Gönderen Konu: Ekranda sürekli donma meydana geliyor  (Okunma sayısı 5532 defa)
« : 09 Ekim 2015, 11:09:18 »
Celeron işlemcili bir laptopa linux mint kurulumu yaptık. Ekranda sürekli donmalar oluşuyor. Sebebi ekran kartının yüklü olmamasımıdır yoksa başka bir sorun mu var anlayamadım.
uname -rm
3.16.0-38-generic i686
inxi -Gx
Graphics:  Card: Intel Mobile GME965/GLE960 Integrated Graphics Controller bus-ID: 00:02.0
           X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1280x800@60.0hz
           GLX Renderer: Mesa DRI Intel 965GME/GLE x86/MMX/SSE2 GLX Version: 2.1 Mesa 10.1.3 Direct Rendering: Yes
OpenGL renderer string: Mesa DRI Intel(R) 965GME/GLE x86/MMX/SSE2
00:02.0 VGA compatible controller: Intel Corporation Mobile GME965/GLE960 Integrated Graphics Controller (rev 0c)
00:02.1 Display controller: Intel Corporation Mobile GME965/GLE960 Integrated Graphics Controller (rev 0c)
Screen 0: minimum 320 x 200, current 1280 x 800, maximum 32767 x 32767
LVDS1 connected 1280x800+0+0 (normal left inverted right x axis y axis) 331mm x 207mm
   1280x800       60.0*+
   1024x768       60.0
   800x600        60.3     56.2
   640x480        59.9
TV1 disconnected (normal left inverted right x axis y axis)
Ynt: Ekranda sürekli donma meydana geliyor
« Yanıtla #1 : 09 Ekim 2015, 14:26:51 »
İlgili sistem için aşağıdaki komutun çıktısını da paylaşınız.
« Yanıtla #2 : 09 Ekim 2015, 14:45:39 »
System:    Host: burak-HP-Compaq-6720s Kernel: 3.16.0-38-generic i686 (32 bit, gcc: 4.8.2)
           Desktop: Xfce 4.12.2 (Gtk 2.24.23) Distro: Linux Mint 17.2 Rafaela
Machine:   System: Hewlett-Packard product: HP Compaq 6720s version: F.05
           Mobo: Hewlett-Packard model: 30D8 version: KBC Version 83.0C
           Bios: Hewlett-Packard version: 68MDU Ver. F.05 date: 10/22/2007
CPU:       Single core Intel Celeron M CPU 530 (-UP-) cache: 1024 KB flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 3457.93 clocked at 1728.967 MHz
Audio:     Card: Intel 82801H (ICH8 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Network:   Card-1: Broadcom BCM4311 802.11a/b/g driver: b43-pci-bridge bus-ID: 10:00.0
           IF: N/A state: N/A mac: N/A
           Card-2: Intel 82562GT 10/100 Network Connection driver: e1000e ver: 2.3.2-k port: 4020 bus-ID: 00:19.0
Drives:    HDD Total Size: 120.0GB (6.4% used) 1: id: /dev/sda model: TOSHIBA_MK1237GS size: 120.0GB temp: 43C
Partition: ID: / size: 108G used: 7.2G (8%) fs: ext4 ID: swap-1 size: 2.14GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 65.0C mobo: 58.0C
Info:      Processes: 161 Uptime: 44 min Memory: 406.8/2011.2MB Runlevel: 2 Gcc sys: 4.8.4
« Yanıtla #3 : 09 Ekim 2015, 15:42:59 »
[member=1676]mehmethanifi[/member], öncelikle aşağıdaki şekilde sisteminizi güncelleyiniz.
Güncelleme Yöneticisi => Düzenle menüsü => Tercihler => Seviyeler kısmından 4. seviye güncellemeleri işaretleyiniz ve Yenile düğmesine tıklayıp Güncellemeleri Kur düğmesine tıklayarak sisteminizi güncelleyiniz.
Ardından, Güncelleme Yöneticisi => Görünüm menüsü => Linux çekirdekleri aracı yardımıyla 3.16.x serisi çekirdeğin son sürümünü (şu an itibariyle 3.16.0-50 sürümde) kurunuz.
Ayrıca burada önerildiği biçimde UXA hızlandırmayı etkinleştirmeyi deneyebilirsiniz.
« Yanıtla #4 : 22 Ekim 2015, 15:00:37 »
Hocam merhaba,
Ekranda mozaiklenme olmaya başladı. yazı yazdığım zaman imlec sonradan geliyor. Bir klasörü simge durumunu küçülttüğüm zaman yada bir yerden başka bir yere sürüklediğim zaman yırtılıp toparlanıyor görünümü meydana geliyor.Bir web sayfasında gezinirken sayfayı aşağıya doğru indirdiğimde donuyor ondan sonra getiriyor yada harfleri silik gösteriyor bir kaç saniye sonra düzeltiyor.
« Yanıtla #5 : 22 Ekim 2015, 15:14:23 »
Düzenlemeyi yeni mi yaptınız yoksa sorun sonradan mı ortaya çıktı?
« Yanıtla #6 : 22 Ekim 2015, 15:15:19 »
Düzenlemeyi yazdığınız zaman yapmıştım hocam. Sorun o zaman düzelmişti ama emin olmak adına konuyu kapatmamıştım.
https://forum.linuxmint.net.tr/index.php?topic=4640.15  burada ki  acpi değerini varsayılan değerde bıraktım. Yaptığımız değişikliği geri alınca düzeldi.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=off"
« Son Düzenleme: 22 Ekim 2015, 15:16:35 Gönderen: mehmethanifi »
« Yanıtla #7 : 22 Ekim 2015, 15:19:39 »
Bu aynı PC'mi? Bu durumda xorg.conf dosyasını silmeyi deneyelim.
« Yanıtla #8 : 22 Ekim 2015, 15:52:55 »
evet hocam aynı pc. sistemi yeniden başlatıyorum.
