Gönderen Konu: kurulum asamasinda kurulum turleri gorunmuyor  (Okunma sayısı 3481 defa)
« : 12 Ekim 2015, 10:49:06 »
Merhabalar;
bir casper marka notebook a linux mint yuklemek istiyorum. kurulum turu kisminda disk secenekleri gozukmuyor. ne yapmami onerirsiniz
arti dugmesine tiklayinca asagidaki hata cikiyor
« Son Düzenleme: 12 Ekim 2015, 10:50:34 Gönderen: mehmethanifi »
Ynt: kurulum asamasinda kurulum turleri gorunmuyor
« Yanıtla #1 : 12 Ekim 2015, 11:14:22 »
sudo fdisk -l
sudo parted -l
« Yanıtla #2 : 12 Ekim 2015, 11:17:10 »
sudo fdisk -l
Disk identifier: 0x8bba5bef
/dev/sda1   *        2048    20482047    10240000    7  HPFS/NTFS/exFAT
/dev/sda2        20482048   498628607   239073280    7  HPFS/NTFS/exFAT
/dev/sda3       498628608   976769023   239070208    7  HPFS/NTFS/exFAT
Disk /dev/sdb: 32.0 GB, 32017047552 bytes
255 heads, 63 sectors/track, 3892 cylinders, total 62533296 sectors
Disk identifier: 0xba000000
Disk /dev/sdb doesn't contain a valid partition table
Disk /dev/sdc: 16.0 GB, 16008609792 bytes
255 heads, 63 sectors/track, 1946 cylinders, total 31266816 sectors
Disk identifier: 0x2213808f
/dev/sdc1   *          32    31266815    15633392    7  HPFS/NTFS/exFAT
sudo parted -l
Model: ATA ST500LT012-9WS14 (scsi)
Disk /dev/sda: 500GB
Partition Table: msdos
Number  Start   End     Size    Type     File system  Flags
 1      1049kB  10.5GB  10.5GB  primary  ntfs         boot
 2      10.5GB  255GB   245GB   primary  ntfs
 3      255GB   500GB   245GB   primary  ntfs
Error: /dev/sdb: unrecognised disk label
Warning: Unable to open /dev/sdc read-write (Read-only file system).  /dev/sdc
has been opened read-only.
Model: SanDisk Cruzer Force (scsi)
Disk /dev/sdc: 16.0GB
 1      16.4kB  16.0GB  16.0GB  primary  ntfs         boot
« Yanıtla #3 : 12 Ekim 2015, 11:42:42 »
Kurulumu 500 Gb.'lık diske mi gerçekleştireceksiniz?
« Yanıtla #4 : 12 Ekim 2015, 11:46:37 »
evet hocam
« Yanıtla #5 : 12 Ekim 2015, 12:04:00 »
Buradaki öneriyi uygulamayı deneyebilirsiniz.
« Yanıtla #6 : 12 Ekim 2015, 12:15:23 »
sudo fixparts /dev/sda
sudo: fixparts: command not found
« Yanıtla #7 : 12 Ekim 2015, 12:30:35 »
Fixparts komutu gpart paketi içinde, önce gpart paketini kurmalısınız.
« Yanıtla #8 : 12 Ekim 2015, 13:59:10 »
Hocam
sudo apt-get install gparted yazarak kurulum yapmayı denemiştim ama hata vermişti. Bilgisayarı teknik servise gönderdim ısınma problemi vardı. Servisten gelince tekarardan kurulum yapmayı deneyeceğim. Şimdi başka bir pc ye linux mint kurulumu yapacağım.
« Yanıtla #9 : 12 Ekim 2015, 14:04:30 »
Paket adı hatalı olmuş, aşağıdaki gibi önce gdisk paketini kurmanız gerekir. Gdisk kurulumu sırasında hata alırsanız bunları paylaşırsınız.
Önce aşağıdaki komut ile gdisk uygulaması kurulmalı.
sudo apt-get update && sudo apt-get install gdisk
« Yanıtla #10 : 12 Ekim 2015, 14:29:30 »
Tamam hocam. Bilgisayar geldiğinde deneyeceğim inşaallah.
