Gönderen Konu: [Çözüldü] Mate masaüstü kurulum hatası  (Okunma sayısı 8347 defa)
Çevrimdışı uyusuk
  • İleti: 172
  • Dağıtım: Linux Mint 17.3
  • İşlemci: İntel Core i7
« : 13 Ekim 2015, 15:54:14 »
Terminalden halletmek istedim ama şöyle bir hata verdi:
ali[member=2353]uyusuk[/member] ~ $ sudo apt-get install mint-meta-mate
[sudo] password for ali:
olduğunu gösterir.
 mint-meta-mate : Bağımlılıklar: mate-indicator-applet ama kurulmayacak
« Son Düzenleme: 15 Ekim 2015, 17:19:03 Gönderen: uyusuk »
Ynt: Mate masaüstü kurulum hatası
« Yanıtla #1 : 13 Ekim 2015, 18:02:45 »
cat /etc/lsb-release
Çevrimdışı uyusuk
  • İleti: 172
« Yanıtla #2 : 13 Ekim 2015, 18:26:58 »
ali[member=2353]uyusuk[/member] ~ $ cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17.2
DISTRIB_CODENAME=rafaela
DISTRIB_DESCRIPTION="Linux Mint 17.2 Rafaela"
ali[member=2353]uyusuk[/member] ~ $ inxi -Fxz
System:    Host: uyusuk Kernel: 3.16.0-38-generic x86_64 (64 bit, gcc: 4.8.2) Desktop: Gnome Distro: Linux Mint 17.2 Rafaela
Machine:   System: LG product: R580-U.AAD6BT version: 04
           Mobo: Quanta model: QL5 version: TBD Bios: INSYDE version: QL5L3G12 date: 11/27/2009
CPU:       Dual core Intel Core2 Duo CPU P8700 (-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 10110.2
           Clock Speeds: 1: 1600.00 MHz 2: 1600.00 MHz
Graphics:  Card: NVIDIA G96M [GeForce GT 130M] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: nvidia (unloaded: fbdev,vesa,nouveau) Resolution: 1366x768@60.0hz
           GLX Renderer: GeForce GT 130M/PCIe/SSE2 GLX Version: 3.3.0 NVIDIA 340.93 Direct Rendering: Yes
Audio:     Card: Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           driver: r8169 ver: 2.3LK-NAPI port: 1000 bus-ID: 05:00.0
           Card-2: Ralink RT2790 Wireless 802.11n 1T/2R PCIe driver: rt2800pci ver: 2.3.0 bus-ID: 02:00.0
Drives:    HDD Total Size: 500.1GB (7.3% used) 1: id: /dev/sda model: WDC_WD5000LPVX size: 500.1GB
Partition: ID: / size: 306G used: 17G (6%) fs: ext4
Sensors:   System Temperatures: cpu: 55.0C mobo: N/A gpu: 0.0:55C
Info:      Processes: 192 Uptime: 6 min Memory: 1078.2/3920.5MB Runlevel: 2 Gcc sys: 4.8.4
Not:Şu an masaüstü olarak Unity  kullanıyorum.
« Yanıtla #3 : 14 Ekim 2015, 09:29:47 »
Aşağıdaki komutların da çıktılarını paylaşınız.
sudo apt-get install mate-indicator-applet -s
dpkg -l | grep indicator-applet
Çevrimdışı uyusuk
  • İleti: 172
« Yanıtla #4 : 14 Ekim 2015, 13:11:42 »
ali[member=2353]uyusuk[/member] ~ $ sudo apt-get install mate-indicator-applet -s
olduğunu gösterir.
 mate-indicator-applet : Bağımlılıklar: libindicator7 (>= 0.4.90) ama kurulmayacak
ali[member=2353]uyusuk[/member] ~ $ dpkg -l | grep indicator-applet
ii  indicator-applet-complete                     12.10.2+14.04.20140403-0ubuntu1                     amd64        Clone of the GNOME panel indicator applet
« Yanıtla #5 : 14 Ekim 2015, 13:23:57 »
Bir de aşağıdaki komutun çıktısını  paylaşın.
sudo apt-get purge indicator-applet-complete -s
Çevrimdışı uyusuk
  • İleti: 172
« Yanıtla #6 : 14 Ekim 2015, 13:40:11 »
ali[member=2353]uyusuk[/member] ~ $ sudo apt-get purge indicator-applet-complete -s
  indicator-applet-complete*
0 paket yükseltilecek, 0 yeni paket kurulacak, 1 paket kaldırılacak ve 6 paket yükseltilmeyecek.
Purg indicator-applet-complete [12.10.2+14.04.20140403-0ubuntu1]
« Yanıtla #7 : 14 Ekim 2015, 13:50:03 »
Aşağıdaki komut ile indicator-applet-complete paketini kaldırmayı deneyiniz, sanırım bu paket ile mate-indicator-applet paketi çakıştığı için Matemasaüstü kurulumu gerçekleşmiyor.
Çevrimdışı uyusuk
  • İleti: 172
« Yanıtla #8 : 14 Ekim 2015, 14:13:53 »
Teşekkürler bu komut ile sildikten sonra mate'i terminalden yükledim ve kurdum fakat oturum kapadıktan sonra masaüstü seçeneklerinde sadece Unity ve cinnamon gözüküyor .
« Yanıtla #9 : 14 Ekim 2015, 14:33:55 »
dpkg -l | grep mint-meta
Çevrimdışı uyusuk
  • İleti: 172
« Yanıtla #10 : 14 Ekim 2015, 14:47:41 »
ali[member=2353]uyusuk[/member] ~ $ dpkg -l | grep mint-meta
ii  mint-meta-cinnamon                            2015.07.09                                          all          Set of packages installed by default in the Cinnamon edition of Linux Mint
ii  mint-meta-codecs                              2015.06.11                                          amd64        All the packages required for multimedia support in Linux Mint.
ii  mint-meta-core                                2015.07.09                                          all          Core Linux Mint packages
« Yanıtla #11 : 14 Ekim 2015, 15:02:57 »
mint-meta-mate paketi ile kurulum yapmamışsınız.
Çevrimdışı uyusuk
  • İleti: 172
« Yanıtla #12 : 14 Ekim 2015, 19:49:53 »
Dediklerinizi sırasıyla tekrar ettim ve sonra kurmaya çalıştım.Aynı hata:
olduğunu gösterir.
« Yanıtla #13 : 14 Ekim 2015, 23:41:24 »
Aşağıdaki komutun çıktısını da paylaşınız.
inxi -r
Çevrimdışı uyusuk
  • İleti: 172
« Yanıtla #14 : 15 Ekim 2015, 00:32:33 »
ali[member=2353]uyusuk[/member] ~ $ inxi -r
Repos:     Active apt sources in file: /etc/apt/sources.list.d/google-chrome.list
           deb http://dl.google.com/linux/chrome/deb/ stable main
           Active apt sources in file: /etc/apt/sources.list.d/graphics-drivers-ppa-trusty.list
           deb http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu trusty main
           deb-src http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu trusty main
           Active apt sources in file: /etc/apt/sources.list.d/noobslab-apps-trusty.list
           deb http://ppa.launchpad.net/noobslab/apps/ubuntu trusty main
           deb-src http://ppa.launchpad.net/noobslab/apps/ubuntu trusty main
           deb http://packages.linuxmint.com rafaela main upstream import
           deb http://extra.linuxmint.com rafaela main
           Active apt sources in file: /etc/apt/sources.list.d/pasgui-ppa-trusty.list
           deb http://ppa.launchpad.net/pasgui/ppa/ubuntu trusty main
           deb-src http://ppa.launchpad.net/pasgui/ppa/ubuntu trusty main
           Active apt sources in file: /etc/apt/sources.list.d/steam.list
           deb [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam
           deb-src [arch=amd64,i386] http://repo.steampowered.com/steam/ precise steam
           Active apt sources in file: /etc/apt/sources.list.d/webupd8team-java-trusty.list
           deb http://ppa.launchpad.net/webupd8team/java/ubuntu trusty main
           deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu trusty main
