Evet, belli bir süre sonra diskler unmount konumuna geçiyor.
derin@green ~ $ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
LABEL=Yedek /mnt/Yedek auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-label/Depo /mnt/Depo auto nosuid,nodev,nofail,x-gvfs-show 0 0
derin@green ~ $ df -h
Dosyasistemi Boy Dolu Boş Kull% Bağlanılan yer
/dev/sda1 184G 14G 161G 8% /
none 4,0K 0 4,0K 0% /sys/fs/cgroup
udev 3,8G 4,0K 3,8G 1% /dev
tmpfs 772M 1,4M 771M 1% /run
none 5,0M 0 5,0M 0% /run/lock
none 3,8G 40M 3,8G 2% /run/shm
none 100M 24K 100M 1% /run/user
/dev/sdb1 1,4T 1,4T 7,1G 100% /mnt/Yedek
/dev/sdc1 932G 187G 745G 21% /mnt/Depo
derin@green ~ $ sudo fdisk -l
[sudo] password for derin:
Disk /dev/sda: 200.0 GB, 200049647616 bytes
255 heads, 63 sectors/track, 24321 cylinders, toplam 390721968 sektör
Disk kimlikleyicisi: 0x000a3623
Aygıt Açılış Başlangıç Bitiş BlokSayısı Kml Sistem
/dev/sda1 * 2048 390721535 195359744 83 Linux
Disk /dev/sdb: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders, toplam 2930277168 sektör
Disk kimlikleyicisi: 0x3c2e1b0b
/dev/sdb1 2048 2930274303 1465136128 7 HPFS/NTFS/exFAT
Disk /dev/sdc: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, toplam 1953525168 sektör
Disk kimlikleyicisi: 0xf4b84f46
/dev/sdc1 63 1953525167 976762552+ 7 HPFS/NTFS/exFAT
