:
Bulunan linux kalıbı: /boot/vmlinuz-3.16.0-38-generic
Bulunan initrd kalıbı: /boot/initrd.img-3.16.0-38-generic
  No volume groups found
Adding boot menu entry for EFI firmware configuration
bitti
Sistemi yeniden başlattım. Değişen herhangi birşey olmadı. Direk Linux Mint'i açıyor. Grubu hiç göstermiyor
Çevrimdışı 1453ubuntu
  • İleti: 18
  • Dağıtım: 17.2
  • Masaüstü Ortamı: cinnamon 32bit
  • Grafik Kartı: AMD/ATİ RADEON HD 4350/4550
  • İşlemci: Pentium E6300@2.80x2
« Yanıtla #3 : 14 Temmuz 2015, 12:14:24 »
ilk yol
sudo add-apt-repository ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair
boot-repair
Ayrıntılı kısım
Adding boot menu entry for EFI firmware configuration (bu kısım Google aratınca Bios Güncellemesi ile alakalı dokumanlar çıkıyor )
https://www.thomas-krenn.com/en/wiki/Restore_Ubuntu_UEFI_Boot_Entries_after_BIOS_Update
Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.(bunun için ise şöyle bir çözüm var )
sudo update-grubGenerating grub.cfg ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Found linux image: /boot/vmlinuz-3.11.0-19-generic
Found initrd image: /boot/initrd.img-3.11.0-19-generic
Found linux image: /boot/vmlinuz-3.11.0-15-generic
Found initrd image: /boot/initrd.img-3.11.0-15-generic
done
sudo gedit /etc/default/grubGRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=countdown
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i915.modeset=1"
GRUB_CMDLINE_LINUX=""
done
https://bugs.launchpad.net/ubuntu/+source/grub2/+bug/1258597
« Son Düzenleme: 14 Temmuz 2015, 12:48:17 Gönderen: 1453ubuntu »
  • İleti: 55
« Yanıtla #4 : 14 Temmuz 2015, 12:41:29 »
Yanitlariniz  icin  tesekkurler.  En son ekran kartı guncellemesinden  sonra sisteme ulaşamıyorum. En kısa zamanda bakacağım.
« Yanıtla #5 : 14 Temmuz 2015, 13:02:22 »
Boot Repair ile burada önerildiği biçimde önyükleyiciyi yeniden kurmak denenebilir. Öncesinde Windows tarafında hızlı başlatma/kapatma ve hibernite seçeneğini kapatmak faydalı olabilir. Nasıl yapılacağı ile arama motorlarında örnekler bulabilirsiniz.
  • İleti: 55
[Çözüldü] Ynt: Linux Mint 17.2 UEFI kurulumu sonrası
« Yanıtla #6 : 14 Temmuz 2015, 13:08:45 »
Tamamdır, deneyeceğim.
Edit: [member=2034]1453ubuntu[/member] çözümünü şimdi denedim. Ekranda 10 dan geri saymaya başladı.  [member=8]Butterfly[/member] linkteki gibi yapınca sorun ortadan kalktı.  Yanıtlarınız için çok teşekkür ederim.
« Son Düzenleme: 14 Temmuz 2015, 13:37:37 Gönderen: enesscelik »
« Yanıtla #7 : 14 Temmuz 2015, 13:42:47 »
Rica ederiz, sorun çözüldüğü için konu kilitlenmiştir.
