Gönderen Konu: Windows'un Yanına Uygun Linux Mint Kurulumu  (Okunma sayısı 4649 defa)
Çevrimdışı lthx
  • İleti: 21
  • Dağıtım: Linux Mint 17.2 Rafaela (64 bit)
« : 07 Ekim 2015, 17:52:59 »
Kullanmakta olduğum Linux Mint sisteminden çok memnunum fakat oyunlarda sıkıntı oluştuğu için sistemi baştan Windows'a çevirip yanına sistemi yormayacak Linux Mint sürümünü kurmak istiyorum.
Öncelikle Windows'u sadece oyunlar için kullanacağım geri kalan her şey için Linux Mint ;)
### SISTEM BILGILERI ###
System:    Host: SONY Kernel: 3.19.0-30-generic x86_64 (64 bit, gcc: 4.8.2)
Machine:   System: Sony product: VGN-FW41ET_H version: C601MAVK
           Mobo: Sony model: VAIO Bios: American Megatrends version: R3100Y0 date: 04/22/2009
CPU:       Dual core Intel Core2 Duo CPU T6400 (-MCP-) cache: 2048 KB flags: (lm nx sse sse2 sse3 sse4_1 ssse3) bmips: 7977.6
           Clock Speeds: 1: 1200.00 MHz 2: 1200.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV730/M96 [Mobility Radeon HD 4650/5165] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1600x900@60.0hz
           GLX Renderer: Gallium 0.4 on AMD RV730 (DRM 2.40.0, LLVM 3.6.0) GLX Version: 3.0 Mesa 11.0.1 Direct Rendering: Yes
Audio:     Card-1: Advanced Micro Devices [AMD/ATI] RV710/730 HDMI Audio [Radeon HD 4000 series]
           Card-2: Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture ver: k3.19.0-30-generic
Network:   Card-1: Intel WiFi Link 5100 driver: iwlwifi ver: in-tree: bus-ID: 06:00.0
           Card-2: Marvell 88E8055 PCI-E Gigabit Ethernet Controller driver: sky2 ver: 1.30 port: 9000 bus-ID: 08:00.0
Drives:    HDD Total Size: 320.1GB (13.0% used) 1: id: /dev/sda model: SAMSUNG_HM321HI size: 320.1GB
Partition: ID: / size: 290G used: 39G (15%) fs: ext4 ID: swap-1 size: 4.26GB used: 0.00GB (0%) fs: swap
           ID: swap-2 size: 1.03GB used: 0.00GB (0%) fs: swap ID: swap-3 size: 1.03GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 47.0C mobo: 47.0C
Info:      Processes: 170 Uptime: 36 min Memory: 687.0/3919.8MB Runlevel: 2 Gcc sys: 4.8.4
Windows 10 Pro yanına kasmaması için hangi Linux Mint sürümünü kurmalıyım?
Windows formatı gerçekleştirmem için diski NTSF formatına nasıl çevireceğim?
Düzenleme: Görüntü imgur.com sitesine yüklendi
« Son Düzenleme: 12 Ekim 2015, 19:39:15 Gönderen: Reddet »
Ynt: Windows'un Yanına Uygun Linux Mint Kurulumu
« Yanıtla #1 : 07 Ekim 2015, 21:36:24 »
Bağlantıda anlatıldığı biçimde çalışan USB/DVD ile yeni bir bölüm oluşturabilirsiniz. Yeni oluşturduğunuz bölümü NTFS olrak biçimlendirip Windows kurabilirsiniz.
[Nasıl] Gparted ile Yeni Disk Bölümü Oluşturma
Çevrimdışı lthx
  • İleti: 21
« Yanıtla #2 : 07 Ekim 2015, 21:47:58 »
Tum diski silip ntsf formatina cevirdim sonra usb windows u takıp sistemi tekrar baslattiktan sonra
error: unknown filesystem
Entering rescue mode...
grub rescue>_
Ekrani ile karsi karsiyayim. Ne yapmaliyim?
Edit: ls yazdiktan sonra cikan sonuclar (hd0) (hd0,msdos1) (hd1)
« Son Düzenleme: 07 Ekim 2015, 21:51:14 Gönderen: lthx »
« Yanıtla #3 : 07 Ekim 2015, 23:01:00 »
grub rescue>_
Diski sildiğiniz için MBR'de yüklü Grub önyükleyici grub ayar dosyasını bulamıyor ve bu sebeple ilgili hatayı veriyor. Gparted ile Disk bölümleme tablosunu da yeniden oluşturmayı deneyebilirsiniz. Ya da Windows kurulurken kendi önyükleyisini yazacağı için sorun kendiliğinden çözülür.
Çevrimdışı lthx
  • İleti: 21
« Yanıtla #4 : 07 Ekim 2015, 23:24:56 »
Window kurulum asamasina gecmiyor ki. Nasil yapacagim anlamadim. Elimde iki usb var birinde gparted live digerinde windows 10 pro. Sistemi gparted live ile boot edince diskleri boldum sildim birlestirdim ne yaptiysam hep ayni hata ile karsilastim. Bu konuda da fazla bir bilgim yok adim adim aciklarsaniz ya da bi kaynak gosterirseniz sevinirim.
« Yanıtla #5 : 08 Ekim 2015, 09:42:22 »
Gparted => Aygıt (Device) menüsü => Yeni bölüm oluştur (Create partition table) => Yeni bölümlendirme tablosu tipini seç (Select new partition table type) kısmından "msdos" seçeneğini seçip Uygula (Create) düğmesine bastığınızda disk bölümleme tablosunu sıfırlayabilirsiniz. Dikkat ediniz bu işlem geri alınamayabilir, eğer verilerinizi yedekledi ve tüm sistemi baştan kuracaksanız bu yöntemi uygulayın.
Çevrimdışı lthx
  • İleti: 21
« Yanıtla #6 : 08 Ekim 2015, 12:11:51 »
Yöntemi uyguladım bilgisayarı kapatıp windows usb flash belleğini taktım tekrar baslattım fakat setup ekranı gelmedi siyah ekranda kaldı ama bu sefer ekranda bir şey yazmıyordu.
« Yanıtla #7 : 08 Ekim 2015, 12:16:42 »
Şu an diskiniz sıfırlanmış durumda. Kurulumu nasıl yapıyorsunuz bilmiyorum ama bundan sonrası Windows ile ilgili alanların ilgi alanına girebilir. Mesela USB ile kurulum yapıyorsanız, bunu Linux altında yazdırdı iseniz sorun yaşayabilirsiniz. Linux altında Winusb isimli aracın haricindekiler Windows medyasını düzgün yazdıramaz. Bence Windows ortamında oluşturulmuş bir kurulum medyası ile yola çıkmayı deneyin.
Çevrimdışı lthx
  • İleti: 21
« Yanıtla #8 : 08 Ekim 2015, 12:19:40 »
Evet Windows'u Linux altında yazdırdım. Winusb kullanıp öyle yazdırayım o zaman. Duruma göre geri dönüş yaparım. Teşekkürler.
Edit: Winusb depoda yok sanırım. Nereden temin edebilirim?
Edit 2: Aşağıdaki komutlarla kurdum.
sudo add-apt-repository ppa:colingille/freshlight
sudo apt-get install winusb
« Son Düzenleme: 08 Ekim 2015, 12:31:57 Gönderen: lthx »
Çevrimdışı omer
  • İleti: 17
  • Dağıtım: LM 19.3 Mate 64 bit
« Yanıtla #10 : 12 Ekim 2015, 14:42:19 »
harddiskiniz 250 gb. farzedelim....
üç partition oluşturuyoruz...
C=windows=100 gb.=ntfs
D=veri deposu= 100 gb.=ntfs
E=linux=50 gb.= ayrılmamış bölüm
önce windowsu kurun...
sonra ayrılmamış bölüme linuxmint17 kurun...
grub da kurulsun deyin....
açılışta liste çıkar...
hangisini isterseniz ona girersiniz...
linuxta iken grub customizer programını kurarsanız...
açılış listesindeki sıralamayı değiştirebilirsiniz...
sonra "KAYDET"  ve  "MBR  ye YÜKLE" deyin...
yeniden başlattığınızda liste sıralaması istediğiniz gibi olur...
hatta istediğiniz satırları kaldır deyip kaldırabilirsiniz de...
